Omnicharge Omni Ultimate Powerbank (USB-C, AC out, DC out, 12x18650)
It’s been many years since I received a powerbank with false energy or capacity rating. One would assume that in 2019 such things no longer happens, much less with a device that costs $350.
Had they used some cells that would at least compare to the Sanyo GA like the super cheap and easily sourced LG F1 I would probably be fine. But there is “142Wh” printed on the back of the unit, that I cannot stand. There is an image in one of their updates from 6 months ago already showing the bak cells, they had plenty of time to explain and justify the changes if they wanted to. Now that is shady.
Sourcing 44,000 cells aren’t difficult either when they had months to do that. A quick trip on alibaba shows more sellers than my fingers can count willing to supply 100,000+ cells per week. When you got the money you just get things done. That’s how China works.
Indiegogo policy dictates that the campaigner must deliver the product, but doesn’t specify it must comply with the spec it was marketed with. That’s up to the backer and project owner. There is no PayPal claim, and obviously omnicharge isn’t answering my emails, after I went the extra mile to expose them. :slight_smile:
If one of these things ever catches fire, these people will be wide open to legal claims because they didn’t use the specified cell. You can just imagine the lawyer in court:
“Unfortunately, instead of using the reputable brand name cell specified on Kickstarter, they substituted a cheaper cell without that assurance…”
I was actually tempted by this powerbank when I first heard about it, but decided it was just too expensive for me. Dodged a bullet there, because I wouldn’t be a happy customer about this either.
Ultimate Battery Cells
Dear Backers,
First, we want to reassure everyone that we have not gone dark. We have been gathering together as a team to discuss a proper response to the accusation from some of the backers based on the comments we have seen posted on IGG.
We take these concerns seriously, and we care deeply about our backer's feedback, and we stand behind the quality of all the products that we build as Omnicharge from the beginning and into the future. So let’s start addressing your concerns:
Choosing BAK Cells
Yes, we chose to use the BAK cells. But it seems everyone has a misunderstanding of why and have a stigma that these are poor quality “Chinese” cells. On the contrary, they are not and here is why:
These cells are chosen because of their charging characteristic and life cycle; these cells have been used in the EV (electric vehicle) market for many years, and have stood the test of time that they are best utilized in high charge and high discharge environments, which we needed for the Omni Ultimate. Additionally, the cells are built to last 1000 life cycles and still retain over 75% capacity which allows the Omni Ultimate to have a longer product life cycle in the field, which we felt was important for this type of item.
Also, BAK is one of the largest lithium battery producers in China, top 3 as a matter of fact and in terms of size are comparable to among the largest in the world. So in terms of reputation and capability, this is not your run-of-the-mill operations company that we’ve chosen. The price, quality, and safety standards were part of the reasons we’ve chosen them over others.
Head to Head Performance Testing Results
During our selection, we came down to either choosing LG or BAK (Sanyo wasn’t ever in the plan due to supply constraints and extremely high cost vs performance). We made that choice through thorough testing and validation. We’ve noticed many of the comments made were just based on the specs and validation on the cell level, which we have also done, but beyond that, the most important testing is actually building battery packs in order to test the performance under the most extreme use cases and look at the holistic performance of the entire system instead of one single cell performance.
Of all the testing, this one is the main differentiator that stood out:
The test is between LG cells and BAK cells, on their performance under 100W continuous discharge (6 cells for each battery pack):
One of the main columns to pay attention to is the number of times that the battery pack was in the state of OT (over temperature which we set at 65 degrees Celsius) and how long it took to recover from the OT status.
You will notice that under different environment temperatures that LG cell pack frequently hit our OT and required much longer cooling time than BAK cells. Just focusing on one scenario, under 23 degree Celsius, discharging at 100W DC, LG cells would trigger OT protection 5 times, whereas BAK would trigger 1 time, and LG would require 32 minutes of cooling, where BAK only took 6 minutes. In the end results both achieve roughly the same discharge time, even though from the outset it looked like LG cells spec sheet looked better.
So why? This is because the frequent temperature protection resulted in LG cells consuming more energy (energy is lost through heat dissipation) and we couldn’t get all the energy from these cells. BAK performed much better in this environment.
We also did some reference tests to see what happened and we found the internal resistance of BAK cells is lower which means it consumes less energy when working. The internal resistance of the battery cell affects a lot on the cell’s performance, especially for high power output scenarios.
Battery Brand
Model NR
Rated Capacity (mAh)
Voltage
Internal Resistance (mohm)
Max Discharge Current
BAK
N18650CL
2900 mAh
3.6V
≤35mΩ
3C (8700mA)
LG
INR18650 F1L
3250mAh
3.6V
≤70mΩ
1.5C (4875mA)
Pack Performance vs. Cell Capacity
So why do we focus on pack performance is because the purpose of Omni Ultimate is to provide a power supply solution for high power electronic equipment such as laptops, drones, video equipment, and even though you can charge your phone and tables, that is not what the Ultimate power system is optimized for.
The cell capacity shown in the spec sheet is standard capacity in a specific environment with specified output current (which is called a lab test results). But in a real world scenario, what we care about is how the cells performs once put together as a pack, going through real-world testing situations. So our goal at Omnicharge is to do our best to find the battery cells with high power performance and capacity utilization in the most demanding use case scenario.
So as for the cells rated capacity vs the cells effective capacity, we’ve chosen to use 140wh effective capacity instead of the cell rated capacity. We apologize if this created any confusion and if you felt mislead. But our reasoning is if the LG pack which is 140wh performs the same as the 125wh pack from BAK, then the end result is the same. We wanted to give you the final performance results which in hindsight we probably should have listed both for better clarifications. And we are learning based off your feedback and we need to improve our communication and transparency throughout this crowdfunding process
Going back to the beginning and where we are today….
When we first launched the Ultimate campaign, this was a product idea, an innovation we wanted to bring to the market with your support and backing. We chose to crowdfund because inherently product development is risky and product outcome is not guaranteed. But through hard work and dedication, and with your support, we have gone through four campaigns, all of which have been delivered into your hands and we have received many thank you notes from our supporters.
This Ultimate campaign has been particularly hard compared to our other campaigns since we pushed our limits on the power engineering design and also came to market with features that were first in the industry. Raising $1m on crowdfunding wasn’t enough to bring this item to the market, once you’ve factored in the R&D, tooling, and manufacturing setup, we already invested our own money in order to fulfill all of the orders to you our backers because that is our promise, and we hold ourselves to a higher standard since we treat our backers as our own friends and family.
Our goal is to bring you a product that works in the real world. If you measure us in that sense, this campaign is successful. If you want to measure us based on our communication or our accuracy on spec sheets, we definitely have room to improve. But at Omnicharge we stand behind our work and engineering, we have dedicated our lives in bringing the best power solutions to market, that is what you’ve backed and received. And so far it seems from all the feedback, the product works as intended despite the debate on capacity ratings.
I can only ask you to remember that this is crowdfunding, you are the early adaptors that support crazy ideas from makers like us. We are not perfect, we are not a Fortune 500 company like Apple, Google, and Samsung, where they have unlimited money and people to handle everything. But even then for those companies with unlimited resources, they can also make mistakes when delivering new products and innovation.
For us, we are delivering the best performing Omni Ultimate that we can deliver to you today. We ask that you look at this beast, look at the performance, look at the design, look at the engineering, and look at we’ve brought to the world today. Look at how we were able to bring you a version 1.0 product that is also almost perfect. We can only ask that you forgive those errors that we’ve made in communication and promise you that we will improve. Let’s put aside the 15 wh viewpoint difference between us, and celebrate that the Ultimate is born.
Regards,
Jason Wong
Omnicharge CEO
Why are they comparing the BAK to an LG F1L and not a premium cell like the 30Q or MJ1? The price per battery shouldn’t be an issue in a product of this caliber.
I’m sorry, but what kind of trickery are they trying to do here?
That’s damage control alright. They are using a bait and switch tactic.
The LG F1L is already an inexpensive cell, so going with a BAK cell means they want even higher profit margins.
If they really cared about the performance, they would’ve gone straight to using 30Qs.
They are lying so much it’s not even funny. These greedy people are not making me too happy.
And they thought we did not know about them using NCR18650GAs in their 1st product.
Oh my they are wrong.
It’s time I employ my tactic…
It’s not the price that’s making me angry though.
If they recalled wanted to get higher performance for a lower price, just go with a 2000-2500mAh 15-20A Chinese cell.
That would’ve been understandable. Not good, but at least understandable and better than this crap.
Seems like they were planning all along to use NCR18650GAs in their 1st product to get some good review, and then they went to make a 2nd gen with the original expectations.
After their official statement and test results that are nothing but pure BS, funniest part being even the cell they supposedly chose for its glorious high discharge capabilities, also got over 65°C at a low discharge rate of ~15W/cell.
Good and bad news….
Bad news is they admitted the use of Chinese cells and are not planning to deliver the promised and advertised product, they just changed the specs instead. Specs no longer says 40,300mAh now just 34,800mAh instead. So we’re either keeping a $350 powerbank with about $12 worth of Chinese cells inside, or receive a full refund.
That that’s where the good news comes in… I’m not sure if this applies for everyone but Omnicharge is offering me a full refund as long as I return the Ultimate and all the accessories, also they might request me to cease fire to their IGG comment section, which I admit it was driving some people crazy. Some of them simply didn’t care for whichever cells were inside they just wanted to receive it.
So what do you think, should I return everything and get my $500 back? My reasoning says yes, but my heart says no, I had so much faith in this product and found a lot of uses for it.
No, don’t get a refund.
You’ll have to ship back a lithium ion powerbank via air!
That is going to cost a stupid amount of money to ship.
I think they are trying to bribe you out.
Even if they are willing to pay the full amount including shipping, I’d still stir up the pot so they feel the fire under their feet.
It still boggles my mind they were using NCR18650GAs in their 1st product, but then swapped them in the 2nd product.
IF THEY REALLY WANTED HIGHER PERFORMANCE AT A LOWER COST, they should’ve went with Samsung 30Qs instead.
I have the impression they got their cells at 1$US/each, which is 2-3x what Samsung 30Qs/NCR18650GAs cost in bulk.
No actually I’m unable to ship anything with any kind of batteries in it via air so they accepted to not return the battery pack.
And even after I return my unit they can’t shut me up on any of the platforms, maybe except their campaign page.
To be honest I’m pretty tired of the situation, I tried my best to summarize everything on the reddit thread and will be uploading some test results soon, but have spend so much time… do you say I should get a refund without returning the product?
Yes, get a refund.
In the meantime, try to get everybody to request a refund.
Even better yet, request Omnicharge to get a % refund based on the capacity loss.
40,300mAh/34,800mAh = 1,16 = +16%
IMO, they should just give a 20% refund to everybody on the kickstarter. That would help to soften the blow.
Just got my Omni Ultimate.
This is what I find strange. On the MR30 DC output connection the grouped ones are negative and all the adapter cables have them shorted while the isolated pin is positive. Why the different setup on the connections? Could they be using a diode as a way of measuring temperature of the battery pack by measuring the voltage drop on the other pin.
The manufacturer said that they include an adapter with every spare battery to charge it outside of the device with the included Meanwell DC power supply. I wonder what that adapter is like. Also, is there a boost circuit in the battery or adapter itself, since the DC supply is only 18V?
Weirdly the one MR30-DC output adapter cable that came with the powerbank reads DC12V IN on it. But those pins don’t match the polarity on the battery. This might be a bit hazardous if you mix up the cables and try to charge the spare with the wrong one.
Glad you got yours, it’s been a long wait for sure.
This is why I didn’t use the factory MR30 connector to test the battery, that would basically short the “signal” negative output with the positive, very odd indeed. The MR30-DC connector has negative shorted with the middle pin.
It would be very interesting to find the charging circuit all inside the battery pack. But if that’s the case their decision to cheap out on the cells is beyond my comprehension. So much engineering and design just to make it all worthless by pairing it with mediocre cells.
I’m curious to see your tests with the Ultimate. Specially the 12V2A discharge test via USB-A so we can compare it with my results.
I’ve got a busy couple of days, but I managed to do an AC discharge test with a 60W incan bulb. Total capacity was 101.32Wh. I still have to discharge the battery to find out the true efficiency.
One thing that was a bit of a disappointment was the decline in AC voltage during the test. The original Omnicharge didn’t exhibit this. The Ultimate started out at 230V unloaded and dropped down to 213V after turning on the bulb. Just before cutting out the power the voltage had dropped to 198V. With an incan bulb this means a significant decrease in light output over the battery life. With universal voltage SMPS devices this doesn’t matter though and I would rarely use anything with a linear PSU with the powerbank.
The battery voltage was 3.2V (19.14V/6) when empty (had some time to bounce back though) so they are pretty conservative with the LVP.
Verified that the center pin of the battery is used for battery temperature monitoring and the temperature indicated on the display is measured from the battery (just like it says).
Four data points with the hottest (40°C) after 100W discharging, 30.2°C right after charging, 21.5°C after overnight in room temperature and 14.8°C after a while outside.
USB-A QC 12V/2A: 112.17Wh. Very much in line with 125Wh battery capacity with 90% efficiency.
Measured the battery capacity straight from its MR30 connector at 123Wh. Discharged at 25W constant power down to 3V per cell (18V).
Actually that’s not bad, just ~1Wh per cell shy of the Sanyo GA.
The adjustable CV/CC output works nicely with a string of LEDs. Here’s four Nichia 144AMs in series (4x6V) run at 1 amp. Just set the output voltage above the forward voltage of the LEDs and adjust the brightness more precisely with the current limit. Just have to use LED (s) with a Vf over 5V since that’s the minimum the Ultimate does.
How are these holding up?
Did they cut any additional corners besides swapping in cheaper batteries?
Sad to see quality fade happen in real time.
Is the Indiegogo page claim (also for the replacement battery they sell) of “40,300 mAh” supported?
No, it’s actually 34800mAh now.
