To hard chrome plated aluminum you need cyanide solution. Chrome will only stick to copper. You have to deposit copper on aluminum first. Yet its still brittle.
Nikasil is the best for durability since it’s a Silicone carbide particles embedded in ductile nickel layer. It’s more a physical plating, molten nickel and Silicone carbide powder sprayed onto rough aluminum surface.
I bought the jetusolis based of my remember of a comparison beamshots by clemence with a cool white high-CRI nichia but i don’t remember if it was an e21a or an optisolis (I think that he wasn’t selling it yet at this time) but I was really impressed. It was close to the rendition of a photo taken with a flash. I don’t now if those beamshots are still around here : there was a cup of coffee on his wood workbench with several other things on it, an orange tube with a blue topcap, a green tool, …
The optisolis 6500°K tint isn’t green for me, more something like a pale electric blue, maybe with a hint of green, a pale blue slightly greenish. You will notice its particular tint without a doubt. Without this tint it would be perfect but the colors rendition and separation would not be the same without it, most probably.
Never seen this maukka’s tests before but I’m glad that it match my visual impression.
The tint of the 5000°K is more pleasing to my eyes but I really appreciate and prefer the colors separation of the 6500°K which is something new for me concerning high CRI LED.
Je ne sais pas si les plages des différentes couleurs (primaires, secondaires, tertiaires) émises et donc restituées par la 6500k sont vraiment plus étendues, plus complètes, plus riches, que la 5000k.
Je n’ai pas un oeil d’étalonneur formé à la colorimétrie à l’oeil nu, seuls des tests par maukka et autres possesseurs d’appareils pour mesurer la colorimétrie pourraient te renseigner sur ce point avec certitude.
Je trouve que les teintes chaudes sont un peu plus dynamiques avec la 5000k et que les teintes froides sont plus propres et plus riches avec la 6500k.
Cela est bien entendu lié à l’indice de restitution des différentes couleurs mais la teinte dominante de la LED joue très certainement un rôle. Les bleus et verts ne sont pas “parasités” par une teinte chaude de la LED comme ils pourraient l’être avec une LED de 3000k par exemple, et donc ils paraissent d’autant plus “propres” que la teinte de la LED est légèrement bleutée et les nuances paraissent également riches du fait du très bon indice de restitution des bleus et verts.
Comme c’est la première fois que j’utilise une LED à très haut CRI avec une teinte un peu froide je trouve cette combinaison surprenante (inattendue) et intéressante même si le côté froid de la LED me gêne un peu. Je n’ai jamais apprécié le blanc froid mais jusqu’à présent les LEDs “blanc-froid” n’avaient pas un aussi bon indice CRI pour autant de couleurs, ce qui les rendaient particulièrement inintéressantes, voire repoussantes à mes yeux. Le CRI70 me rend mal à l’aise même si la teinte me convient. Je me sens déphasé et “color-blinded”, avec l’optisolis 6500k ce n’est pas le cas malgré sa teinte bleu pale. Bon, je ne mettrais pas cela chez moi en éclairage domestique pour autant.
I also dont use cool white at home, I use 3000k Incandescent… @100 CRI…
good points, darksucks offers nickel plated lights… they stay shiny… no tarnish, but also not Oligodynamic like copper, silver, and gold… did somebody mention Gold plating? LOL!
What kind of MCPCB comes in the kit? Is it XP footprint or specially made for E21a/Optisolis? If XP, is the LED connected to the positive and thermal pads, then MCPCB insulated from the aluminum pill, and ground wire connected to the MCPCB?
Sorry if I’m misunderstanding something or if this has been discussed elsewhere.
That’s a curious choice. I suppose these don’t have super thin ceramic insulation, do they?
If they do - I’m very curious about the maker.
If they don’t - does copper offer any real advantage over alu?
- no benefits of nanoceramic or copper board at Jet-U power level (230-235mA). But decided to go with copper because BLF likes copper and eventually someone will use it in a hot rod lights.
Faaaaar cheaper than nanoceramic board. $0,6/pc (for 2 LED types at 200pcs per type, 400pcs total all in) vs $2/pc (for 400pcs per LED type). The NC prototyping cost is killing me.
About the maker, I’ll keep it secret to stay alive. But you can find many makers out there using the same base substrate. Bergquist
At 230mA power level, copper doesn’t benefit to almost everything except it can be soldered onto solderable objects. These 10mm Jetusolis/JetuE17A/JetuE21A copper MCPCB already tested against NC board.
UPDATE: 190407
MOQ of 60pcs reached. But I will keep the interest list going until I have finished with RRT01 testing. And possibly combined with RRT01 interest list. My RRT01 shipment from Banggood still somewhere between Hongkong and Indonesia. With combined order I should get better pricing for you too.
I wanted to update my interest in total from 1 Jetusolis 5000K to another Jetusolis 3000K
So I made a second comment.
Now the second Jetusolis moved to Nr. 28;
Nr. 28 and Nr. 1 is the same person
I’ve never bought a flashlight this way and I’m curious. Does this mean we can get what is essentially a new flashlight with our choice of LED and color temperature? (I’m curious about the Optisolis but I’m not sure if I’d want 3000, 4000, or 5000K.) How much would one of these cost in total and how exactly do we set it up?
