Keep in mind, though, that those meters are powered by the voltage source they’re sensing. That means that “charging current” will quite possibly never go low enough for the charging-IC to sense, “Okay, time to stop…”.
The charger will or at least should hold it in CV mode at ~4.20V, and not overcharge, but it just won’t ever show it as being topped off.
I put a 3v XHP50.2 in my convoy l2 (single cell) with the intention to make it more of a single cell Q8, didn’t work. still throws like a beast considering what it is. but i do like the slightly larger spot.
I’m not sure if i’m just getting used to high lumens (my edc has a ~2200 turbo) but it doesn’t seem that bright. maybe it’s the X6 driver? still waiting on a LD-A4
I found a cell which had been discharged to 1.8V. Out of curiosity, I tried charging it. Things went pretty well until it was nearly full, and then it refused to go up above ~4.12V or so. It just kept charging and charging.
So… that cell is basically dead. It may still be usable for some lightweight purposes, but I drew sad faces all over it to make sure I don’t forget which cell it is.
I found that even with the volt meter it does stop charging. I think the lower resistance batteries terminate quicker and maybe just the smaller protected ones take forever
Put a 3V XHP-50.2 in my TK61, the driver is cranking amperage safe for an XM-L2 so I need to address power level, not sure how to go about making the TK61 do the amperage this emitter is capable of… as it is it’s only doing some 2100 lumens.
I’m trying to install an osram white flat in a GT mini but the screw cutouts of the new 20mm pcb don’t line up. Should I just use thermal paste without screws?
Well for some reason the screw cutouts on my gtmini stock pcb are spaced equally whereas the ones on L4Ps 20mm 3030 board are closer together so there no way to screw the board in.
Ignore the super bad de-soldering job.
Aha, so holes for the wires and holes for the screws don’t all line up… Gotcha.
I only got a micro, so can’t say how the mini’s put together, but if the reflector pushes down hard enough on the pcb, regular thermal goop like AS5 should work fine. The reflector (and presumably centering spacer?) should keep it lined up and centered. It’ll “float” and self-center via the reflector.
still its always risky with the LED holes within the MCPCB diameter
if it rotates as well it will easily cut through the wire insulation, had that often enough in the past
best is to drill fitting holes and thread them
or
use a grinding tool or file to remove material from MCPCB
if you work on MCPCB always make sure if you are finished the bottom is flat!
Because axial fixation is done by bezel/reflector/centering ring, one screw should be enough to prevent the MCPCB from rotating and shearing off the leads. IMHO there will always be one cutout that fits. Just don’t overtighten the screw to keep the MCPCB flat. Easy does it.
Kawi, I have that but I don’t think it will supply enough power to the 50.2… so… I modded the TK61 entirely.
I wiped the factory driver , installed an FET+1 with ramping and reversing 7 level firmware, then modified the carrier for 4P. With Efest 3500mAh cells it does 4490 lumens on level 7.
This is with my light box diffused and calibrated per Maukka. May be a little low but my meter shows actual lumens now with no multiplier so it’s pretty cool not having to mess with the math. lol
I did a simple driver swap on a Thorfire TG06S. I decided I wasn’t crazy about it always starting on high, so I swapped in a Nanjg 101 AK-A1 with guppydrv. It’s 14500 only now but I like the programmable firmware. The only issue is moonlight doesn’t work. It’s a dead setting, all the others work fine though. I don’t know if the driver is defective or if moonlight is just finicky.
