Private messages are going out now, with coupon codes and information about how to make a purchase.
Since the process is spread out over time, it has a delay between each message. It looks like it’ll probably finish going through the list in about 41 hours.
These messages are sent in the same order as the interest list, so if you’re near the top you should get a message soon. If you’re near the bottom, it’ll probably be tomorrow.
To give people a bit more time to sign up, I plan to update the list again tomorrow and run a second batch of messages after the first one finishes.
If it is not too late, I am in for ONE light with the higher CRI leds (not the on with xpl-HI it is launching with).
If I can order one with no bunnies or other animals, then that would be perfect.
If I got more than 2, I’d have to build a bigger doghouse so I could sleep in it once my wife noticed. If we are still adding to the list, I guess the appropriate thing to do would be to add me on the list for a second one, and I will wait for that notification before I purchase the second.
I placed my order! I haven’t been following the thread but I’m happy that everything finally came together. Thanks to the whole team for making this happen.
I’m excited that the time is here for them. Thanks TK and team for all the work you’ve done!
I hope the SST-20s come out soon for the light as well. The high CRI has really grown on me when out running with my D4S even though the color temperature is slightly warmer than I wanted (I really like the ~4750K of my Foursevens Mini MKII). It helps quite a bit distinguishing items on the ground when running. Thanks again everyone!
@ToyKeeper, thanks so much for all your work on this. And of course also to Neal & FW3A Team.
So is this first batch with the BLF discount only going to be XP-L HI, and that SST-20 will be at a higher price?
Also, if the only branding to be added is the bunny on the tail switch, is that etched into the metal or painted on?
