Not me… I think USB charging on the E07 would royally screw up a great light. I hope FireFlies leaves the E07 as is with no USB charging…… ever.
The size it is now is perfect.
I came to like cells that feature charging (and sometimes even powerbank). Buy 1 cell like that and you can upgrade many lights…
…but that works only for lights that support protected cells. And E07 is not one of them.
And it doesn’t wor perfectly for super hot rods - because these cells don’t tend to be high discharge ones. And E07 is one of them…
:+1: … I understand that, it’s just my opinion on the matter. Just as your preference is yours.
I could say the same thing to you…. Just because you want it, don’t ruin it for others who see it as a useless feature that is not wanted in most lights. Consumers appreciate functional simplicity more than unneeded or unwanted bells & whistles.
See what I did there??…. Neither one of us is right, or wrong; completely.
It is simply “our individual opinions”.
No it is completely not the same. You are telling them not to create a usb alternative when there is already a non usb version. There does not exist a usb version for those who want one. We want the option to buy a usb version which is none of your business if you dont want one. Why dont you just go buy the non usb version and be happy?
I have no problem at all if they want to create another version of the E07 that has USB & whatever else. (Call it the ’E07-b&w’ maybe)
But that is not what Ekstasis asked for. He asked for a new updated version. That would take away our choice to buy more E07’s without USB, which many consumers consider a useless/unneeded feature in a light. I am proudly one of those consumers.
And so because someone wants something they should have it? Regardless of the inherent danger? The Emisar lights have a focus on ultimate performance in a compact structure, the entire design concept leaves no room for the charging circuit being asked for nor the likely ensuing loss of performance. It is not so much WE should be happy to “mind our own business” as it is we should help protect muggles that do not know what they are doing. Cells such as the high discharge non- protected 21700’s this light is designed to use should be charged outside of the light, carefully monitored to preserve a safety margin the users life may well depend on. Li-ion safety is extremely important, one major incident where poor design costs lives could impact us all in ways we’d truly hate to see.
My vote, my experience, goes with no built in charger for ANY light, you want easy stay in elementary school. Life, and it’s inherent pursuits, is not easy.
And of course, that’s my opinion and you are welcome to it.
Yeah, I’d like to see E07 with usb charger, but I get that E07 is too small/compact to accommodate usb charging. That’s why I’m looking forward to Astrolux MF01 mini.
This is plain wrong as muggle will buy a flashlight with a battery OR forget to buy a battery and complain about it later (that flashlight was sold without battery). He will most likely buy some YourHouseOn*Fire* brand with 9000 mAh and cheapest wall/usb battery charger. I did not see the picture of “2 bay 21700 / 18650 charger” FF sells as an optional accessory to E07, but I highly doubt that it is in any way better than usual in-flashlight charger.
No USB for me. Please keep the USB OUT of the discussion..
the light had already many problems we don't need to create a new one. Not to mention the water proof issue this one alone can make. And this can make it completely useless light
Charging in or out the light is not just about easy vs. hard. For me it’s more about convenient vs. inconvenient. In this case I actually prefer the inconvenient way….but that’s only because it’s cheaper and available. If the cost difference was marginal and lights with built-in powerbanks were abundant - I’d clearly prefer built-in. And I actually fail to see why one would prefer hard for the sake of hard unless improving skills was a goal by itself. Which doesn’t seem to be the case.
And I’d say that built-in is the safer way. It can prevent many kinds of user misuse, both caused by lack of education (inserting a cell the wrong way) and not (mishandling).
I disagree. I believe it is far more dangerous to give muggles a lithium ion cell light because the likelihood of them charging the cell in a non compatible charger is far higher than a built in usb charger causing explosion. In fact I dont think anyone here has heard of a flashlight with built-in charging exploding.
Yes, I think pipe bomb. It takes a lot to turn flashlight into one:
I believe there were some later tests with similar conclusions.
Merely shorting one while disabling thermal protection is not enough to cause problems.
Similarly use of a weak and used but gnerally OK quality cell - you’ll just get less current and may wear the cell much faster than usual.
So you believe in making a muggle safe gun instead of training the muggle?
Do you not see an inherent problem in the fact that even a cheap single bay charger is $5-7 while the built in charging circuit is pennies worth? Quality, at $0.30? And you’ve never seen a cell vent? Ever? Sorry bud, but it happens and it’s freaky even in a proper charging environment, possibly deadly encased in an aircraft aluminum tube.
The odds, think of the odds. It will happen at some point that a charger overcharges when left alone to charge, and in todays ever more populated environment it could well happen that when it does many many people will be affected. Plug it in and leave it, that’s what everyone wants to do, and that’s fine while everything is in top working order, but one little component goes wrong and the cell overcharges, it heats up, it vents… then what? Not YOUR light, but the guy in the same building several rooms over, or several floors away, and suddenly you’re evacuating because someone else bought a cheap a$$ light and left plugged into the wall… or maybe it’s your mom getting smoke inhalation and an extended hospital stay due to that guy… but it does happen, and sooner or later it will happen to you. Keep muggles, muggles… or educate them and attempt to eliminate the potential for massive problems?
The vape folks are seeing it more and more, and they will get our li-ion cells regulated beyond purchase soon enough that we probably won’t have to worry about this discussion.
One test, one result. Multiply it by a million and see how many results you get… the combination of variables is beyond imagination. Murphy’s law prevails. How many li-ion fires in the underbellies of Airplanes did it take to cause us grief? No flashlight even involved. The cells are extremely powerful, the possibilities nearly endless. Proceed with caution or be prepared to pay a price.
