I like the clip on the S Mini better than the bigger 2-way clip on the newer model, and I like the old square knurling design more than the staggered lines. Itās a bit longer, but the extra length at the front goes toward protecting the optic. I also kinda prefer it without the magnet, though I donāt care much either way.
The things I like more about the S1 Mini are the lighted button, the choice of two different optics, and the low-battery detection (finally). Itās also nice being able to get it in aluminum, which is generally cheaper and has a good balance of weight and thermal properties.
Theyāre already good, but it would be nice to combine the best parts of both and upgrade a few other thingsā¦
any new developments that could lead my Olight Copper S Mini to Nichia Nirvana?
or is Sacrificing an Olight S1 Mini High CRI, still the OnlyWay to Enlightenment?
Sorry for the thread resurrection, but I got an S1 Mini cheaply and am itching to take it apart. I have a question and an observation.
First, Yajiamei 17mm TIRs fit in an S Mini; Iād assume they will also fit in an S1 Mini. I suggest the 20Ā° Beaded as the smooth versions project a square.
Second, does drilling/breaking out the optic seem like a viable way to get into the S1 Mini without risking the switch and driver? Youād still have to figure out a way to pry the retaining ring loose, but you could do that on the ring itself and work from the back where scratches would be hidden.
Iāll add another variable in the equation : focusing the LED in the optic :-p
These lights are a bit tricky to mod if you donāt keep the stock emitter model.
That said, my S2RII now runs a Samsung LH351D (on a 10mm KD MCPCB) and the beam is nice so everything is doable
Similar to your proposal, I tackled it from the optic side. I was prepared to but fortunately did not have to replace the optic. I simply inserted the flat tip of the smallest micro-screwdriver I had between the optic and the blue ring and slowly worked it around/out. The TIR optic survived fine with only two small indentations where I first inserted the screwdriver.
The worst damage was some light scratches to the ringās blue finish and to the bezel where I pried the screwdriver against the bezel edge. Working slower and gentler I probably could have further minimized even those scractches but since I intended this as an EDC any light scratches werenāt a concern.
I was fortunate this time and nothing got broken (which with modding is always a risk). All I can share it to take your time and be gentle with the blue metal ring because (a) it is not as hefty as it looks and (b) unlike the optic, it cannot be replaced!
As -X3 indicated above, the only issue I had was with the LED centering which because of the emitter size differences (5050 XM-L2 versus 3535 LH351D) was a challenge to center exactly but beam looks fine so I mustāve gotten it right enough.
Well, I done goofed today - was following this to get the driver out (stripped insulation from ground wire, needed to replace wire), and the SMD switch has broken off. Great. So now I have to either find the right switch and solder on (possible but tough) or just give up on the whole thing.
Cautionary note here: Iāve killed four S1 Minis with modding attempts this week. The moonlight mode and switch status light appear to be on a different channel from the rest of the modes, and the driver is insanely sensitive to damage on this channel. Even the slightest short while a cell is installed causes permanent damage. I was trying to be fancy and keep the stock optic, but I couldnāt figure out why I kept ending up with bad moonlight modes. Today I did one by simply drilling the optic, and it was working fine until I stupidly accidentally touched one of the MCPCB leads with tweezers while a cell was installed. The light was turned off, but the LED briefly flashed on anyway, and the moonlight channel was broken afterwards.
After this failure, moonlight mode is useless because the output is so low. Sometimes when turning it on there is a brief flash before the output drops. The switch status LED is also no longer visible. The UI is completely normal and every other mode and function works fine.
I consider myself a fairly competent modder. Iāve worked on over 30 Zebralights with only a single major failure. Iām 0/5 for Olights so far. If youāre going to attempt an emitter swap on any of the EDC models, I strongly suggest just drilling the optic or using the standard bezel prying method when possible. And donāt do anything with a cell installed.
Donāt let the photo fool you, the light on the left is only producing 0.4 lumens. The broken moonlight mode is barely driving the LED enough to turn it on. Itās not a useful output level, and some LEDs flicker badly.
No. The prying method shown here works fine. Just take the ring and optic out and desolder the LED. Iāve done like 6-7 olights with no issues. Led swaps are fine. The s2 copper I tried was a disaster thoughā¦
Edit: my mistake. Iām talking about the s mini, NOT the s1 mini. I have seen one of those.
I dropped my S1 mini a bunch of times and the Moonlight mode began exhibiting the same behaviour as your damaged lights, Bob. Funnily enough it spontaneously fixed itself after a while and the light now functions as normal.
