The latest batch of batteries I got from BIC appeared to be really bad. Blue Ultrafires rated at 2400 mAh were 220 in real. And 3600 protected UFs only 880 mAh. I'm not buying another battery from BIC. I guess FocalPrice green Panasonics are genuine but maybe with untuned circuits.
There isn't any cell manufacturer as far as I know selling protected cells, they are always unprotected, they are protected by the companies who re-label.
The first batch I had from them (talking about 2400 ones) were way better. They now sell uberly inexpensive but apperantly junk cells under UF brand. I have always avoided UF cells but were surprised I had good luck before.
FocalPrice has really good prices if bought over 3 pieces. I really wonder how my ones will measure. As the OP says, they will more likely be genuine. Maybe I'll get their 2900mA Panasonics too.
I feel they are genuine just from the measurements given by ada_potato if we take as a true value the 3100mAh of the panasonic, compared to his trustfire flames gives us the trustfire flames are 2254mAh which sounds to be true on the old batches of them.
I have just seen this same panasonics at CNQG, the price is a lot more expensive, but at least they have published its resistance, being ≤45mΩ.
They published something that is absurd, they cannot be under 100mOhm. The cell alone has 80-90mOhm and "standard" mosfets will add 25-38mOhm, from 4.5V to 2.5V
Flashlights are only a realy small niche for li-ion batteries. Most of them are build for laptops and nowadays for e-bikes. They need unprotected and Panasonic, Sanyo, Sony, LG etc. built them.
AW, Redilast, Xtar and other brands build a protection and wrapped.
I think the Focal, BIC Sanyo and Panasonic batteries are genuine (the MarsFire have only the wrong mAh in the titel and the description). Manafont sell them, too (they do not name mAh):
Here is the 2A discharge curve for the first cell:
The charger monitor programm unfortunately crashed while discharging the second cell. So there is just a picture of the charger display. I twas discharged with 2A too:
The cells did match pretty good. But I think you have to discharge them down to 2,5V to get better mAh results.
I expected the difference of roughly 500mAh to be the result of not discharging them to 2.8v but to 3v.
But it might be a combination of the charger not charging them to 100% and showing a little to low results in discharging. So take the above discharge with a grain of salt.
I will get a better charger and we'll see. You can't do anything wrong with an iCharger 206B, right?
My set of batteries arrived yesterday. The good part I found was that they were genuine batteries with clear wrap and apperantly a PCB. The Kapton (or similar) tape and a bar under it runs from tail to head. The bad thing about these batteries were that they had stickers all around it. Had to remove the stickers with some penetrating oil to let them in some tightly fit bodies.
Anyway, I charged one with my XTAR WP2 II charger and made a discharge test with my Accucel 6 hobby charger @ 1A, the max current I could set. I must state here that I uses magnets for connection but they were between the clippers so the clipper could touch the battery directly. Therefore, having a small amount of connection resistance added to the circuit I set my Accucel 6 to NiMH discharge mode and down to a voltage of 2.3V.
The cell measured 3034mAh and the final voltage the charger reads were 2.3V. I didn't have a DMM with me but tried a second discharge cycle at 0.1A and the voltage was back at 3V.
My conclusion,
1. They are really above 3000 mAh, built well and has strong metal tabs at the both poles.
2. The circuit didn't seem to have cut at 3V on my sample
3. The circuit didn't seem to have cut at 2.5V either, but with some inline resistance the real voltage on the cell could be higher.
4. I still don't know if the circuit really works.
- I will try some further tests tonight, and this time I'll try to measure the real voltage on the cell.
