Can you please give us some more information about the XHP35 HI driver?
Is it a new developed driver from your usual supplier or does it come from KD?
Will it also work 1S (1x 26650) or 2S (2x26650) only?
What is the maximum current it can apply to the XHP35 HI?
What diameter sizes of the driver can you offer?
Okay, so it’s not possible to boost to 12V with only one battery. I guess Kaidomain’s H1-A will still need some tuning for providing 1.5A to the XHP35HI from a single cell. But I see that Sofirn will soon launch the C8G (1x 21700 with XHP35 HI, SMO and 2.000lm). In my opinion the Convoy L2 makes much more sense with XHP35 HI. The L6 is quite a large light for this little amount of lumens (max. 2.000lm), its small reflector diameter in comparison to its length and its moderate power consumption. The XHP35 HI is - to my mind - for throwers and the L6 is more or less an allround-like flashlight but no thrower, perfect for XHP50.2 or XHP70.2. Just sayin’…
According to Jensen567's figures the H2-C still did well at “2A” gear, but pay attention to the already low efficiency at that point (1S input with R075 + R075 sense resistors). Since high mode uses a 60 second stepdown you may try an R100 over the stock R050 (2.25A maximum), but beware of the low efficiency risks, high current losses in switches, springs, etc.
If I were Simon I would go to driver designers and manufacturers and tell them to “stop complaining and make an outstandingly powerful driver, this is for enthusiasts”.
Simon, just so you know, Richard at MTN Electronics has designed a Boost driver that works with one or two cells and delivers 2.3A to the XHP-35. This is good for over 2000 lumens in your C8+. Perhaps you should work out a deal with Richard?
For what it’s worth, this same driver of Richards also excels in the L2, amazing lights these 2!
I put a 3v XHP50.2 in my L2 @12A (single cell). it’s a nice light, easy to focus. just guesstimating by eye, CD is a little higher than stock, but quadruple the lumens.
About the anodizing, my l2 came like it was wrapped in sandpaper compared to the super smooth ano from the S2+’s
I don’t know of available drivers that will supply the optimum current to the XHP-35 as far as Banggood or even on Aliexpress. The drivers I have used are from members of this forum. One in the US and one overseas. LED4Power’s drivers can be configured to use 4 cells to power the 35, these require extension tubes on the L2 to allow the use of 4 26650’s or a normal 2 cell tube set-up can make use of 26350’s with shorter run times. The US made Boost driver can use one or two cells to power the 35 to 2.3A or so, these are the more expensive but more compact option. This latter comes from Richard at MTNElectronics.
