Since it uses Anduril, then most likely that is 7 clicks will cycle from Off to On to Blinking (if 3 states) or Off to High to Low to Blinking (if 4 states).
Would also probably like to order on AliExpress. Banggood lately has been cancelling my pre-orders after they already take my money, then mention some other issue if the pre-order is taking too long, and suggest me to cancel it or they cancel it automatically…
Can’t answer regarding the bezel. Bezel not glued would probably be OK? (could carelessly unscrewing the bezel damage the LEDs, like in the earlier batch of Fireflies ROT66 where the optic will scrape off and damage the LED?)
Regarding the driver board, I seem to recall Toykeeper or someone in another SP36 message thread, mention that due to the smaller size of the head, there is not additional space to hold the driver board in place (like screws), so it has to be glued in place (otherwise there is risk of shorting out something, which I recall Toykeeper mentioned too)…
A LED with a green tint will look bad even to muggles, even if they ignore the reason why it looks bad. They won’t like it and you will loose customers.
But a bad tint can be corrected with an appropriate filter and they are several ways to mount or incorporate it.
- Soft thin filter between a TIR optic and the front glass lens to keep the filter flat. The filter should resist to heat and UV to not degrade too quickly over time = more expensive.
- Front glass lens replaced by a tinted glass lens.
Front bezel threaded to mount removable glass filter just like on camera lens. Not cheap.
