Xevious.
And that (unfortunately) is the way we all get experience.
Hopefully you won’t get caught again.
Just remember. TOP line knives. Damascus or otherwise.
Will start around $850 and up to multiple thousands.
Good. Mid range from a top name. $450 to $700.
Tojiro. Iseya and others that YOU have read up on and talked about.
“YOU Have, Haven’t you.
Will start at around $65/80 and go up through different models
to around $350 ISH.
You will NOT Get cheap. Chinese cooks knives like you do Folders.
(Size alone precludes that…) THAT ARE ANY GOOD EDGE WISE.
Hundreds of yrs of Blade Quality skills don’t come cheap.
Accept that ONE good “speshul” knife will cost you $350 to 600.
At your skill, experience levels.
Just hold and drool on every now and then.
No2 White Powder Carbon Steel will give you a good blade
for a half sensible price.
And get the Tojiro, Iseya. etc From the Upper end of the lower/Mid range blades around $65/230. for your daily use.
They WILL do a great job. And the likes of our blade skills.
WE will NEVER know the difference.
The Iseya are 1\2 a level UP on Tojiro. But NEED more care in handling.
But a LOT of pro Kitchens all over the world
Use and are happy with results from Tojiro DP Blades. and the models above.
Tojiro DP Petty Around $65 OR…
Iseya I ser, 33 layer Hammered $85ish.
Tojiro DP 7in Santoku $?? OR……
Iseya 33, Damascus Santoku $???
With Any comfortable feeling $20 Paring for now.
Look on net for Wusthof 8in Chef (Narrow blade) on special.
But any decent Euro blade form will do for that. I like the Brazilian one. (Mundial) but it is soft steel. Wears quick. Feels good.
Look in Hocho for prices PLUS freight added.
And…. I think a local Meatworks supplier would be best for a 10/11in Butchers knife for any heavy work.
Good blade, cheap price for minimal usage.
I’m a few yrs out of touch with pricing nowadays
hence the Look??.
$200ish will get you a basic. usable couple with parer,
with another $40/50 for meatworks blade.
THEN… Start saving for the Drool item/s.
A lot depends on your income.
Working I was on $2.500ish a week plus tonnage,
Nowadays, OLD age Pension.
Slows you down a bit once you spent it all hey.
Yeah, I hear you. Sad thing is, this seller has 100% positive feedback and over 20,000 transactions. There must be a lot of naive buyers out there. This was his response: “we are really sorry about the inconvenience you had as these minor scratches should not be there, as far as those spots are concerned which are called ball spots are due to forging, Damascus steel is alloy or carbon and steel which forged into layers and some of the time it happens, this is true Damascus and not etched, we have been selling for over ten years and have more than 20000 feedback.”
But there’s no sign of Damascus pattern on the bald spots, in addition to no smooth transition there—it’s a sharp cut off. Plus, the back side of the exposed blade shows no pattern either (I looked up close with a 30x magnifier).
The seller (damascus007) listed the auction as no returns, but is offering me a 40% discount or a return. I’m going to return it. When there’s a return, there’s no feedback. So maybe that’s how he escapes the criticism (since if he refused, there would be negative feedback due to the deception).
I’d be curious to know if you’re able to look directly at his auctions and see for yourself if it’s possible to ascertain that his claims are true, or he’s peddling a massive scam.
Anyway, I appreciate all the details you provide, though overwhelming. I do realize that you have to pay many hundreds to get really good quality Damascus steel blades. My hope was to get a mediocre example that is at least the simulated Damascus steel by process, not by faux surface etching. But in the end… I think I’ll let go of this. The “white powder carbon steel” sounds more interesting and within a more practical budget. Where do you suggest looking on-line?
UPDATE: Interesting that the seller issued me a refund and stated “please cut the blade part right from the centre and see it’s genuine or not, we are not the trader it’s our family business for the last 40 years and we never sell anything fake and offer money back guarantee on our products.”
So I made another pass at examining the knife up close. I did find a consistency of pattern from one side of the blade, across the top, and to the other side. No “flawed” match of pattern. On the back end of the knife, what seemed devoid of pattern with the naked eye revealed that there is a pattern there. It’s just most of it was covered up from the grinding. But it was uneven, so I could see the layered steel pattern within it.
Thus… it looks like this may actually be some primitive, rough form of Damascus styled steel. And that bald spot was just an unlucky happenstance of unfolded steel in the mix. That’s what I can perceive from the examination. This seller must not have a very good command of the language, as he could have tried to explain things better.
UPDATE #2: Rather than wiping out everything here, I just wanted to point out that the seller gave me a full refund and told me to keep the knife (“too expensive to mail back”). With the cosmetic fault, he’d probably not be able to resell it anyway, so it wouldn’t make sense to send back as it is. I wonder if there’s something I could do to the back end of the knife to help get the rest of the Damascus lines to come through?
@ Macka17 & Xevious
Devin Thomas / Among the best in the world (and there ain't many)
, absolutely top notch.
Brad Vice / Very, very good.
What is “No2 White Powder Carbon Steel”? I cannot find any information about it by that name.
Is the “White 2” I have listed below what you are referring to Macka17?
Thanks in advance…. :+1:
White 2 Steel / Composition And Reference Data
Composition
- C: 0.95-1.05;
- Cr: 0.20-0.50;
- Mn: 0.00-0.50;
- Ni: 0.70-1.30;
- P: 0.00-0.03;
- S: 0.00-0.03;
- Si: 0.00-0.35;
Maker: Takefu - Japan (JP)
Notes:
White 2 - Takefu steel.
According to them, Shiro2 is their most popular cutting steel. Shiro2 is not Shirogami 2 steel, even though sometimes Shirogami 2 is referred as Shiro2. Whenever you see the abbreviation, it is most likely referring to Hitachi Shirogami 2 steel, not Takefu Shiro2.
Cross-References:
- none
Known Aliases:
- Shiro2
Good to know, although price points are probably beyond my budget. Devin Thomas doesn’t have any current products listed for sale on his site. But wow, the gallery! I had no idea such Damascus steel patterns were possible. And that’s all from folding steel in specialized ways?
Shirogami = white steel, aogami = blue steel also called white paper steel and blue paper steel based on the color of the paper they are (or were traditionally) wrapped in if i’m not wrong.
I have a small Spyderco Caly 3 super blue (aogami) and it’s a nice carbon steel (not stainless).
Yeah, I think Devin Thomas mostly makes Damascus now to supply other makers. He is a master at Damascus. I thought you might find it interesting reading.
Brad Vice’s shop is only about 20 miles from where I live.
Yep, using different steels forge welded together, folded, & folded some more. There are special methods used to create the different patterns.
The blade is then profiled, ground, heat treated, & sharpened.
Then it is all etched in a solution that reacts a bit differently with each steel used. That is what ‘brings out’ the pattern.
‘Touch up edge’ again after etching.
Yes indeed, I did! I’m fascinated. I had no idea such patterns could be achieved. I think I’ve found a “holy grail” for a future purchase. Will have to save up.
That’s great you’re so close to Brad Vice’s shop. Does he accept customer walk-ins? That’d be great if you can get to know him and get to see his projects.
Thanks Tally-ho, you hit the nail on the head. :+1: …. Seems there are many other ‘terms’ that refer to the same steels you referenced.
https://www.thebestthings.com/newtools/japanese_steel.htm
Japanese Blue and White Steel
The most widely available Japanese tool steel is manufactured in two forms: blue steel and white steel – named for the color of the wrapping paper used by the maker. Knowledge of these two form’s chemical content and tempering process allow the woodworker considering Japanese edge tools to make some tradeoff between hardness and toughness in the blade’s edge qualities. Hardness means the temper and content of the metal is such that the blade can be sharpened to a very fine degree but results in a somewhat brittle edge prone to chipping or crumbling. Toughness refers to the ability of the edge to avoid damage, and thus stay sharp longer.
Blue steel, or Aogami, has tungsten and chromium alloys added to the edge steel that make the hardening temperature less important, resulting in an edge that tends to be tougher, and thus stay sharp longer than white steel, while not taking on as fine an edge.
White steel, or Shirogami, contains fewer impurities and does not have the alloys added, so the hardening temperature range is very narrow. The blacksmith forging white steel has to be very skilled, but the result is tool steel that can be sharpened to a very fine, but more brittle, edge. Both forms are further broken down into grades based on the carbon content of the steel.
The better Japanese blades are laminated by hammer welding the edge steel onto an iron or softer carbon steel core, the actual process proprietary to each blacksmith. So, while there is science in the forging, hammering, heat treating and tempering processes, more than anything else the quality of the steel is the result of the care and skill of the blacksmith.
These are family run businesses that trace their lineage back to the edged weapon makers to the samurai and it takes 10-15 years at minimum to perfect the craft. Considering this learning curve, it is no small wonder that Japanese blue and white steel blades made by traditional methods are superior to machine manufactured products.
When trying to decide which blade to buy in a Japanese tool you should bear in mind the difference between blue steel, white steel, or the exemplary special process steels like Damascus is not one of quality.
There is a wide range of qualities available in both types of steel, and in the chisels made with from these steels. You can get acceptable toughness in very hard white steel chisels while taking advantage of that form’s ability to yield a very sharp edge; or you can get a quality blue steel blade that can be honed and sharpened very finely.
And of course it is quite easy to get neither hardness nor toughness in a sub-standard steel blade, blue or white, from an inept or sloppy manufacturer.
The chisels that we are offering are all at the higher end of what is available. It really boils down to the quality of the steel and the skill and care of the blacksmith. So, consider the edge qualities you want in a chisel and buy your Japanese edge tools from a trusted source. Either form of steel in a quality tool will yield outstanding results.
Simply put.
White steel is iron, carbon and not much else.
Blue steel is iron, carbon, tungsten and chromium.
White steel can and will take a finer, sharper edge, is generally tougher and more resilient, easier to work with during manufacture, less expensive and is, in most cases, the best steel for chisels, especially chisels that will be struck during use.
Blue steel will take a very good edge and keep an edge for longer than white steel can in planing and paring cuts. Because of the added alloying elements, it’s a little more brittle, is slightly more difficult to work with during manufacture, slightly more expensive and is ideal for planes and paring chisels.
This is not the be all and end all ‘rule’, as there is some cross over between the steels and a blue steel chisel can be a wonderful thing, as can a white steel plane stay sharp for a very long time. But as a general ‘rule’, this covers it with some exceptions for special circumstances.
The ‘sharpest edge’ doesn’t mean anything if you can’t actually get the edge there though…
Sooo, white steel is easier to sharpen and is ‘more likely’ to have a better edge put on it because of that. If you’re able to confidently put an excellent edge on white steel, then blue steel shouldn’t be a problem.
I hope that helps,
Stu.
Good, I’m glad you found the reading interesting & enjoyed the pictures you found.
Yeah, it is pretty amazing the patterns they can acheive. I am awestruck with most of it.
Brad Vices shop (Alabama Damascus) is only about a quarter mile from Bear & Son Cutlery . He supplies Bear with their Damascus in addition to supplying other outlets & his internet sales.
I do know Brad, having met him through a friend who is a Custom Knife maker. He is a nice & personable guy.
I have been to his shop when they were forging. It is pretty neat seeing those Damascus billets being forged on those huge power hammers. . :+1:
Hey Stu, just a little confused here. In the first section it says white steel is more brittle, while blue steel is tougher. Yet in second section, says blue steel is more brittle… :question:
“Stu” must have been drinking.
Those were copied & pasted from the site the links go to. I’d trust the first one. The second one was from a forum… so who knows. .
It could just be a ditterence of opinon or based on heat treat & Rockwell hardness differences or other variables.
It’s just like the search for the “Magical Search for the Super Steel” that tops all others……
The vast majority of people will not be able to tell the difference.
Any good steel, if ground & heat treated properly; is going to cut very good. It is also much better to have a “lesser steel” properly heat treater than a ‘Super Steel’ that is not.
I have some Customs made of 1095 that are heat treated perfectly that out do some ‘Super Steels’ where the heat treat was not quite up to par. Close mind you, but it missed the mark.
Here are some videos I thought you might find interesting….
A couple more about Alabama Damascus……
This one by Ed Caffrey is about etching Damascus & is good. Very detailed though.
I am acquainted with Ed, he is a Bladesmith from Great Falls, Montana & a super nice guy. He makes his own Damascus as well as a great knife too. They ain’t cheap either……
Unfortunately, due to serious health issues Ed has had to take some time off for a while.
^ thanks @teacher, lots of good info in that.
^ thanks @teacher, lots of good info in that. :+1:
Your welcome xevious, I enjoyed watching those & thought you might also. Take care…
Thank’s Teacher. Tally Ho.
and all the rest of you.
As shown. it is a VERY interesting subject. with lots of variations.
Sorry I haven’t answered but I have gud days and bad days.
Hmmm.
“”Shirogami = white steel, aogami = blue steel also called white paper steel and blue paper steel based on the color of the paper they are (or were traditionally) wrapped in if i’m not wrong.“”
As I said in beginning. Steels do vary.
BUT… It’s the experience and skills of smith that makes any what it is.
Good steel/bad blade. or Cheaper steel Good blade.
Hocho, and several others will give all the info you need.
And. Realistically.
Hocho usually the cheaper for same blades. It does vary with specials though.
In your price range. Iseya 33 damascus. 6 in Petty.
VERY nice blade I love mine. $75 now.
Tojiro DP 3 layer VG10. 7in Santoku. $91
A LOT of pro’s use it and it’s smaller mate around the world.
Sharpens well. Cuts well and stainless.
Iseya 33 dam, same knife different tip shape. $125
A little dearer. but very pretty.
The smooth damascus ARE prettier than the hammered but.
Your eyes.
I’m only going on blades “I’ve” owned personally, Have Used and felt a lot more.
Plus multiple Mates have many others.
Coupla grand a blade is nothing if you appreciate such. But I wasn’t a good enough cutter , handler. To Appreciate such.
I Just appreciated at my skill?? level.
(I’d fuck a good one real quick.)
$200ish will buy you a NIIIce coupla blades in your financial level.
and they soooo smooth cutting.
Learn to hold a knife and present BACKS of knuckles only.
NO TIPS>of pinkies.
But get a bottle of Single Malt. coupla bars of dark chocolate.
and settle in for a loooong read. plus many YouTube video’s.
You are entering a different world compared to Western blades.
Anther little carbon NON stainless I play with. “Tojiro Japanese-Style Shirogami White Steel Aji-Kiri 105mm. Around $65 US on sale. plus freight from Japan.
6 in Petty $73.
Hammered 7in Santoku $125.
But I reckon their 7in smooth at $133 is a nicer blade??.
Here we go. Choices again.
and these just the cheaper models. My level.
wait till you see some of the real ones… (You’ll crack a hard just perusing them (chuckle)
Have fun.
Then go back to the folders for a little wallet relief hey.
NO TIPS>of pinkies.
Wait… what?
Hmm, I like the way you think. Dark b33r instead of scotch for me, though. I’ve been trying various types of “hard” liquor… to me it all tastes like jet-A.
Unno, all I got are my trusty Wüsthof sudoku blade and Choinese cleaver to keep me busy. No idea if it’s made of that origami metal or the other one. It just works.
I’d probably pick up something made from Chinese Mystery Metal, with my luck.
And stiiiiiiiiiill waiting for my go,comma blades…
Post a picture of the complete knife, both sides.
Then post a picture(s) of the “backend of the knife” you are referring to.
Yes, there is something you can do to bring out the pattern. Post those pictures so I can see where you are talking about & we’ll come up with a plan.
