I find all the bickering and “threatening” to not purchase hilarious. It’s got a well-loved open-source firmware, a good range of fully-regulated power, a standardized LED layout and optics, a novel rear e-switch, and it still manages to be basically the second-smallest 18650 light in current production. At $30, I’d buy it if they painted it plaid; we’re lucky it doesn’t cost three times that much.
I’m already down for one, but put me down for a second. I’ll probably buy at least that many. If nothing else, they’ll be fun to tinker with or make good gifts.
Obviously no one is entitled to this light, it’s being designed by volunteers and I appreciate the work they’ve done. I do however see the point that these people are making. This is the looks category of the main post as of right now:
Bearing this in mind, I don’t think it’s that unreasonable for people to be upset and say that they may have lost interest in the light because of this.
Call me what you will but I think I like the revised grey version better than the original…
Should I be interested in the LH351D version at all? What will it do differently than the XP-L? I’m thinking about adding a second one to my request and I’m wondering if I should get one of each.
The first post has not been completely updated, but it looks like the second option will likely be the Luminus SST-20, not the LH351D.
The main difference is those two options would 4000K color temperature (warmer appearance) and high CRI, which will be most noticeable when viewing objects with lots of red tons in them, like skin and wood tones.
The SST-20 also would have similar or perhaps a slightly tighter beam than the XP-L HI, and lower output. The LH351D, should the last reported plan change and that emitter be offered, will have a floody beam best for close-up use, and have output nearly as high as the XP-L HI.
Both will likely have a slight greenish-tint at lower power levels that may or may not bother you - different people care different amounts about this - where as the XP-L HI should have a very neutral or perhaps even slightly rosy appearance.
Looking at all these last minute changes, I guess I’ll just hope we get some good emitters.
And I think I’ll be getting the ol’ lathe set up if logos on the button and up the only option. Last time I did a group buy was the 348 and thankfully they sold it with or without markings.
