I want to buy both of these lights. I am buying the Convoy 1st because Simon does not use glue and has interesting LED/Driver options. After I build the perfect Convoy, I will still get the Sofirn because of the side switch. Sofirn does a good job and is a must for any collection.
Sofirn SP33 XHP50.2 color temps: 6000-6500k. This is the official answer Sofirn. And this is confirmed by paired comparisons.
JKK70 It has a deep reflector, so hotspot will be wide but the side illumination is a bit narrower than SP33
S11 has an average mode of about 750Lm, but a rich selection of color temperatures. Perhaps a pill construction removes heat a little worse, but I have not seen direct comparisons.
Sofirn should hurry with the provision of a choice of color temperatures, it is an important competitive advantage.
I have not had the opportunity to test the Nightwatch NA40SE. I will give other results of tests, maybe they will give data for analysis: 24°C of the medium
How does the SP33 manage heat so we’ll compared to the other lights? I was thinking maybe it’s bad thermal paste so it doesn’t let the heat out but that would show after 60 minutes. Could it be the driver efficiency?
I have a ft03. not really looking for a thrower. jaxman z1 xhp50.2 looks good but its out of my budget and cool white. sofirn sp33 seemed perfect until i realised it doesn’t come in neutral white. Looks like I’ll be sticking with larger LED’s as they seem to manage heat better. Also looking for a 21700 light to replace my L16.
Ain’t interested in modding? The F13 can be had for cheap, even though it’s quite nice as a host, and easy to mod. 22mm driver, 20mm LED star. Go crazy…
Guys, isn’t this an interesting lights… THE JINHENG JKK70 30W 3600 Lumen Powerful 26650 Flashlight SST40 Strong Floodlight - 4000k. Dude, it has 4000k warm white and optional on 5000k and 6000k. Wow, isn’t that greats, huh?
Is Luminus sst40 led warm white 4000k exist or this one is dedomed?? Can anyone here on BLF confirm me. Anyone own this light pls share your thought. because my eye got strain on Cree xhp70.2 p2 6500k due too much bluiesh light harmful one. I had to wear polarised Specs that way I feel much better…
Besides, it can also use a second tube for +1 26650. This is a good high performance flashlight that will probably hold on for a while on medium mode (1300 lumens).
