Just received mine,build quality seems ok,threads smooth and lubed,reflector OP similar to L6,anodising shiny black,not sure about UI yet,ceiling bounce a fair bit brighter than L6,will check out later when fully dark.
The texture on the reflector should be very light. The L6, the xhp70 one, had a heavy texture. I hope Sofirn got it right.
Yours is shiny black? I though they would all be matte black.
Yea they should be matte not shiny and have a slightly OP reflector. The L6 is less OP than the S70 so maybe this reflector is similiar to the L6?
This is the issue if no one gets sent an engineering sample to check.
Shiny black compared to the L6, about the same as BLF Q8 and the OP is only slightly less OP than L6.
For anyone interested, I have published the approved manual for Sofirn's SP70 on my sharepoint, both in English and German language.
Please click ►►►here◄◄◄
In looking over the manual and the OP, didn't notice details on the LED.
Back here Jason wasn't sure, but thinks it went out as 6000K-6500K: https://budgetlightforum.com/t/-/52135/1728, but still we don't know the bin?
Do we ever get output bins from manufacturers?, and if we do get them are they correct, and are we able to check them?
That’s all information I have received from Sofirn, so far. I asked them if their numbers may be worth being updated since JasonWW got much better results with those 26650 batteries Sofirn has apparently provided for testing the SP70 prototype. But they didn’t want the numbers in the ANSI chart to be changed. I don’t remember the exact post here on BLF but I was told the numbers in the manual result from testing with 18650 batteries. Eventually, we need to wait and see what actual numbers people will measure once they get their SP70s.
Sometimes. We sure got it on the Q8, after great insistence of course. Just wish'n, just say'n. If we know, that's good, if we don't, that's typical.
I'm mostly worried about their driver. I can't remember where/which lights, but I seem to recall some of Sofirn's drivers being subpar on efficiency and/or standby drain. I guess standby drain isn't as big an issue on a light with a rear lockout switch. I just hope it's not a light where I feel like I want to mod the driver first thing, because then I start wondering why I didn't build another L6.
We don’t know the exact bin.
I haven’t been able to test anything because I don’t have the light. Sofirn has tested a variety of batteries, though. I believe their 5500 lumen rating is using their low drain 26650 batteries. I’m guessing they need to sell more of their low drain cells. When they tested using their 21700 and HD 26650 they got the higher lumen numbers.
I think its a safety issue for non flashlight people and Sofirn are concerned? Using high drain cells is probably not recommended for every one. Lots of 26650s are not suitable to be used in series where as most brand name 18650s will have no issues.
Check out HKJs charts and heaps of pair of 26650 don’t match which can be an issue. At what point does it become an issue? Well for some novice that may only charge cells when they are flat its a bit of a worry where as we probably charge our cells more often.
I’m mostly worried about their driver. I can’t remember where/which lights, but I seem to recall some of Sofirn’s drivers being subpar on efficiency and/or standby drain. I guess standby drain isn’t as big an issue on a light with a rear lockout switch. I just hope it’s not a light where I feel like I want to mod the driver first thing, because then I start wondering why I didn’t build another L6.
The S70S had a really high drain of 4.43 milliamps. I don’t think the mcu went to sleep. Plus the green led was an inefficient one that needed more current than some other green leds.
That was a linear driver of some kind. On their C8F, which is a FET driver, they got the drain down to 77 microamps. Much, much better, but it’s not using a constant on led like the SP70. So I hope the SP70 drain is under 400 microamps. Under 200 would be even better. I’m not too worried about it though. For storage I would cut the main power.
There is review in youtube.
This was posted and talked about a couple pages back.
Thanks for the video Tangra, I guess I missed it when it was posted before.
It’s sweeps week…
I just sweeps once a month……
OMG! I was supposed to SWEEP?
I thought she said sleep…
