Fireflies E07 preview
2069 posts / 0 new
timbo114
timbo114's picture
Last seen: 1 week 3 days ago
Chatika vas Paus wrote:
Indeed! I didn’t know it’s a battery indicator.
But I noticed that my “HOT” is not in the middle. Perfectionist’s hell. Angry
Black it out with a sharpie so it doesn’t stare you in the face all the time.
You can always wipe off the sharpie later …
gpbeiew
Last seen: 4 weeks 1 day ago
alex64 wrote:
Anyone know the N times default config for Floor and Ceiling Cfg? I have changed it and now the Ceil it’s almost the same to the turbo.
Default ceiling is 120 (click 31 times after prompt). Max ceiling (= turbo) is 150 (1 click after prompt). Not sure what level default floor is set to, but lowest possible setting is 1 click after prompt.
alex64
alex64's picture
Last seen: 3 hours 12 min ago
Thank you, I’ll try it.
Incognito
Last seen: 1 year 9 months ago
What’s the recommended “Temperature limit” setting?
alex64
alex64's picture
Incognito wrote:
What's the recommended "Temperature limit" setting?
For me 50º. Always with the calibrated sensor.
Another question, in Muggle mode at 4 seconds always stepdown to low, is there any chance of changing it?
mattadores
mattadores's picture
Last seen: 10 months 2 weeks ago
Can anyone help with this issue?
I received my Fireflies E07 Friday of last week and it has a strange issue that my Fireflies PL47 has never had:
I will take a video to show you what’s happening but when I ramp up to the top of the ramp (not turbo) the light flickers very heavily and rapidly once it reaches the top of the ramp. This happens if I keep holding the button or if I release the button as soon as it reaches the top of the ramp. The flickering happens most of the time and can last anywhere from 2 – 10 seconds.
It also happens if I save the top of the ramp setting as the memory setting and turn the light off then on again.
Like I said, my PL47 doesn’t have this issue and is totally stable once it reaches the top of the ramp
mortuus
mortuus's picture
Last seen: 2 hours 4 min ago
hm weird… what battery do u use ?
make sure the head is tight screwed if its a bit loose it could explain the flickering maybe or idk ?
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
contactcr
Last seen: 2 hours 37 min ago
Get some 80-90% alcohol and clean any copper parts or non anodized metal (driver ring, tail pcb ring, springs, battery tube ends and finally your battery + and – terminal)
fluke
Last seen: 2 months 4 weeks ago
xevious wrote:
fluke wrote:
Works on Firefox.
Have you check (ALL) check  box options?
Including Accessories? IE: None?
Thanks. I'll have to re-check that. You'd think that any required fields would be highlighted if not selected, rather than simply preventing the "Add to Cart" button from functioning.
Took me ages to work out i had not checked the No/None accessories.
Juls Boo
Juls Boo's picture
I receveid my E07 from fireflies webshop, clear anodize, Nichia 219B
Everything is perfect, it’s now my favorite flashlight.
I already have a ROT66 and PL47, everything buy from fireflies website and with Nichia 219B
Nichia 219B is my all time favorite LED for long exposure photography (light painting), it’s great to have 3 flashlights with the same LEDs
Juls Boo / LIGht HunTer
juls boo
Light Painting GIF done with various light. More here [ https://ello.co/julsboo ]
contactcr
Just curious if you compare the 219B tint from this one to your older purchases do they look the same?
Juls Boo
Juls Boo's picture
Looks the same to me with this rosy tint
juls boo
mattadores
Thanks… cleaned it all and it turned out to be the female tailcap. basically turned a tissue jet black after cleaning and she’s functioning tip top now.
Still.. I’m kind of surprised I had to thoroughly clean my 3 day old light… lol
contactcr
It’s pretty easy to transfer stuff to/from batteries, your fingers, grease from threads, oxidation, etc. Your other lights might be dirty too and if they are lower power or different type of driver the problem could manifest itself differently or not at all. I just clean them no matter what. Some people also re-do the grease or apply a thin layer or stuff like this:
https://www.illumn.com/miscellaneous/no-ox-id-a-special-electrical-grade...
KevinZA1988
KevinZA1988's picture
Last seen: 9 hours 46 min ago
I received my EO7 today and noticed something strange. Only two of the aux LED’s on the switch is on. Why is this? See pictures. Help would be appreciated!
https://photos.app.goo.gl/y8GtWR2uJKs6C8Xp9
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Emisar D4, Fireflies E07, Jaxman E2L, Manker MC13, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II.
Most of them have been modded! =)
https://photos.app.goo.gl/JaJaDv4V838AEJf39
contactcr
If the light was ON during the picture that is how it's supposed to work.
If the light was OFF do this (there is no low/high, only high/off I think):
Aux LEDs / Button LEDs
Some lights have aux LEDs or button LEDs.  These can be configured to do
different things while the main emitters are off.  There is one aux LED
mode for the regular "off" mode, and another aux LED mode for "lockout"
mode.  This allows the user to see at a glance whether the light is
locked.
Aux LED modes typically include:
  - Off
  - Low
  - High
  - Blinking
To configure the aux LEDs, go to the mode you want to configure and then
click the button a few times:
  - Off mode: 7 clicks.
  - Lockout mode: 3 clicks.
This should change the aux LEDs to the next mode supported on this
light.
For lights with a button LED, the button LED typically stays on while
the main emitters are on.  Its brightness level is set in a way which
mirrors the main LED -- off, low, or high.
For lights with front-facing aux LEDs, the aux LEDs typically stay off
when the main emitters are on, and when the light is otherwise awake.
The aux LEDs on most lights only turn on when the light is asleep.
KevinZA1988
contactcr wrote:
If the light was ON during the picture that is how it’s supposed to work.
mode for the regular “off” mode, and another aux LED mode for “lockout”
locked.
– Off – Low – High – Blinking
- Off mode: 7 clicks. – Lockout mode: 3 clicks.
light.
mirrors the main LED — off, low, or high.
The light was off in the picture. When I turn the light on, the aux/switch LED’s turn off. There’s only an on/blinking/off option in the settings. Only two LED’s on the switch. https://photos.app.goo.gl/adtzmA91pPf58etz5
There’s a picture of the light when on and the UI sheet that came with the light.
contactcr
If 7 clicks while off doesn’t fix it then it’s probably a wire has come loose
KevinZA1988
Do you know if the driver is glued? I don’t see a retaining ring…
Just my rotten luck.
koziy
Anybody here place an order recently and get DHL shipping? How long did it take before the tracking number was active?
I selected DHL, and got a shipping confirmation the day after I placed the order, but after 2 days, it’s still not trackable. The DHL tracking number is also different from other DHL tracking numbers I’m familiar with; it has the format “L##########D,” but usually they are just numbers, I think. Since DHL Express is a 2-3 day service from other countries, it seems like it should be at least trackable by now. Is it a Chinese holiday?
Edit: OK, so today I got a text message from DHL informing me that a package was just sent. Totally different tracking number, although it is the same package. I placed the order Sunday night, got the shipping confirmation Monday afternoon, and it’s now Thursday.
ichoderso
ichoderso's picture
Last seen: 1 month 5 days ago
have published some pictures in the german forum:
https://www.taschenlampen-forum.de/threads/fireflies-e07-21700er-7x-emit...
Nite Shadow
Nite Shadow's picture
Last seen: 1 week 11 hours ago
It seems that you can only view the thumbnails unless you are a member of TLF. Can you just post here too?
koziy
OK, just posting an update. It’s Tuesday, April 16th, I got my E07 a little earlier, and as of right now, it looks good, appears to function normally, and has no obvious flaws with aux LEDs, as others have reported. I ordered it when the website said it was the second production run. The QC stamp on the box is dated February 15, 2019. I have no way to confirm if it has the correct amount of thermal paste and don’t feel like unscrewing it at the moment. Overall, I really like it. This has the Nichia 219b emitters. Very nice amount and quality of light. Edit: Just played with it in the back yard at night and WOW, what a beautiful effect that pinkish tint has on the budding trees this time of season. Lots of heat generated very quickly, though. I spent about 20 minutes playing with the dog, shining the light into the woods on turbo periodically, and when I came in, the battery was at 4.1 volts, which seems pretty good to me.
It took a total of 8 days from order to when I should have received it (there was one extra day because the DHL driver had it on his truck yesterday but didn’t drop it off until today), which is a good turnaround. In reference to my comment above, the initial tracking number that Jacky sent out, which had the format “L########D” was in fact on the inner box, but DHL also gave the package a second tracking number, attached to a plastic wrapper around that box, which I didn’t get until I started getting SMS updates about tracking. I assume that the first tracking number is internal to China, since it was useless for DHL’s international site.
Ekstasis
For the new updated version they should add usb c charging, this should be standard..cant be that expensive to add ?
I gladly pay 10 dollars extra for it
SKV89
Last seen: 1 day 1 hour ago
Ekstasis wrote:
For the new updated version they should add usb c charging, this should be standard..cant be that expensive to add ? I gladly pay 10 dollars extra for it
I would pay 15 extra for USB charge version. Would be eve. Better if it can function as power bank like the TO56R or Rofis MR50, MR30. Great for taking on trips
teacher
teacher's picture
Not me… I think USB charging on the E07 would royally screw up a great light. I hope FireFlies leaves the E07 as is with no USB charging….. ever.
The size it is now is perfect.
BlueSwordM
BlueSwordM's picture
Last seen: 3 days 18 hours ago
I mean, this does exist with USB type C charging:
http://budgetlightforum.com/node/66341
SKV89
teacher wrote:
Not me… I think USB charging on the E07 would royally screw up a great light. I hope FireFlies leaves the E07 as is with no USB charging….. ever. The size it is now is perfect.
Just because you dont want it, dont ruin it for others who see it as a useful feature. Choices are always good for consumers.
Agro
Agro's picture
Last seen: 2 min 8 sec ago
I came to like cells that feature charging (and sometimes even powerbank). Buy 1 cell like that and you can upgrade many lights…
…but that works only for lights that support protected cells. And E07 is not one of them.
And it doesn’t wor perfectly for super hot rods – because these cells don’t tend to be high discharge ones. And E07 is one of them…
teacher
teacher's picture
Thumbs Up .. I understand that, it’s just my opinion on the matter. Just as your preference is yours.
I could say the same thing to you…. Just because you want it, don’t ruin it for others who see it as a useless feature that is not wanted in most lights. Consumers appreciate functional simplicity more than unneeded or unwanted bells & whistles.
See what I did there??…. Neither one of us is right, or wrong; completely.
It is simply “our individual opinions”.
