R95 in 3000K looks like a great value indeed!
I’d be curious to see a tint mixed R95+Optisolis in the low CCTs. There’s a small chance they may compliment one another in the blue/cyan region.
It appears there might be a slim possibility to adapt to automotive 12v applications… it seems not designed for 3v emitters in series…am i wrong?
Oh my…
Due to the orientation of the image of the MCPCB, I was reading those pad labels as “d” and “d/s”. I thought there was some cruel calculus joke going on (thinking d/dx). Nope… Those are probably “p” and “p/s” for parallel/series, huh?
The boards are still in the making, delivery schedule is 190515. Crash test will follow later. I still have no idea what is the maximum wattage this board can handle. Nothing fancy here, just normal good quality MCPCB.
I’m getting to like mid power LED these days. Spent few weeks designing the boards and browsing through hundreds of pages of data sheets for a project (that led to this VS35SP36). And as I dug deeper, I like the idea even more. I know the idea of high efficiency lighting is not widely appreciated in BLF but here’s my thoughts to share.
The beauty of mid power LEDs are: low power - low cost - high efficiency - power in numbers. Of course you can get the same output from a single XHP70.2 pushed very hard, but there’s no way you can get the efficiency (wattage/output, cost/module) of multiple mid power LED. I don’t see any benefit for manufacturers to use high power LED in general lighting unless smaller form factor is to be desired. Especially driven at below to max OEM rated current for reliable and predictable L70 life. This explains why more than 80% of Nichia’s LED sales come from low to mid power LEDs. I believe the same also applies to Cree and other manufacturers.
With high power LED, you can get slightly higher efficiency than mid power LED if they’re driven at the same low current. But what’s the point? At whooping 10x - 20x the cost? Development in high power LED is very similar to F1 racing. While mid power LED development is closer to 24 hours Le Mans racing. The latter has more real world applications. It would takes years before F1 technology applied to your public bus transport.
High power LED development from version 1 to version x doesn’t attract manufacturers to get the newest LED. For example the move from 319A to 319B, or XHP70 to XHP70.2 only gain marginal efficiency (within OEM spec), too small to think about for most luminaire manufacturers. Perhaps the most significant gain is the beam quality, not the efficiency. On the other hand, flashlighting is very similar to premium super car world. Anything faster or better, even those with decimal point advantages are still the better choice.
319B vs GR-V3 (both R70), 3000K, Target OTF output = 3500lm:
Nichia NF2W757GR-V3 R70 (6V)
Condition: 1400mA (116,67mA/LED), CC driver, 3S12P
Output = 3959 lm
Efficacy = 162 lm/watt
Wattage = 24,4 watt
LED# = 36pcs
LED cost* = $4,3
*$0,1176/pc @</=10.000pcs MOQ
Nichia NVSW319BT R70 (3V)
Output = 3914 lm
Efficacy = 179 lm/watt
Wattage = 21,5 watt
LED# = 73pcs
LED cost* = $59,86
*$0,82/pc @</=3500pcs MOQ
To get reasonable cost, we have to change existing driver to match 319B performance. To get at least the same efficacy as GR-V3, thus:
Condition: 5760mA (480mA/LED), CC driver, 3S12P
Output = 4017 lm
Wattage = 24,8 watt
LED# = 19pcs
LED cost* = $15,58
See? There’s no way high power LED will win over mid power LED in terms of cost or efficacy. And FYI, almost all higher current LED driver are more pricey than their lower current output counterparts.
With such low current and power density, GR-V3 can use any good cheap laminated MCPCB reliably. While 319B with its higher power density is about to enter the DTP zone or at least very good laminated MCPCB
[Clemence]
Can’t please everybody all at once. But don’t worry, I already made a design for linear 150mm x 15mm 757 MCPCB waiting to send to the factory.
I have no idea what this is
Don’t forget Optisolis higher Vf, can only be mixed in the series string
It can be configured to 3V or 9V with 3V LED. 6V or 18V with 6V LED, 12V or 36V with 12V LED
No, no calculus involved in the design, s = series, p = parallel, s/p = series or parallel
[Clemence]
Quite wide. Most LED strips are 8 mm. 10 mm is rarer but nevertheless well supported.
It’s not that finding a profile for a 15 mm PCB would be impossible but there are far fewer options.
Just ordered a host for one of these.
https://www.fasttech.com/p/9664958
Just need to change the lens and swap the driver.
Planning 36 4000k optisolis in parallel.
Is running a 7x7135+fet driver with a 30q battery OK?
Wait, is this an MCPCB for 3030 LEDs?
If so, I’m interested in getting 1pc for now, since I know what LEDs that I’ll be running
Yes it is.
And what are they? ?
Was talking about these:
https://www.mouser.ca/Optoelectronics/LED-Lighting/LED-Emitters/High-Power-LEDs-White/\_/N-8usfj?P=1yooj8k&Keyword=luminus&FS=True
UPDATE 190617:
5700K (18x sm503 rfc00 & 18x sm653 rfa00) Optisolis module (9v configuration) prepared for testing in Finland
[Clemence]
Excited for the test results!
Also, I see that this board is available in your shop now. Can we get these with pre-mounted emitters? And how about the R95 3000K ?
Got a test sample of the board populated with 5000K+6500K mixed Optisolis with 3S12P config. It’s beautiful, sunlight on a board. Haven’t tapped a heatsink for it yet but here it is at low power (500mA x ~8V).
Wow. Amazing stuff!
Maukka, what is the Duv value of direct sunlight? Isn’t it green-shifted a good bit?
Yes, sunlight would be at about duv 0.0030.
My jetusolis 5000K tint is pale creamy yellow (cooler hotspot) and the 6500K is (“was” as I lost it a few days ago) pale blue/cyan, how is the tint of the mix, maukka ?
could this be used in an 18650 flashlight ?.
6500+5000k mix?.
Optosolis Flooder?
I have a wizard pro 6500k. would consider an LED swap or new wizard pro with this if that would work as an EDC.
thanks
This is literally perfect! There is no cyan hole.
Im in on a blended 5k/6.5k quadtrix for my RRT-01
