First, you would need to swap in a new driver that was already setup with NarsilM. That’s pretty easy. The potential hard parts with the MF01 is if it’s not an early unit, it will probably be glued shut and very difficult to open. Secondly, the emitters will probably be set up at the wrong voltage requiring you to cut traces on the led board (mcpcb) and add jumper wires.
I would start by seeing if you can get the front bezel off your light.
You don’t list your location, but if your in Europe you might be able to ship it to Lexel for a conversion. Outside of Europe the shipping costs go way up.
BTW, do you know about the new MF01S It would be way cheaper to sell your current one and buy the new one since it already comes with many improvements. No NarsilM, but Anduril is based from it with nice ramping and user adjustable features.
Hi. I am new here and dont understand much about these custom drivers.
Probably this is right place to get new driver for my Convoy C8+. I need driver capable of moon mode, some regulated modes and turbo. Was thinking about BLF A6 driver, but there are only two mode groups which doesnt suit me much. I need something like this - moon, 1x7135, 8x7138, turbo. Or 1x7135, 8x7135, turbo. All without memory. Can it be done an how does it will cost to ship to EU? Need it to be plug and play, so I can solder only two wires. Thanks.
Bistro drivers like C8 can be user programmed for different mode groups, no memory like you want
Spring and wires can be added for some extra fee
I ship from Germany
The little leg on the MCU that controls the switch has a small positive “potential” on it. This needs to touch ground to complete the circuit and signal the MCU. You can run the positive wire from this leg or pad to the switch and then the return wire can go to any ground point you want. It can be on the driver or the flashlight body. There are many negative points on the driver, maybe even a dedicated pad for it.
PS, this is an old thread. New questions should go to the new Batch 7 thread.
