Test/review of Eizfan Pro Q4 Intelligent Charger
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 week 4 days ago
DSC_5126
DSC_5127 DSC_5128
This is a simple LiIon charger for four cells.
DSC_4993 DSC_4994 DSC_4995 DSC_4996
The cardboard box lists some specifications, battery types and features.
DSC_5125
The box contains the charger, a mains cable and, manual.
DSC_5129
The charger has a mains input socket, it will accept 100-240VAC 50/60Hz according to specifications.
DSC_5247
There is not much user interface on this charger, only one led for each slot. It is red while charging and green at other times, except if a totally drained battery is put into the charger, then it will go out.
DSC_5130
Specifications are listed on the back.
DSC_5132 DSC_5133
The slots uses the usual slider construction. They can handle batteries from 29mm to 70.3 mm long, this excludes protected and button top 21700 and a few very long protected xx650 batteries, but everything else will fit in length.
supportedBatteryTypes
supportedBatterySizes DSC_5212 DSC_5213 DSC_5214 DSC_6306
Due to the 1A charge current it is best only to charger high current version of small cells in the charger.
The charger slots are large enough to fit 32650 batteries, but I had trouble getting connection with them.
The charger can handle 70 mm long batteries, inclusive flat top cells.
Measurements
  • Discharges with 0.01mA when not connected to power
  • Below 0.5 volt the charger will not charge batteries and the led is off
  • Between 0.5V and 2.9V it will charge with 75mA
  • Above 2.9V full charge current will be used.
  • Charges/discharge with less than 0.01mA when battery is full.
  • Will restart if battery voltage drops to 4.10V.
  • Charge will not restart charging on a nearly full battery after power loss or battery insertion.
  • Power consumption when idle without batteries is 0.15 watt
Eizfan%20Pro%20Q4%20%28SA18650-33%29%20%231
A nice CC/CV charge curve with a termination current around 150mA.
Eizfan%20Pro%20Q4%20%28SA18650-33%29%20%232
Eizfan%20Pro%20Q4%20%28SA18650-33%29%20%233
Eizfan%20Pro%20Q4%20%28SA18650-33%29%20%234
The other slot is similar.
Eizfan%20Pro%20Q4%20%28SA18650-26%29%20%231
Eizfan%20Pro%20Q4%20%28PA18650-31%29%20%231
Eizfan%20Pro%20Q4%20%28BE18650-26%29%20%231
Eizfan%20Pro%20Q4%20%28AP18650-26%29%20%231
Other types of batteries do not change anything.
Eizfan%20Pro%20Q4%20%284xSA18650-33%29
With four batteries the charge current drops a bit, this is probably to the temperature inside the charger. I have no idea what happens around 180 minutes, at least the final result is good enough.
Temp6482
M1: 43.8°C, M2: 45.6°C, M3: 44.9°C, M4: 42.0°C, M5: 67.3°C, HS1: 69.9°C
Temp6483
M1: 61.1°C, HS1: 73.2°C
PoweronLiIon
The charger is fairly fast to start, only requiring about 1 second.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
It is a simple charger, but for LiIon batteries that can handle 1A charge current it works fine and with acceptable charge speed.
Notes
The charger was supplied by a Eizfan (Efan) for review.
MRsDNF
MRsDNF's picture
Thanks HKJ. Thumbs Up
I’ll have to look to see if they come with an Australian plug standard.
