Now we have an alternative to those AA 15mm flashlights. I think that they will fit ¿or they will be too tiny? 12mm anough to fit 15mm hole?
Pity it's high, low, strobe. And 9Hz is the most probable frequency for causing seizures....
But.... suitable for 15mm replacements? for AA flashlights?
Also, may fit on smaller ones as black cat?
ummm probably I will get one
Expanding the diameter somehow is probably easier than decreasing it.
I just took a look inside the black cat and I think it might very well fit. The black cat pill consists of two parts so you have some play height-wise. It probably needs additional insulation though.
I just hope it is no next mode memory thingy.
Like I said onDX : most AAA light have >12mm driver tube size (12.2mm) so if the specs a right (big laugh) you'r ok.
Aloha and welcome to BLF pipopopo!
Nice, you make me feel welcome with the Hawaii flowers and stuff; Merry christmas back to you from a white snowy Europe.
on topic: I ordered one of these drivers: will give some feedback when it arrives.
Greetings pipopopo. Good to have you here!
I hope there's something extremely bright in your stocking tomorrow.
Thanks!,
too bad the sock was empty (I know I should have been a good boy)
I had a great meal though..
