Thanks for all the parts Led4power. Everything arrived in good order. At first, I wasn’t completely onboard with lighted tailcaps, but they are pretty cool. They might even help me if the power goes out. One build done and more to go. Waiting on some parts.
Is the LD-B4HV going to back in stock soon? Or do you have something else planned? Also, I’m highly anticipating the release of the Subzero.
If I have something selected as being in my wishlist, will I automatically get an email once it is back in stock?
Any suggestions on what to use for a thermal path with an LD-A4 and a S2+ host?
Reading through the thread again I realized I ordered a 12A LD-A4 with the intention or using it for a triple, misunderstanding the use of a MOSFET on this style of driver and don’t have anything to use as a heatsink. It’ll be going in a kiriba-ru triple copper pill, would some of those silicon thermal cubes suffice?
DarkShot, this aluminum spacer is probably meant for such duties. You could also craft it from copper if able, or something similar. The dimensions can be easily figured out, height is the only measurement which can leave a bit of doubt but this is easily solved making the part a tiny bit taller so you can sand down reduce it if needed later.
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
Cheers, the issue at hand is those thermal kits are out of stock, and if they were in stock they still wouldn’t work, as I’ll need a single hole for the triple pill I intend on using. If I had some machining tools at my availability this’d be done in short order but I don’t unfortunately.
My order arrived yesterday! Had everything arrive extremely well packaged, and everything went together almost without a hitch!
Unfortunately it looks like the RGBLEDs don’t like heat or I otherwise ham handed something, ‘cause one of them the red channel no longer works and I managed to kill another one. This was 100% my fault, it arrived perfectly functioning. Time to source some new RGBLEDs!
Additionally, where could I add a bleed resistor to an LD-x4 that I didn’t select as an option to use an illuminated tail cap?
LD-x4 doesn't use resistor for bleeder but small jfet transistor 2SK3796 (you will see 3-pin empty space for it on driver - if you ordered one without bleeder option), parasitic current consumption during driver ON time is significantly lower compared to resistor (1mA vs 6-20mA).
But adding ~300Ohm resistor between driver spring pad and gnd ring would work too.
I just built a light using the LD-B4 driver and one of your quad pcbs. I couldn’t find a diagram showing the connections of the socket on the pcb. I had to carefully study the pictures of your example build. Is there no diagram anywhere?
Question: mode advance in the LD-4 drivers is done by a half click, that’s pretty obvious. But is movement in the other direction possible? Eg. by a double click. I can’t find anything about this in the instruction
virence.com Nichia E21A sw30+sw40 Wizard Pro ; Skilhunt H03 XP-E2 660nm Photo Red ; Wizard Pro E21A 2000K ; S2+ E21A sw40 d220 (for sale)
I just built a light using the LD-B4 driver and one of your quad pcbs. I couldn't find a diagram showing the connections of the socket on the pcb. I had to carefully study the pictures of your example build. Is there no diagram anywhere?
There is no diagram at the moment, for 3x and 4x 32mm mosX boards connections are:
Pin1 - GATE (Pin1 is 1st from the left if you look from pcb center)
Pin2 - TEMP/NTC
Pin3 - MOONLIGHT
For 6x 34mm mosX boards connections are:
Pin2 - MOONLIGHT
Pin3 - TEMP/NTC
If customer buys one of these MCPCBs with all options included, I put connector with wires in package, so customer doesn't need to worry about this, he only needs to solder those wires correctly to driver (red-gate,white-temp, blue or yellow-moonlight).
Thanks. I bought the parts used and did actually manage to switch moonlight and temp which means that the overtemp protection doesn’t work correctly. It was easy to fix though.
I build 2x Convoy S2+ few days ago (post in mod thread) but today have time to take more pictures.
Both with l4p mpcb and drivers and with custom retaining ring from kiriba-ru.
The leds are Luxeon V and Nichia 219-b-v1 sw45k 9080. I read that the nichia led become more pink at current higher than 2Amps (1,5Amps now) So, probably change the driver to LD-4 3Amp in the future
Thanks for the clearance boards! I just bought a few yesterday. I wish I could have bought more but I’ve been spending a lot on other things already this year. I also bought another Q8 4040/5050 board, and it made me wonder if you ever sold enough to break even on those. You had said before that a lot of people who showed interest never bought any of them, and you were stuck with a lot of unsold boards. I know that was before I had bought any, and I’ve bought a couple of them since then. So, I’m hoping others have stepped up too, and you don’t lose money.
- The YKK Philosophy
I built an X6 quad with LED4Power’s new spacer:
http://budgetlightforum.com/comment/1461027#comment-1461027
Thanks for any help.
I don't plan to stock LD-B4HV anymore. I'm not sure about automatic mail sending, so it's better to check site and and this thread occasionally.
led4power.com
Thanks Neven! All good as ever!
MY REVIEWS THREAD /// My Flashlight Collection ///
Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Review's Blog (PT) /// OL Contest 2019 /// OL Contest 2020 /// GIVEAWAYs: 1 / 2
Any news on the CULPM1.TG yet?
I really want some of that boost hx
The OPTOFIRE - 4.63Mcd aspheric LED flashlight The SYNIOSBEAM - 10Mcd recoil LED flashlight List of the farthest throwing flashlights
- Yeah, but is it ultra high CRI?
Thanks for the suggestion though!
Still waiting for the FET switches and den 30A drivers :).
Project Excalibur - Next Generation LED Thrower (UPDATE 2018-01-15: 1.7Mcd)
Portable Thrower Comparison
Unfortunately it looks like the RGB LEDs don’t like heat or I otherwise ham handed something, ‘cause one of them the red channel no longer works and I managed to kill another one. This was 100% my fault, it arrived perfectly functioning. Time to source some new RGB LEDs!
led4power.com
Any new products coming soon?
When they become ready, you'll see them in store.
led4power.com
Hello Neven, is it possible that you will offer XHP50.2 in 3V variant?
Such as from cutter in around 5000K?
I'm not planning to stock Cree LEDs.
led4power.com
https://led4power.com/download/4621/
I’m talking about the LED PCB. There is no diagram for it.
Edit: see LED4Power answer below
Double click can be assigned a special function. It’s in the instructions. No reverse
Pin2 - TEMP/NTC
Pin3 - MOONLIGHT
Pin2 - MOONLIGHT
Pin3 - TEMP/NTC
led4power.com
Here's a German thread on my build.
Clearance sale on some of ALU MCPCBs:
https://led4power.com/?s=clearance+sale&post_type=product
Perfect for ultra-budget builds with LEDs from Arrow that are on clearance sale too:
http://budgetlightforum.com/comment/1493829#comment-1493829
led4power.com
I think the 3V XHP50.2 may have spurred some sales. 15K lumen Q8’s
Or more…
Possibly even more “IF” you buy a bunch of 50.2 3v and cherry pick’em….over 5000lm with out lens.
4800lm with a UCL lens from flashlightlens.com
Wish I had 3 more of these….
KB1428 “Live Life WOT”
Is the LD A4 enough for the 3V XHP50.2 or should I go with the B4?
USB power meter/tester thread
