Good charger Garry. I was wondering about the low charge rate (650ma) for 26650 as well. The specs for the Knot Top battery list charge rate as <= 1a. So I guess it's ok to use the Xtar to charge it.
Thanks for the tip, jonhobart! My Knot Top 26650 came today (probably 3 weeks ahead of my new single bay 26650 charger) and the nickel and dime approach worked, but it took a really long time at 1A charge rate. If you have them, 1 or 2 rare earth magnets on top work even better. I don't think nickel is a very good conductor of electricity.
By the way, I bought the TrustFail specifically to charge 26650 batteries and what a piece of junk it is. I still like it however, because it only charges to 4.18 volts. The Solarforce on the left consistantly charges to 4.24.
When charging 14500, Foy struts his engineering prowess thus . . .
Adjustable charge rate of 100-1200ma, full cc/cv control, thermal protection, input voltage of 5-12VDC. This is what I will be using with 26650's, the bigger the cell, the more important to have a safe charge protocol.
From a quick bit of research on a few sites it runs on 110 to 240 volt 50 to 60 HZ comes with a USA power cord but the cord is separate from the charger and easily swapped out for an AU or EU cord from a laptop power supply or old printer, DVD or stereo power cord i have a few spares so its not big deal for me and they are cheap.
It will only charge at 1.5 amps so only really only suited for charging big cells like the 26650/25500/26700 batteries and maybe high end 18650,s like redilast, aw's and Panasonic's 3100's as an example. but 1.5 amp is good for a 4000 + mAh 26650 li-ion cell.
Here is how i charge my 26650's with my Icharger 106b+ i can charge 1 through to 6 at a time and i balance charge them like my lipo,s and 18650,s, but i only have 3 x 26650,s right now with more on the way.
DArn it, I have a hyperion EOS0606i that I intend using, however I have no idea how to find the correct pin outs for the balance cable, so I'm stuck charging 1 battery at a time
Well you will need hyperion balance leads if thats what you intest on doing ? but hyperions leads are rare or not cheap, what i would do is buy one of these
Then just buy the cheap JST-XH balance leads from 2s to 6s depending on how many you want to charge at one time and pick your magnets or battery holders, for 4 or more batteries at one time you want the long leads.
Appreciate your detailed reply mate, I had already bookmarked and pinched all the photos out of your balance charging thread the other thread has some good info, in terms of the black balance leads, where do they attach between cells? To the magnet or on the cells themselves?
Have the hyperion balance adapter here, never even thought about changing it and buying the JST-XH leads makes it much easier than trying to find pin-outs!
yeah to the magnets then the magents go inbetween the cells and hold them together, i used 8 x 8 rea eath magnets they solder ok with a 70 watt solder iron, just dont let them bang to hard together as they will chip,
Yeah just plug the jst-xh leads straight in, they are more common and cheaper too.
Overall, it's a decent charger but never seems to stop charging so definitely not a safe one (even if the residual charge rate is very low). Not recommended for novices and even advanced hobbyists should use with care.
So they are just like most cheap chargers that ovewr charge by the looks and i quess the safest option would be to use the protected trustfire 26650 batteries or balance charge them like i do
The Xtar WP2 II charges the King Kong unprotected 26650 just fine with the addition of a magnet on top to make contact. Mine cuts off charging at 4.19v each time.
The Xtar WP2 II i gave to a family friend cuts out around 4.22 not bad also depends on the cell, some of the other trustfires and solaforce chargers are around 4.23 and my old mans imax b6 over charger's.
Ill test the TR-005 when it gets here and see if its with in a safe range before i hand it over as the above test is not to bad to me as a midrange user and it could of just been a one off.
