Thank you for the information but sadly it’s not easy to get things from Russia. Last time we purchased the Russia headlamp, it took from late 2018 to early 2019 to arrive. :person_facepalming:
Actually sofirn can get samsung leds but it hard to purchase accurate tint zone, it comes reel by reel. Sofirn need to separate them. Then better tint sell well, what about these tints not so good? Sell to muggles?
Barry, thanks for checking the 80CRI 5000K Samsung LH351D leds, the output and CRI looks good.
The question is: how does the beam shape and the tint look if you shine the XP-L2 version and LH351D version next to each other? On a white wall, but also when illuminating some colourful things, or outside? I know that you are less flashoholic than we are , but perhaps you can share us your personal impression of the difference?
Since it uses Anduril, then most likely that is 7 clicks will cycle from Off to On to Blinking (if 3 states) or Off to High to Low to Blinking (if 4 states).
Would also probably like to order on AliExpress. Banggood lately has been cancelling my pre-orders after they already take my money, then mention some other issue if the pre-order is taking too long, and suggest me to cancel it or they cancel it automatically…
Can’t answer regarding the bezel. Bezel not glued would probably be OK? (could carelessly unscrewing the bezel damage the LEDs, like in the earlier batch of Fireflies ROT66 where the optic will scrape off and damage the LED?)
Regarding the driver board, I seem to recall Toykeeper or someone in another SP36 message thread, mention that due to the smaller size of the head, there is not additional space to hold the driver board in place (like screws), so it has to be glued in place (otherwise there is risk of shorting out something, which I recall Toykeeper mentioned too)…
