Yeah, practice is best when it comes to knife sharpening. Another important thing is to do regular maintenance so as not to have a need for more work later on. Less aggressive removal of material, no need to kill the blade.
Found the RAT2 for $50AUD locally so it might just be worth avoiding the hassle of customs and go local.
https://www.knifewarehouse.com.au/rat-ii-black-handle-black-blade-folder-ontario/
edit:: helps if I read stock levels
Thank you Relampago
I will probably go for Spyderco.
Really?? You must have big hands??
I actually do not like the shape of the handles on the original 3 or 4. I was glad when they came out with the ESEE-3HM & ESEE-4HM. I like these handles really well. Picture of the ESEE-3HM below.
I also love that GoCommas and can recommend them.
Can someone recommend a tool to sharpen knives?
Something not too expensive…
I use these compact and inexpensive Lansky crock sticks:
What I love about ceramic and carbide sticks is that I can get a working edge with like 5 passes.
Family picture :
Land (SRM) changed the name of some of their knives (like the 9104 became 913, green 910 became 911, ...) a few monthes ago.
All of them are pretty good knives with a good finish and sharp enough out of the box.
The small one on the top is my edc. I got several of the same kind on GB while they where on sale and no "washed" 7010 was available. I didn't like the shiny black coating too much and the sharp edges (frame, blade back) were very uncomfortable on such a small knife so i decided to soften everything with fine sand paper and steel wool and i am very pleased with the result (reflexion on the picture makes it look more "white" than it is for real).
I don't know what steel it is made of but i am using it everyday for food, cardbox, whatever and need to sharpen it less than once a month.
The 9xxx are pretty big knives and that's why i love them (i used to carry an INRON MY802 as edc for long time) but because of terrorism paranoia there is now too much a chance to get in trouble carrying such knife where i live so i eventually went with the 7010 : still supposed not to be allowed (no lock allowed) but the smaller size and nice look (hey flowers !) makes it easier to carry and less frightening.
I have not used the 811 "for real" enough to have an opinion so all i can say is it looks as good as the others.
/\ Nice “family picture”, thanks for sharing.
@ Adahn Very nice work!! . :+1: . I bet that was a job getting that all lined up correctly….
You bet right
But it was worth it
Now I’m thinking about making a scale for my SRM 813. Not sure if I’ll make it before I tried my dc supply for anodizing
@ Adahn… Thanks for the pictures. And again…. great work!!
Wow impressive work! The knife is really light now and still with a solid steel frame-lock.
very nice work adahn
That cheap sharpener on No1 frame.
I’ve used a version of that for a few yrs now.
The only difference being I bought a set of DMT Diamond Plates (that fit) in leiu of the “stones.
Does a great job so far.
Just kept the purple stone for polishing.
Gives a nice even grind for kitchen but a little iffy for smaller blades.
I still do them, with the plates. By hand.
Made up a angle “L”plate with base and several holes in vertical to give grind angles.
:person_facepalming: . That did sound like a commercial didn’t it?
But yeah…. I do like it. At $10 it is a no brainer & from what I have seen “so far” it stacks up darn good against some of my knives that cost MUCH more.
I am still shocked & amazed by that……
Your commercial testimonial so good I just ordered it. Thank you.
/\ … Hope you enjoy it.
Couple of years back purchased a Ganzo G720 due to reviews on this site. Seemed to misplaced it a couple months back, but since I’m not a daily knife user and have 2 SRM 7063 AUC - LI at hand couldn’t be that upset. Right now I am however starting to miss it and am looking for a replacement.
What I liked about the G720:
- Weight, it was quite a chunky knife and felt good in my hand
- Size/grip, see comment above
- Axis lock, I seem to hurt myself with a liner lock, Axis lock (or something similar which keeps my fingers away from the blade) is the way to go for me
Going through this topic I’m seeing some new brands like Brother and Fura. So I’m wondering; should I just go for the G720 again or do you guys know a better/good alternative?
Get it while it’s still available.
I agree. The G720 is amazing as a worker folding knife, very comfortable and a fat blade with textured G10.
In the market again.
I’m really liking my Ganzo 7582, but it’s a bit big for EDC. Ideally I’d get a Pro-Tech Calmigo, but they are spendy.
I messed with some spring loaded tab and flipper tab assisted knives and I think I can get along with them.
Looking for a 2.5” blade, and relatively thin profile, simple no serration drop-point.
What’s out there?
The CH Outdoor and GoComma stuff look ok. I’d prefer something with a axial/axis lock as I’ve got a youngin in the house.
