13829 posts / 0 new
TrueRMS
Last seen: 2 years 1 month ago
Seems like it is an issue if TK herself pointed it out as an example of how to report a bug and stated it had been resolved in a later revision…
A big issue, no definitely not, but to claim “it’s a non issue” sounds a little stand-offish
Personally I only use the stepped mode and I often hold to start from low and step up to the level I want (this is also how I instruct people to use anduril lights I hand them) so I fully expect to run into this bug.
I’m not trying to be negative, I read that other thread before making my purchase. Just asking if the lights not yet produced will have the same exact FW on them or if they’ll be updated to the already published newer version with the bug fix for this particular issue.
teacher
teacher's picture
Last seen: 3 years 1 month ago
I’m not going to argue the point.
‘To me’ it is a total & complete “non-issue”… I should have said that in my post above. Sorry I didn’t, my bad. Facepalm
Whatever it is to you is fine with me. Thumbs Up
I understand it may be an issue to you. To me it is not. My apology if I seemed insensative to your plight
Edit: I fixed my post above to include ‘to me’. Beer
maukka
maukka's picture
Last seen: 1 month 1 week ago
I actually ran into that bug several times, since I like the stepped ramp mode.
For me it pops up often when I’m in relative darkness and don’t remember what mode I used previously. I know that the lowest moonlight mode will not be bright enough, but don’t want to take the risk of blinding myself by just switching the light on at the memorized mode. So I press and hold the switch to bring it to moonlight and immediately release and press again to go one or two steps brighter to a usable mode. But the light doesn’t react to the press.
teacher
teacher's picture
Caleb wrote:
ToyKeeper wrote:
Last I heard, I think Neal found a FD2 tint bin. Hopefully it’ll be a little more rosy than the FB4 bin found earlier.
From the chart, FD2 could be a great tint. Yay! Can’t wait to see it in person.
In theory, the FD2 should be less green than the FB4?? Is that correct?
cabfrank
Last seen: 3 months 1 day ago
Yes, from what I understand, a bit less green and a bit more rosy. Unfortunately, that tint chart isn’t as informative as the Cree chart we often refer to, but it is the only one I found as well. Maybe someone will point us to a better one.
teacher
teacher's picture
Thank you for the verification. Thumbs Up . Yeah… that is the only chart I could find. And I certainly agree… the CREE Chart is much better to me too.
cabfrank
Are you tempted to get one of the SST models in a nicer tint? I think I am, but also maybe the XPL 7A. Of course we have both already ordered our 3D’s.
teacher
teacher's picture
I think I will. And then if it turns out ‘ugly bile green’ like that Convoy S2+ I got (to see what the SST 20 craze was all about), I will change them out to something I like. Giving the SST 20’s to someone who likes green. Beer
I too, after TK & you (I think it was you) brought up that 7A would make for a great candle mode; am thinking seriously about getting a 7A to be a designated candle. Wink
Noir
Noir's picture
Last seen: 2 weeks 1 day ago
I can reproduce this little bug on my ROT66 and D18, but if nobody had pointed it out, I would probably have never noticed it.
maukka wrote:
I actually ran into that bug several times, since I like the stepped ramp mode. For me it pops up often when I'm in relative darkness and don't remember what mode I used previously. I know that the lowest moonlight mode will not be bright enough, but don't want to take the risk of blinding myself by just switching the light on at the memorized mode. So I press and hold the switch to bring it to moonlight and immediately release and press again to go one or two steps brighter to a usable mode. But the light doesn't react to the press.
I would probably have never run into the bug, because in the scenario you are describing I would simply press and hold until the desired brightness level is reached. There is no need to do two press and holds with a short pause in between, because Andúril will start in the lowest mode, but then immediately start to ramp up if you continue to hold the button down.
maukka
maukka's picture
That’s absolutely right! I think it’s mostly a reflex for me to let go off the button when the light turns on and blinks. I will try to use your method of holding the switch down from now on Smile
EnlightenMe
I wonder if the bug was reported to Neal/Lumintop and fixed in a timely enough manner to correct lights in the next batch. Or, were a ton of drivers already loaded and what’s done is done? Personally, I’ve never used a ramped light before, and would probably be a smooth ramp kinda guy anyway, so it may not affect me. I’m just happy to finally get a chance to hold an FW3A and impress my friends!
joechina
Last seen: 1 day 23 hours ago
Tom E wrote:
In case it’s not known here, Martin told me that Neal had a few 3D’s on hand, so the shipping notices are legit, assuming all you that got a tracking # ordered 3D’s.
FB is good for something, sometimes… smile
Have we somewhere pictures from a beamshot comparison of the to HI tints side by side?
( sorry I haven’t read the rest of the posts)
clip.
Last seen: 3 years 3 months ago
Comparing the location with the CREE ANSI chart, looks like FD2 falls very close to 5D2. Not sure which 5D Hank is using in the Emisars, but I love it. Looking forward to seeing the SST color.
stehk
Last seen: 9 months 2 weeks ago
Thanks FW3A team to design and build this amazing flashlight!
Thanks Neal for the super quick shipping arrangement and i made a new friend Smile .
PS: I live in China which just like Neal, that’s why i got the package that fast.
Tried my best to get some beamshot
clip.
stehk, thanks for posting! What tint did you go with? Looking forward to beamshots.
trakcon
trakcon's picture
Last seen: 9 hours 48 min ago
stehk wrote:
Thanks FW3A team to design and build this amazing flashlight! Thanks Neal for the super quick shipping arrangement and i made a new friend Smile .
Sorry that my new VTC6 still charging, no beam shot yet.
Looking forward to photos and initial impressions!
Edit: I see that photos were posted; just blocked on my work computer. Looks great!
Paradise
Congrats to the first commercial recipient of this light! Proves that all of this actually exists Wink
stehk
I got the 3D tint in this moment. Hopefully the high CRI SST20 can launch soon.
Spiderlight
I think Neal could not ship mine because I didn’t enter a phone number Facepalm
Scallywag
Scallywag's picture
Last seen: 1 day 13 hours ago
ToyKeeper wrote:
M4D M4X wrote:
people sharing codes hopefully grow purulent furuncles in the genital area...
I'm just quoting this as a reminder. Dear reader, if you find yourself thinking about posting private group-buy codes in public, just remember... PURULENT GENITAL FURUNCLES
Not a good google images search, BTW. I only searched for the non-genital version "purulent furuncles" and it wasn't good. About what I expected, though, not knowing what either word actually meant ahead of time.
Tom E wrote:
In case it's not known here, Martin told me that Neal had a few 3D's on hand, so the shipping notices are legit, assuming all you that got a tracking # ordered 3D's.
FB is good for something, sometimes... smile
That is what I ordered! We'll see how this compares to my typical 12-15 day China ship times.
ToyKeeper wrote:
Last I heard, I think Neal found a FD2 tint bin. Hopefully it'll be a little more rosy than the FB4 bin found earlier.
I heard a rumor (okay, I read something elsewhere on BLF) that AstroLux may have bought a bunch of "good bin" SST-20s. Wonder if that's making things difficult.
ToyKeeper wrote:
SIGShooter wrote:
I don't really know why I bought the flashlight since I don't really have a need for it.
Most of us don't really need it. To merely fill a need, we could go to a local shop for whatever cheap light they have. But there are plenty of other valid reasons to get one. I'm guessing the majority of us are here because we enjoy it, not because we actually need more lights. However, that said... I use this particular light a lot. It gets more runtime than the entire rest of my collection, unless I count the Q8 I use as a bedside candle.
mitsuki08 wrote:
I really want to thank all who worked on this light. I know it's not healthy but recently lights have been making me really happy more so than other things. So I hope everyone who worked on this feel the appreciation/thanks from the bottom of my heart. Sorry for being cheesy or over-dramatic.
Although few would admit it, that's probably the reason why many people are here. Sometimes a light in the darkness is exactly what we need, even if it's not strictly for the purposes of seeing at night. Because what we have here is a community, and it serves a lot of purposes which aren't strictly about converting electrons into photons.
Flashlights are definitely a hobby for me. They give me something to do, to plan, to tinker with in my brain throughout the day. It is healthy to have one or more hobbies, in moderation of course. But I'm proud of that, because I have too many friends and acquaintances with no real hobbies besides watching TV or playing video games.
I hope the FW3A ends up being a strong player in my EDC rotation, and I don't think I'll notice the firmware bug (since it seems I'm getting a first batch light). If it really bothers me, maybe it will be the push I need to start flashing firmware!
clip.
I’m really liking the 3D tint stehk, thanks for updating! Glad I went ahead and got one of each instead of sticking with the warmer colors.
JasonWW
JasonWW's picture
Last seen: 2 weeks 3 days ago
Usually the phone number (on Paypal) is only used for text updates regarding tracking.
Firelight2
Firelight2's picture
Last seen: 14 hours 20 min ago
I ordered on the first day and paid for expedited shipping.
I just checked the tracking number for the status for my shipment. ETA to California is this Thursday.
hcanning
Scallywag wrote:
ToyKeeper wrote:
M4D M4X wrote:
people sharing codes hopefully grow purulent furuncles in the genital area…
I’m just quoting this as a reminder. Dear reader, if you find yourself thinking about posting private group-buy codes in public, just remember… PURULENT GENITAL FURUNCLES
Not a good google images search, BTW. I only searched for the non-genital version “purulent furuncles” and it wasn’t good. About what I expected, though, not knowing what either word actually meant ahead of time.
That is what I ordered! We’ll see how this compares to my typical 12-15 day China ship times.
I heard a rumor (okay, I read something elsewhere on BLF) that AstroLux may have bought a bunch of “good bin” SST-20s. Wonder if that’s making things difficult.
ToyKeeper wrote:
SIGShooter wrote:
I don’t really know why I bought the flashlight since I don’t really have a need for it.
Most of us don’t really need it. To merely fill a need, we could go to a local shop for whatever cheap light they have. But there are plenty of other valid reasons to get one. I’m guessing the majority of us are here because we enjoy it, not because we actually need more lights. However, that said… I use this particular light a lot. It gets more runtime than the entire rest of my collection, unless I count the Q8 I use as a bedside candle.
mitsuki08 wrote:
I really want to thank all who worked on this light. I know it’s not healthy but recently lights have been making me really happy more so than other things. So I hope everyone who worked on this feel the appreciation/thanks from the bottom of my heart. Sorry for being cheesy or over-dramatic.
Although few would admit it, that’s probably the reason why many people are here. Sometimes a light in the darkness is exactly what we need, even if it’s not strictly for the purposes of seeing at night. Because what we have here is a community, and it serves a lot of purposes which aren’t strictly about converting electrons into photons.
Flashlights are definitely a hobby for me. They give me something to do, to plan, to tinker with in my brain throughout the day. It is healthy to have one or more hobbies, in moderation of course. But I’m proud of that, because I have too many friends and acquaintances with no real hobbies besides watching TV or playing video games.
I hope the FW3A ends up being a strong player in my EDC rotation, and I don’t think I’ll notice the firmware bug (since it seems I’m getting a first batch light). If it really bothers me, maybe it will be the push I need to start flashing firmware!
Agreed with all of this. It’s a really intriguing hobby for me, and I can’t put my finger on why bathing an area in light from such a small handheld device gives me such enjoyment, along with all the intricacies of different lights, but it does. I can’t wait to get my warm white FW3A. Anduril is the best thing since sliced bread, and the 7A will be an emitter I’ve had no experience with yet, and I’ll probably end up with another one once the SST20 version is released Smile
I don’t agree with the puerile genital funiculars or furry uncles or whatever they’re called, though. Nobody wants that.
Notable lights: Q8 with 4 x 3V XHP50.2, bypassed springs, brass driver and tailcap screws, Anduril firmware, removed anodisation, AR glass, warm white switch LEDs (16,800lm)  |  Convoy S2+ with triple Luxeon V 4000k, Led4Power B4 Driver, Carclo 10507, bypassed springs (2900lm)  |   D18 in sand  |  D4V2 in sand  |  D4S in grey  |   FW3A with warm white XP-L HI  |   KR4 Mule in blue
KawiBoy1428
KawiBoy1428's picture
Last seen: 2 hours 56 min ago
My 2 will be delivered by the end of the day… this Thursday! Steve
KB1428 “Live Life WOT
Spiderlight
I received this mail from Nelsgedgets
“Hello [redacted],
Pls provide phone number for shipping
Thanks
Neal”
So I think I delayed my shipment. Facepalm
teacher
teacher's picture
Tracking says 2 of mine will be here Friday 3 May. So far ever DHL from China I have had has arrived a day early. Soooooo, I’m hoping for Thursday….. Wink
Hope I didn’t just jinx it… Shocked . Facepalm . Knock on wood! Big Smile . Big Smile
iamlucky13
Last seen: 1 day 10 hours ago
This kind of thinking is infectious. Especially when I realized some of the fancy, smelly candles my wife has bought cost 2/3 as much as this light and are not rechargeable, nor as someone else pointed out, waterproof.
Clemence is planning an E21A triple board. I wonder if the E21A’s could handle the 219 build of Anduril (FET channel limited to 50%). That would provide a lot of color temperature choices. 2700K or 3000K could both be great. If you really wanted candle like light, you could go all the way down to 2000K.
RobertB
RobertB's picture
Last seen: 1 week 23 hours ago
He literally signed up with blf a few days ago, near the bottom of the interest list, and was one of the first to get not one, but two, FW3A’s … lol
Satan@103TFS
Last seen: 5 days 21 hours ago
Beside earlier get the light could someone tell me why I should order XPL-HI instead of wait for SST20 ?
