Sofirn SP70 Alone $50, PM for AMZ US CODE(LIMITED)
2245 posts / 0 new
Yourrid
Yourrid's picture
Last seen: 17 hours 55 min ago
JasonWW wrote:
Yourrid wrote:
Single click ON to the last setting used (which is usually high) is a huge factor.
Just to be clear, it does do this. (In case you thought it didn’t and needed to be added)
Does or does not? I thought Tom E said it goes to last used?
If my info is incorrect, I’ll happily correct it. I thought it went to last intensity used in ramping mode.
Edit: as I understood it, from OFF, press and hold goes to moonlight, and it will not ramp up to high like Narsil or Emisar’s UI. The only way to get out of moonlight is to turn it off, then single click ON which goes to the last used setting. For me, that seems like a shortcoming.
Barry0892
Barry0892's picture
Last seen: 1 day 15 hours ago
guys, I think there are some misunderstandings.
Sofirn SP70 available now is sofirn version which is helped by BLFers but not BLF version. Sofirn put it on market because sofirn need a big powerful light.
The BLF SP70 version is not confirmed, since now some of the sofirn SP70 are received by BLFers, you guys can talk about how do you like the BLF SP70 to be.
Just don’t mix sofirn SP70 with unconfirmed BLF SP70. Facepalm
WhatsApp: +8615773183209
My new Facebook account: https://www.facebook.com/barry.dong.9250
JasonWW
JasonWW's picture
Last seen: 5 hours 46 min ago
You were describing a basic momorized level. When you single click to turn it On, you go to the last used setting.
So if you like to keep it at a specific level, you can. One click On and one click Off. It stays at that level.
Keep in mind that all UI’s are a compromise because you can’t please everyone. Even though the operation of Moonlight on the SP70 is not perfect, I think this is a solid improvement over the UI on the S70S and L6.
I personally don’t ever use lower levels on my big lights because I have smaller lights that are better for moonlight.
WTF
Last seen: 1 month 1 week ago
Barry0892 wrote:
cool. package sent to Jason will arrive soon too.
pictures and video of SP70 sharing is welcome!
Guess it’s time to talk about a BLF version. maybe: retaining ring, smooth reflector, different tint, no switch tail cap, Anduril firmware? Big Smile
Could everyone read post 2000 again.
I’m guessing Sofirn would rather us talk about what we want than nit picking the current light and leaving a bunch of negative stuff for search engines to find.
I like Barry’s list. 4000k is ideal for me but its an easy change so I don’t really care.
Narsil would be better. No one is going to use candle mode with this and throwers aren’t really ToyKeeper’s thing. This is Tom’s domain.
Add in some input from Kawiboy, TA or Dale and this thing could be special.
Barry0892
Barry0892's picture
Is it better if start a new thread for BLF SP70 ?
JasonWW
JasonWW's picture
Do the sales figures of the current SP70 look good enough to make a BLF version?
Maybe it is too early to know?
Yourrid
Yourrid's picture
I totally understand the “last mode” idea. In my opinion, it’s probably a good feature. The problem I see is the ramping from OFF. I cant ramp from OFF to HIGH. Ramping from OFF only goes into moonlight mode. Then you have to turn it off, then 1 click turns it to blindingly bright light.
Sofrin needs a ramping mode that goes from 0 to max, while holding the switch from OFF.
Johm
Last seen: 7 hours 45 min ago
Definitely.
JasonWW
JasonWW's picture
Yeah, this function was quite low on my list of priorities. I’m glad the overall UI works as well as it does.
A simple fix might be covering the lens with your hand or leg to avoid any sudden brightness while you ramp down.
A counterpoint could be that some people like that you can activate moonlight without loosing your preset level. Losing the preset certainly irritates me that’s why I use a different light when I need a very low level.
Like I said, no UI suites everyone perfectly.
Relampago
Relampago's picture
I purchased this light thinking it was going to have ar glass and becu springs, but I’m not disappointed that I misunderstood. I like the sofirn lights I’ve purchased and would love to see an upgraded blf edition with a good price, I’d purchase another.
“Electricity is really just organized lightning”
― George Carlin
JasonWW
JasonWW's picture
I was told that they were using BlueSwordM’s BeCu springs. Does anyone know how to confirm this?
Agro
Agro's picture
Last seen: 2 min 34 sec ago
BlueSwordM wrote:
@Scallywag, can you check if the springs are magnetic?
Thank you.
Speaking of magnetism…will a magnet in the tailcap be available as an option?
Agro
Agro's picture
All is needed is a stronger magnet….
But really I was just kidding, I found the thought of carrying around a magnet this strong amusing. Smile
Sofirn
Sofirn's picture
Last seen: 7 hours 21 sec ago
I don’t think so. BlueSwordM did give a good advice but engineers believed they can find great springs too. So……
Hope someone can compare these two kind of springs.
JasonWW
JasonWW's picture
Awe man, that means the springs might be the cause of the lower amperage. I might bypass the springs instead of swapping the FET and see if the amps go up. I want to keep it stock for right now so I can do more measurements.
JasonWW
JasonWW's picture
I hope that everyone who has recieved their SP70 is liking it. Big Smile
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 1 hour 41 min ago
I have now created a new thread for the development of Sofirn's SP70 "BLF Edition".
http://budgetlightforum.com/node/66964
I hope all of you agree that this thread is now being separated for the "BLF Edition" might deserve to be discussed in detail elsewhere. Thus, this thread here can remain for any further discussion about the standard SP70. I therefore encourage you to post your ideas and suggestions for the "BLF Edition" in the new thread. I will try to keep track and collate any updates and progress during its development over there.
Jason, Dale and anyone else who could help me summarize the most important charecteristics about an improved SP70, please feel free to post it in the new thread.
Thank you very much!
Cheers,
Thomas
BlueSwordM
BlueSwordM's picture
Last seen: 2 days 20 hours ago
Ah damn it.
I know they are using BeCu, but they haven’t told me what type.
They could be using:
1. BeCu C17200 22% IACS.
2. BeCu C17530 38% IACS
3. BeCu C17500 45% IACS
Looking at the current achieved here, it looks like they are using BeCu C17200.
On one hand, that means they are about 55% the conductivity of BeCu C17530 that I use, and the longer spring along with the thinner inner spring means there is much more resistance.
On the other hand, I do support their decision for cell compatibility purposes.
BeCu C17200 has close to the same mechanical properties as steel, but with 3-3,5x the conductivity of that.
That means variously sized 26650s and 21700 can fit in the same light without making it very hard to close the light.
Or they could just be using phosphor bronze. It’s obviously not steel though.
That means the BLF edition can be improved on that point however.
Lux-Perpetua
So, BeCu C17500 45% IACS would be best for lowest resistance?
I would include that information into the new SP70 BLF edition thread.
BlueSwordM
Yes, but the mechanical properties are quite bad.
BeCu C17530 is the best overall.
Lux-Perpetua
Alright, thank you BlueSwordM. I will put that into the wishlist of the BLF edition and suggest to follow up in the new thread. Wink
Tom E
Tom E's picture
Last seen: 18 min 38 sec ago
JasonWW wrote:
I hope that everyone who has recieved their SP70 is liking it. :D
I nitpik, that's what I do, but also to get the info out there as clear as I can, sometimes opinions added. The UI is quite usable as-is, but everyone has their own priorities of "musts" and "nice-to-haves"
But, I really do like this light!! It's amazing what it can do stock! Very happy with it, specially considering the cost.
I haven't followed all the reports on throw #'s, but again, very happy with mine with bypasses and good cells.
leroycp
Last seen: 9 hours 47 min ago
Agree with Tom E. post 2093. Like for a stock light.
gehrmo
Last seen: 5 days 18 hours ago
Very happy with mine.Especially the large well defined hotspot.Quality,UI and tint all fine (my old eyes prefer cool white).While I will definitely be interested in a BLF edition I hope they don’t turn it into just another large thrower.
cncyana
Last seen: 1 week 1 day ago
The Noctigon Meteor M43 Flashlight had Berylium-Copper springs (45% IACS) that went almost completely flat after a short time of usage. I can’t remember whether the spring metal was to blame or the extreme heat or both. Don’t remember what they did to fix it.
Life’s Questions/Answers here: http://www.answersingenesis.org/home/area/qa.asp “So then, each of us will give an account of himself to God.” Romans 14:12
cncyana
I’m sold on it – got two on the way.
BlueSwordM
@cncyana, that’s right.
BeCu C17500, while having the best conductivity of all BeCu spring alloys, also has very poor yield strength.
That means plastic deformation, especially with a small top diameter—-bottom diameter ratio, is a huge problem with the Intl Outdoor spring.
Doubt it was heat at all.
The stock M43 driver would never pull enough current to make the springs to hot.
DB Custom
DB Custom's picture
Last seen: 4 days 17 hours ago
Just for the record, there is no centering ring.
The base of the reflector doesn’t sit on the MCPCB either, instead, it seats on the cut shelf in the head via the belt around the reflector such that the base hovers approx 1-2mm above the MCPCB.
DB Custom
DB Custom's picture
Interesting… I swapped out the MOSFET for an SIR404DP, changed the leads to Turnigy 16ga. With spring bypasses in place (still dual springs) and Samsung 30T’s freshly charged this light makes 10,500 lumens at start and drops down into the mid 8000’s by 30 seconds. In this case, the head IS starting to warm up nicely. Big Smile
Edit: Recharged the 30T’s, looks like it’s pulling 21.3A at start at the tail.
Scallywag
Scallywag's picture
Last seen: 21 hours 3 min ago
DB Custom wrote:
Interesting... I swapped out the MOSFET for an SIR404DP, changed the leads to Turnigy 16ga. With spring bypasses in place (still dual springs) and Samsung 30T's freshly charged this light makes 10,500 lumens at start and drops down into the mid 8000's by 30 seconds. In this case, the head IS starting to warm up nicely. :D
This pleases me Smile
Old Lumens Contest 2020 - Hand-made light category
ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20 | Baton S1
Boruit D10 w/ Quadrupel Fet+1/Anduril | EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S15 Ti | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special | Thrunite T10Tv2
Supfire M6 3xXHP50.2, Sofirn C8F, Unfinished: Sofirn SP70, IYP07/Tool AAA hot-rods, Jetbeam E3S
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
