a) PFlexPro is closed because they have a big order and don’t give a damn about the retail biz.
b) Malkoff is a parts supplier turned manufacturer. Very expensive. More than Surefire.
c) Elzetta is more expensive than Surefire too.
d) HDS makes the ugliest flashlights there are. WAY more expensive than Surefire.
I just bought a Surefire Fury Tactical (1500 real lumens) for 139.95.
Is that expensive?.
No joke, back when I had my work notebook/agenda, I only wrote on it with two Bic pens I’d found abandoned inside library books - one purple, one bubblegum pink. They NEVER went missing from my pen cup, unlike the blues and blacks. Even leaving them on top of my otherwise empty desk yided no “yoinks”.
We here say it in jest, but it’s a legitimate life hack
You are right but ramp up and down several times in a raw and report back if you have lower brightness immediately. I remember QTC experiments done here and I remember that you had to wait for the QTC material to recover from compression before having lower brightness.
Just checked. As far as I can tell, it ramps down immediately. Maybe because construction of the light that I tried (CRX mod) prevents overcompression.
QTC is very finicky around firefly mode but othat than this - the only feature I miss in QTC lights is battery check.
You know that in the first place it was a joke about the more and more popular anduril/narsil ramping UI that involve a switch to work, but if you are considering QTC and rotary, you are right and i’m wrong.
Those UI are brillant in themselves for mimicking/imulating a QTC/rotary, its admirable but sometimes the fact that you have to wait for, then pass and miss the “right” brightness you need : click-hold “oops too much”, click-hold “oops too low”, click-hold…makes it less straight-forward than an UI like Bistro. Too much choice in brightness settings. Then you will say that anduril can be configured with stepped ramping. Darn, ToyKeeper is good at making my joke irrelevant.
But again it was just a joke about smooth ramping UI using a switch.
Well forget it.
