Panasonic NCR18650A (with PCB) from FocalPrice
Thanks ada_potato, that looks like a pretty good price for these batteries. Welcome to BLF!
Aloha and welcome to BLF ada_potato!
Maybe we can get HKJ to review these to makesure they're on the level.
I also ordered 4 of the protected ones from FP. They should arrive this week. I’ll then conduct my results with my humble Accucell Hobby Charger at 1 A discharge rate.
Good to have you here, ada_potato.
Hi!
If they are protected, protection is DIY, not by manufacturer. I quess...
there are more batteries for great price on FP:
http://www.focalprice.com/EB0039S/Panasonic_2900mAh_18650_Battery_with_Protection_Grey.html
http://www.focalprice.com/EB0040S/Panasonic_2900mAh_18650_Battery_Grey.html
and marsfire :) with "original" Sanyo 3800 mah inside http://www.focalprice.com/EB0051R/Sanyo_37V_3800mA_18650_Liion_Battery_for_High_Power_Flashlight_Red.html
from some reports on their site Panasonic cells are good, but some doubts still presents... :)
Wow, that's a cheap price.
So, if they're lying about one of their batteries, what are the odds that they're lying about some or all of their batteries?
They are protected, the problem is the description as far as I can see.
In buyincoins got the same batteries, look at the white and red ring on top of it (+) and compare to the unprotected.
Here you also got the link to the ones at buyincoins, where by the way they are cheaper if you buy only 1-2 units.
They are, but not by manufacturer.
The latest batch of batteries I got from BIC appeared to be really bad. Blue Ultrafires rated at 2400 mAh were 220 in real. And 3600 protected UFs only 880 mAh. I'm not buying another battery from BIC. I guess FocalPrice green Panasonics are genuine but maybe with untuned circuits.
Yes you are right, I did not get you.
There isn't any cell manufacturer as far as I know selling protected cells, they are always unprotected, they are protected by the companies who re-label.
The similarities here is is ULTRAFIRE, not BIC. You can buy UF batteries from ebay, Manafont, DX etc and most likely you'll get the same junk.
The first batch I had from them (talking about 2400 ones) were way better. They now sell uberly inexpensive but apperantly junk cells under UF brand. I have always avoided UF cells but were surprised I had good luck before.
FocalPrice has really good prices if bought over 3 pieces. I really wonder how my ones will measure. As the OP says, they will more likely be genuine. Maybe I'll get their 2900mA Panasonics too.
I feel they are genuine just from the measurements given by ada_potato if we take as a true value the 3100mAh of the panasonic, compared to his trustfire flames gives us the trustfire flames are 2254mAh which sounds to be true on the old batches of them.
I have just seen this same panasonics at CNQG, the price is a lot more expensive, but at least they have published its resistance, being ≤45mΩ.
Here you got the link:
http://www.cnqualitygoods.com/goods.php?id=1495
I bought two of these cells at CNQ and will add two discharge curves later when I'm home.
They published something that is absurd, they cannot be under 100mOhm. The cell alone has 80-90mOhm and "standard" mosfets will add 25-38mOhm, from 4.5V to 2.5V
45mOhm could be the resistance of just the protection pcb.
But you are right, it's useless to claim this would be the total resistance of the protected cell.
From my tests, I believe the unprotected 2900mah panasonics to be genuine. They do seem to bulge out very slightly in the middle, though.
