FREEME ✌ ASTROLUX FT03S SFH55 9300lm & FT03 SFT40 2200lm 1300m NarsilM v1.3 USB-C - ALIVE
Thanks. I think koef3’s “corrected” test represents an emitter in a C8 reflector, but without driver and lens. If I understand koef3’s updates and follow-up post, the reflector alone seems to cost 6. If an AR lens costs another 6, that leaves around 8-18% lost in the wiring and driver.
The koef3 numbers I quote are the “reduced” values, which are labelled “CORRECTED” in the top-most “LED TEST” chart. The other charts only show the initial bare emitter figures. I am somewhat new to the details, but I do understand what domes do and such.
I’ve been reading this and related posts as well, but I was most interested in the difference between tm07 and nkresho’s lights. tm07’s light appears to be making 2000lm or more if both cd figures are accurate.
I can tell you already you’re going to get way more loss in a reflector than 6. More like a minimum of 15 to 20% assuming it’s a really good quality reflector. Most are over 20%.
To get a 6% loss a reflector would need to use a silver coating. That’s too expensive for most flashlights. Typically flashlights use an aluminum coating which is a lot cheaper but also a lot less efficient.
In Koef3’s tests, corrected means it’s at 85°C.
Leds lose output as their temperature goes up. The blue line is at 25°C which is about room temperature. That would be like “turn-on” lumens.
Once the light has run maybe 30 seconds that’s where you see his “corrected” lumens at 85°C.
When you measure a light according to ANSI-FL1 specs you measure after the light has been on 30 seconds.
Different people on BLF like to use different times. Some care mostly about turn-on lumens, but most prefer the more realistic number at 30 seconds. I try to include both numbers in my measurements so people get an idea how fast the lumens drop. Of course, with a really powerful light that gets hot super fast, you might have to post the lumens at 25 or 20 seconds.
Note that Cree also lists output for their leds at both 25°C and at 85°C so that’s probably why Koef3 used those exact numbers. He is also probably estimating they are at 85° since you can’t actually measure the junction temperature of the die.
Koef3’s follow up post was about luminance which is different from lumens.
Lumens are to total amount of light.
Luminance is the amount of light per square millimeter of the die.
Mar/05/2019 12:31:20 —-> Apr/05/2019 23:52:47
240.480 Cd (0”)
230.040 Cd (30”)
NW.
6m.
5,89A at the tail with blue 26650 Liitokala
Perfect focus.
Got my FT03 yesterday, forgot all about it, what a surprise, surprise, surprise! :smiley: :+1:
. My NW came with the board off center making the spot oblong and fuzzy. Broke the board loose by the screws and the thermal grease, floated it in, it is much better now! Proceeded to clean all contact surfaces with Dykem, a very strong alcohol and then clean again with No-OX-ID leaving a light film/residue behind.
. Some readings
. The best reading I got on output was just over 2000lms at turn on, this was the second hit…
. When I tested the 30T it actually lost out put from too much current 9-9.4 seems to be the max before output drops from over current on my FT03.
. Indexed the tail cap and drilled the holes bigger for a lanyard also have a clean de-domed SST40 for it, might just leave this one alone, it’s a Keeper for Sure!
. :heart_eyes: :+1:
@Kawiboy, that is way too close to the SST-40s current death.
Seems like the gold wires are having a very hard time keeping up with such a high current load.
They may have been damaged very slightly, which is why the numbers are probably lower.
Mine MW just shipped yesterday. Ordered on 3/5.
BG has really upped their game with deliveries, most people here receiving it in about 10 days. Hope to see it arrive before end of the month.
What it is drawing and what the LED is seeing is 2 different things from my experience, I don’t put too much faith in tail cap current draw, you have to measure at the emitter. This is were my FT03 out put topped out at, that is were I will run it at …….Wide Open Throttle!
Edit: The Black and Gold Liitokala 50A netted 1987lms. at turn on, straight off the charger 4.21v.
I have CW SST-40s putting out 2200lms so for NW this is acceptable to me.
Thanks for the testing Kawi! :smiley:
You may be more proof that my Brand new Molicel P42A 4200mAh 45A 21700 will be too much amps for the light! I got $22 worth of batteries[fixed income] and no other 21700 light to use them in!
I love that NO-OX-ID,Illumns turned me onto it 6 years ago,great for so many things! :+1:
EDIT: The P42 is more like 30A continuous. Mooches test show it has little value and gets too hot[battery degradation] at 45A. Still has Amp draw slightly better than 40T and very similar to 30T.
Is going to be time to charge my light, I know when I connect the cable the switch turns orange, a few questions
1. Does the switch change to another color (Green?) when the battery is fully charged?
2. What is the cutoff voltage when it stops charging?
3. I know I can turn the light on while is being charged, but does it still charge the battery while flashlight is turned on in the low modes? (moonlight to Around 50 lumens)
Thanks!
KB has a point about the amps at the LED, as opposed to at the battery, which is how we measure it. In addition, the way we typically measure amps at the tail with a clamp meter is to remove the tailcap and use a heavy gauge wire, which is ok, but the tailcap has resistance, specially if no bypasses, that reduces amps. So what you are really running is probably lower than we measure.
My CW has shipped 2019-04-05 22:28:49. Ordered on 28th March.
Your a lucky man! I am a bit jealous!!!
I ordered mine February 14, 2019 and it was shipped April 4, 2019. You only waited 1 week , I[like a lot of others] have waited almost 7 weeks!
In any event, enjoy it when you get it! :partying_face:
Even better is the fact that it usually only take 5-6 days to arrive.
Sorry missed this post.
I was running a shocklii 26650 when I ran it through the paces. I haven’t squeezed a 40t in there yet.
Also, if it’s relevant to the comment above, my sphere is maukka light calibrated and corrected for color temp (scaled multiplier based on CW and NW calibration lights).
No one lopped a dome off yet???
Member “TM07” POST # 1673
De-domed CW 1700L/367Kcd
Dome on 235kcd = 969 meters
Dome off 367kcd = 1211 meters
So it sounds like I’m not missing out by only having the 15A Keeppower 26650?
