I’m talking about the LED PCB. There is no diagram for it.
Edit: see LED4Power answer below
Question: mode advance in the LD-4 drivers is done by a half click, that’s pretty obvious. But is movement in the other direction possible? Eg. by a double click. I can’t find anything about this in the instruction
Double click can be assigned a special function. It’s in the instructions. No reverse
I just built a light using the LD-B4 driver and one of your quad pcbs. I couldn’t find a diagram showing the connections of the socket on the pcb. I had to carefully study the pictures of your example build. Is there no diagram anywhere?
There is no diagram at the moment, for 3x and 4x 32mm mosX boards connections are:
Pin1 - GATE (Pin1 is 1st from the left if you look from pcb center)
Pin2 - TEMP/NTC
Pin3 - MOONLIGHT
For 6x 34mm mosX boards connections are:
Pin2 - MOONLIGHT
Pin3 - TEMP/NTC
If customer buys one of these MCPCBs with all options included, I put connector with wires in package, so customer doesn't need to worry about this, he only needs to solder those wires correctly to driver (red-gate,white-temp, blue or yellow-moonlight).
Thanks. I bought the parts used and did actually manage to switch moonlight and temp which means that the overtemp protection doesn’t work correctly. It was easy to fix though.
Clearance sale on some of ALU MCPCBs:
https://led4power.com/?s=clearance+sale&post_type=product
Perfect for ultra-budget builds with LEDs from Arrow that are on clearance sale too:
https://budgetlightforum.com/t/-/56520/14
I build 2x Convoy S2+ few days ago (post in mod thread) but today have time to take more pictures.
Both with l4p mpcb and drivers and with custom retaining ring from kiriba-ru.
The leds are Luxeon V and Nichia 219-b-v1 sw45k 9080. I read that the nichia led become more pink at current higher than 2Amps (1,5Amps now) So, probably change the driver to LD-4 3Amp in the future
Thanks for the clearance boards! I just bought a few yesterday. I wish I could have bought more but I’ve been spending a lot on other things already this year. I also bought another Q8 4040/5050 board, and it made me wonder if you ever sold enough to break even on those. You had said before that a lot of people who showed interest never bought any of them, and you were stuck with a lot of unsold boards. I know that was before I had bought any, and I’ve bought a couple of them since then. So, I’m hoping others have stepped up too, and you don’t lose money.
I think the 3V XHP50.2 may have spurred some sales. 15K lumen Q8’s
Or more… 17000lm
Possibly even more “IF” you buy a bunch of 50.2 3v and cherry pick’em….over 5000lm with out lens.
4800lm with a UCL lens from flashlightlens.com
Wish I had 3 more of these…. :cry:
Is the LD A4 enough for the 3V XHP50.2 or should I go with the B4?
I haven’t had issues pushing 12A through the A4 in a small host.
5700K Luxeon V (I'll put it on web this weekend).
Neven, can you perhaps put up a picture to show the tint vs the 4000K Luxeon V?
If not for shipping, that clearance would feel like a gaw. I love your alu boards.
Neven, do you offer 20mm drivers or 17mm to 20mm driver adapters?
Thanks,
Caleb
Neven, any plans to be able to utilize an electronic side switch ?
Neven, do you offer 20mm drivers or 17mm to 20mm driver adapters? Thanks, Caleb
Not currently, I'll check with Simon if he could make some adapters.
