Simon, just so you know, Richard at MTN Electronics has designed a Boost driver that works with one or two cells and delivers 2.3A to the XHP-35. This is good for over 2000 lumens in your C8+. Perhaps you should work out a deal with Richard?
For what it’s worth, this same driver of Richards also excels in the L2, amazing lights these 2!
I put a 3v XHP50.2 in my L2 @12A (single cell). it’s a nice light, easy to focus. just guesstimating by eye, CD is a little higher than stock, but quadruple the lumens.
About the anodizing, my l2 came like it was wrapped in sandpaper compared to the super smooth ano from the S2+’s
I don’t know of available drivers that will supply the optimum current to the XHP-35 as far as Banggood or even on Aliexpress. The drivers I have used are from members of this forum. One in the US and one overseas. LED4Power’s drivers can be configured to use 4 cells to power the 35, these require extension tubes on the L2 to allow the use of 4 26650’s or a normal 2 cell tube set-up can make use of 26350’s with shorter run times. The US made Boost driver can use one or two cells to power the 35 to 2.3A or so, these are the more expensive but more compact option. This latter comes from Richard at MTNElectronics.
Is there an L2 extension tube available separately? I’ve seen pictures of an L2 that comes with one that looks like it’d screw into the L2/L6:
Asking because I just got an L6 and it’s great, but surprisingly it’s smaller than I’d hoped for. Would love to be able to add an extension tube or two and swap the driver for a 3S or 4S one to have a proper maglite form-factor replacement with modern internals!
Hello Simon!! apart from keeping our pockets empty LOL, is there an interest from your behalf of making a helmet light for mtb or mounted on the front of a bike, thanks!!
