Thank you Contactcr for the values! Thatās interesting, it confirms my impression that the CCT is a slight bit under 5000K and the CRI right around 90.
I just received mine today and this is a great light! Iām already liking it very much!
I definitely appreciate the ability to run on high for lengths of time, running a battery with enough capacity to support that. The Moon is a great level, and Iām very happy about the nicely logarithmically spaced brightness levels!
My first of two arrived ā¦ I love it. Installed my Towild silicone diffuser and instantly turned my new TO50R into a lantern. The Towild diffuser is a perfect fit. I am super pleased with all aspects of this setup. Acebeam 21700 5100mAh batteries are a perfect fit as well ā¦
Have not received mine yet. Tracking shows the package has not moved since 12 days. Last time I saw that, the package was sent back to China because of li-ion battery and tracking will not show you that. I wrote to Jason from Wuben 2 days ago to check if they did not received it back but I never had any answerā¦
I would say that is because they drilled the holes in the wrong place. The mpcb looks perfectly fitted for screws in the adjacent hole with enough space to fit the optic in without issue. Someone, somewhere along the line screwed up and they used a patch job to fix itā¦
By the way has anyone elseās flashlight come with oil and aluminum shavings in the top threads? I had aluminum shavings underneath the o ring, in the threads, and inside the battery tube that I had to clean out when I got mine. The bezel had machining oil on it as well, inside the three indentations. Also, arenāt the square threads a bitā¦ thin for what you would normally find on a flashlight of this price? Itās a nice flashlight and all, but the build isnāt exactly up to snuff for what it was billed as. The finish quality and attention to detail of my C8F is above that of this flashlight, and I paid significantly less for it. I know weāre mostly paying for the driver, but stillā¦
I disagree, you can clearly see in the photos from straight above that the unused screw holes are further in from the edge of the MCPCB, I canāt imagine them lining up with where the screws are actually mounted.
My point was that the screw holes themselves were cut in the wrong place because there is nothing that could possibly be obstructing them to prevent moving the screw holes a bit inward. The only things that need to be there are the aluminum that forms the shelf, the wires (which run down the center), and those two screws.
If you want the LED to be aligned in each corners of a square when you are holding the flashlight with the switch above, two legs of the TIR need to be on the vertical axis, the 2 others are on the horizontal axis.
They drilled/tapered the 2 holes for the screws on the horizontal axis while they should have drill it with an angle compared to the horizontal axis, right here :
They used 2 holes reserved for the legs of the TIR so they needed to cut it.
Ah I see exactly what you mean, the screws are 90 degrees from the leg holes vs those spots being used for the legs.
I guess Iāll give them the benefit of the doubt and assume there was some reason for it? I know the D4 and PL47 both cant fit all 4 legs of their optics for whatever reason either.
I mean you could bead blast it, but Iāve never bead blasted anything and had a resultant texture be āgrippyā. Generally, the bead blasting would strip the layer that I intended to remove and did very little to significantly change the texture of the material underneath. If I were you, bead blasting would be a no-go for this sort of thing.
I just received the two I ordered. The packaging and initial appearance of the light looks very premium like Olight, Acebeam, and Armytek. However, once you start twisting it open and looking it upon close inspection, it still is not there yet, but still look better than most of the cheaper brands. I also see the crushed legs of the optic but I wouldnāt have noticed it if not mentioned above.
Iām surprised how bright it is. 2,970 lumens on turbo and more stable than most other lights Iāve tested on turbo. 1,380 lumens on high mode. Low mode is 14 lumens with no moon light unfortunately. This is on fully charged stock batteries measured at 2s. Didnāt see any output boost by using Samsung 30T.
Wuben told me it was an LG M50T but Iām surprised the wrapper says 4800mah. The battery is too long to fit my charger so I canāt test the capacity. It is a tad bit longer than the Acbeam 5100mah protected cell.
The beam is smooth and floody. Appears warmer than the XP-L HI 3A on my E07 and also more green but doesnāt bother me unless I compare it side by side with Cree A or D tints.
The size of the light is a good bit larger than the Acebeam EC65 but Iām guessing itās because of the dual switch and larger driver?
I still donāt like the two black side switch that is extremely difficult to locate in the dark. Wish they can fix that. I prefer power switch located at the rear for ease of access.
Overall, I am pleased with this light and I intend to bring it with me on trips because of the very useful usb power bank feature.
I actually find that this is one of those things Iām not having a hard time doing. My clip is tight enough around the body that having it on the oposite side of the switches allows the clip to actas a guide for positioning the light in darkness. The notch uses one of my fingers as a self positioning guide and the height difference between the two buttons is easy to feel for. However, the actuation force for each button is higher than I would have liked. It does help prevent instances of accidental actuation though, so I canāt complain too much.
