So I’ve been looking for a 26650 floody light which can do about 1000 lumens continuous. So far I’ve found these:
JKK70
Sofirn SP33 XHP50.2
Convoy S11 XHP50.2
Probably gna get the sofirn but im confused about the color temps. First link says 6000-6500k. Second one says 5350k- 5700k. Third one says xpl and 5350k- 5700k in the description but XHP50.2 in the title.
Confusing as there are 3 versions: SP33 w/ XHP-50 (Gearbest) and may be 5300-5700º; Ali Store XHP-50.2 (flipchip, no bonding wires) to which Sofirn made an update to their ‘newer’ version (V.2) which is ~5700º K.
Best you deal directly with Sofirn Store
I should add; have a JKK03 (same XHP-70.2 emitter - same driver/interface) but driven with 3 x 18650s and used as a power bank. Excellent machining and design. All the detailed nuances. The biggest difference is the Jin Heng does not step down in turbo mode. So much mass to dissipate the heat. The Sofirn has this redundant timed (2 minutes) step down regardless of their ATR (Advanced Temperature Regulation). The detailing and the overall look / feel of the JKK is better (my judgement).
If you plan on using outdoors, a higher CCT will give more ‘punch’. Again, subjective opinion. I tend to take out my 6000º + lights more often than the the 5000º
I want to buy both of these lights. I am buying the Convoy 1st because Simon does not use glue and has interesting LED/Driver options. After I build the perfect Convoy, I will still get the Sofirn because of the side switch. Sofirn does a good job and is a must for any collection.
Sofirn SP33 XHP50.2 color temps: 6000-6500k. This is the official answer Sofirn. And this is confirmed by paired comparisons.
JKK70 It has a deep reflector, so hotspot will be wide but the side illumination is a bit narrower than SP33
S11 has an average mode of about 750Lm, but a rich selection of color temperatures. Perhaps a pill construction removes heat a little worse, but I have not seen direct comparisons.
Sofirn should hurry with the provision of a choice of color temperatures, it is an important competitive advantage.
I have not had the opportunity to test the Nightwatch NA40SE. I will give other results of tests, maybe they will give data for analysis: 24°C of the medium
How does the SP33 manage heat so we’ll compared to the other lights? I was thinking maybe it’s bad thermal paste so it doesn’t let the heat out but that would show after 60 minutes. Could it be the driver efficiency?
I have a ft03. not really looking for a thrower. jaxman z1 xhp50.2 looks good but its out of my budget and cool white. sofirn sp33 seemed perfect until i realised it doesn’t come in neutral white. Looks like I’ll be sticking with larger LED’s as they seem to manage heat better. Also looking for a 21700 light to replace my L16.
Ain’t interested in modding? The F13 can be had for cheap, even though it’s quite nice as a host, and easy to mod. 22mm driver, 20mm LED star. Go crazy…
