Sofirn SP70 Alone $50, PM for AMZ US CODE(LIMITED)
2245 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 2 weeks 2 days ago
The Switch PCB has double SMD emitters on each side, ultra teeny tiny flea like resistors (no idea what value, they’re too small to read if indeed there are numbers on them) But the switch is too bright, for sure, I meant to do something about that and forgot.
Oh, by the way, Sofirn cut a vertical slot across the hole the switch sits in much like we’d do with a file come modding time… Result? You can pull the switch board through the hole through this slot without de-soldering the 4 red wires (yes, all 4 are red)
JasonWW
JasonWW's picture
Last seen: 1 day 33 min ago
Nice that they remembered to do this. Until you mentioned it, I completely forgot that I had asked them to do this. Does the switch PCB have the resistor to control the brightness or is the resistor on the driver?
Scallywag
Scallywag's picture
Last seen: 3 hours 23 min ago
That's good, considering they're all red. I'd screw that up.
I forgot my charger is .5A, so I won't be playing with these today.
Does anyone have recommendations for a charger with good analyzing functionality? Could even be just 1- or 2-bay as I'd only use it for the special functionality.
Old Lumens Contest 2020 - Hand-made light category
ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20 | Baton S1
Boruit D10 w/ Quadrupel Fet+1/Anduril | EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S15 Ti | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special | Thrunite T10Tv2
Supfire M6 3xXHP50.2, Sofirn C8F, Unfinished: Sofirn SP70, IYP07/Tool AAA hot-rods, Jetbeam E3S
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
DB Custom
DB Custom's picture
The tiny resistors are on the board, one on each side.
I used a magic marker to mark one dot, two dots, three dots, four dots on the wires just in case, then took a photo so I’d see where they were positioned on the board. Didn’t need to take them off in the end.
Funtastic
Funtastic's picture
Last seen: 20 hours 41 min ago
the4ds9 wrote:
I discovered by reading the Owner’s Manual the Group 1 (Non-ramping) has six brightness levels. The Turbo mode brightness in Group 1 (Non-ramping) is only available by double-clicking the side switch.
That’s normal with a lot of the Sofirn models
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
Funtastic
Funtastic's picture
My second SP70 arrived today and tested as stock and get 4500 lumens at 30 sec. Put on the bypassed tail of my other SP70 and gained 600 lumens.
The springs they used aren’t very good
BlueSwordM
BlueSwordM's picture
Last seen: 2 days 18 hours ago
They are actually using great springs.
It’s just that they aren’t up to snuff with the type of springs we use here on BLF.
Also, seems like you are getting very low numbers overall.
Funtastic
Funtastic's picture
We’ll see what Jason’s results are as he has the same setup as me.
My numbers were 100 different than Matt’s with the Convoy L6 so it must be near accurate
BlueSwordM
@Funtastic, could you check if the springs are magnetic?
They should not be.
DB Custom
DB Custom's picture
Blue, the springs in my tail cap are magnetic enough that the entire tail cap can swing from a small magnet on the leads of my CottonPickers charger.
Funtastic
Funtastic's picture
BlueSwordM wrote:
@Funtastic, could you check if the springs are magnetic? They should not be.
My neodymium magnets stick to them
BlueSwordM
Wait, wait.
These were supposed to be using BeCu springs.
How come Sofirn of all companies did not use AT LEAST a cooper alloy?!
It all makes sense now why Sofirn were beating around the bush.
They told me they were going to use a copper alloy, in the past.
Someone changed something somewhere.
A BLF edition is absolute needed now!
I’m not mad though. Just dissapointed.
the4ds9
the4ds9's picture
I am thankful for this informative thread. I was getting ready to buy some Aspire and/or Golisi S43 26650’s. Based on my trial of the Efest Purple 4200 50/35 26650, EBL 5000 26650, and Sanyo UR18650NSX, there’s no Wow-factor to be gained with use of Golisi or Aspire. Even the “cheap” EBL 26650 is fine and an upgrade to an Orbtronic 5750mAh 26650 button-top for longest runtimes makes more sense, based on my reading this thread and already having compared EBL to Efest and Sanyo batteries, in my Sofirn SP70.
Funtastic
Funtastic's picture
Sofirn are using two different XHP70.2 bins for the SP70. My first one has a cooler tint and achieved 5900 lumens and my second is slightly warmer and is only 5300 lumens. This is slightly annoying
Before I noticed the tints I thought it was my solder joints so I re did them. I also built up solder around the driver in case the tube wasn’t tightening. Tried exchanging things with my other but it’s definitely the tints
JasonWW
JasonWW's picture
So this new tint is a bit more towards neutral white?
I have not heard anything about them switching tints in these current models.
djozz
djozz's picture
Last seen: 55 min 49 sec ago
BlueSwordM wrote:
Wait, wait.
I’m sure they used steel springs, changing habits is a difficult thing for chinese companies. Even if a change is an obvious great improvement in our flashoholics eyes and even by objective tests, they are weary to implement it as the first ones doing it, any change is seen as a risk. Only if competing companies prove to be profitable by implementing a change, there is a clear willingness to also go for it. (why would using copper alloy springs give us an advantage while high end companies like Olight, Nitecore, Fenix do not use them? There must be a downside somewhere!)
Btw, your first batch of springs are slightly magnetic too because of the nickel plating, I do not think it is the case but in theory they may have used a copper alloy with very heavy nickel plating.
Funtastic
Funtastic's picture
How much variation can exist in the same tint? At first glance it looks cooler than the other but the more I stare at it I’m not sure.
If it’s not the LED then it’s something on the driver causing a much lower output
Can’t do anymore testing as I’ve already sold them but have another 5pcs on the way
JasonWW
JasonWW's picture
At least 400K. Like 6100K to 6500K, etc…
BlueSwordM
@djozz, I know about my first batch. They are very slightly magnetic. But not to the extent of real steel springs.
It’s heavily nickel plated since I always specify the plating thickness for easy solderability. It does make the springs slightly more expensive, but it is worth it since it’s almost impossible to sand off, and makes soldering very easy.
It does make me wonder one thing: how how are the springs getting?
Because if there is 12A flowing through even dual steel springs, their temperature must be extremely high.
Also, I mean, Emisar, Astrolux, Acebeam, Lumintop are using copper alloy springs in their high power lights
This is what surprised me honestly.
The reason I actually suggested to Sofirn to use BeCu springs was to stop them having to do spring bypasses on their lights. Would surely save them money, time, and employee time.
DB Custom
DB Custom's picture
Used mine in the rain this morning, taking the trash can walk. The beam is large enough to be useful in a general purpose setting, bright enough (especially modded) to be impressive, and the light is easy to hold and operate even in rain. I have to say I’m impressed, in spite of some possible small shortcomings I like it. They did good, again.
Pretty sure too that a Nickel plating wouldn’t be strong enough magnetically to swing the entire tail cap from a small 6mm dia magnet. Wink
JasonWW
JasonWW's picture
Okay, I did some lumen testing on the SP70 with the Sofirn HD 25A, the black Liitokala and the Aspire 4300 with my Texas_Ace Lumen Tube and Maukka calibration light.
I noticed the light didn’t get hot as quickly as it did during my tail cap amp draw test. Sure enough, the springs on the tail cap do reduce output, so I did tests both with the stock “tail cap on” as well as with a short 8ga wire eliminating the tail cap resistance. I took measurements at Turn on and 30 seconds.
SP70 —————————————— T.O. —— 30s.
Sofirn HD 25A with tail cap – 5270lm, 4890lm
with 8ga wire across the tail – 5800lm, 5390lm
Black Lii 5000 with tail cap – 5250lm, 4700lm
with 8ga wire across tail – — 5570lm, 5200lm
Aspire 4300 with tail cap – 5080lm, 4720lm
with 8ga wire across tail – 5900lm, 5350lm
I took the wire across the tail measurements first then took the tail cap measurements second with about 3-5 minutes of cool down time in between, no recharging. So the “tail cap on” measurements might be a tad higher if I had recharged the cells fully in between, but not significantly higher. I just didn’t have time to do full recharges between every test.
These numbers are quite impressive. They are pretty much equal to my Lexel made FET driven L6 with bypassed springs dual BeCu springs from BlueSwordM and 5700K emitter from MTN E. I tested that light with the same black Liitokala 5000 and Aspire 4300 cells. I measured the L6 a short time ago with the tail cap on. I did “Turn on” and 20 seconds because the light got hot so fast. Here are the results.
Modded L6 ——— T.O. —— 20s.
Black Lii 5000 – 5300lm, 5100lm
Aspire 4300 – 5500lm, 5250lm
The Sofirn HD 25A cells also seem to be impressive. They beat the black Liitokala’s (maybe 60 cycles on them) and are really close to the Aspire 4300 cells (maybe 20 cycles on them). The Sofirn HD cells did not seem to draw the same amperage as the other 2 cells, yet the lumens don’t reflect that. It makes me wonder what spring bypass wires alone can do.
Just remember that lumens are tricky to measure with high accuracy and the Turn on numbers just flash for a quick second so I’m not sure how accurate that is. Maybe 1 second numbers are more accurate.
I also measured the parasitic drain at 1.88 milliamps. This is a lot lower than on the S70S which had a 4.43 milliamp drain. So it’s better, but still pretty high. I wouldn’t leave it powered up for months on end. Turn the tail switch off for any type of extended storage.
I plan to do a review thread with all my measurements and beam shots put together. I’ve just been super busy the last couple of weeks.
the4ds9
the4ds9's picture
Impressive! Party Thumbs Up Thanks!
DB Custom
DB Custom's picture
Jason, you need to charge the cells and test again with the tail cap… that 30 second run with the wire bridge took a hit on the cells so your next reading is going to show significantly lower. Not a fair comparison test at all.
JasonWW
JasonWW's picture
I’ll try it when I get another chance. I think it will be in the same ball park, though.
djozz
djozz's picture
Nice set of output tests Jason! Thumbs Up
JasonWW
JasonWW's picture
One small correction, I actually installed dual BeCu springs from BlueSwordM in my L6. It’s not bypassed stock springs.
Satan@103TFS
Last seen: 1 day 6 hours ago
My number of SP70 is close to Jason for reference I give a lumen of stock S70s NW (look like the same tint as L6) and L6 OP XHP70 N4 3A
(0s/30s)
stock S70s NW Lii50A = 3648 / 3553
stock L6 Lii50A = 3382 / 3303
stock SP70 Lii50A = 5320 / 4845 Sofirn HD = 5415 / 5130 Shocki 5500 = 5510 / 5092
(with bypass 20 awg both drivers/tail keep dual springs) Sofirn HD = 6156 / 5662 Shocki 5500 = 6242 / 5871
My measure may not so accurate but should not far behind . Sofirn HD is quit good comparable to Shocki 5500 but I don’t measure capacity yet will report back
JasonWW
JasonWW's picture
Neat that we are getting such close measurements.
I guess I need to solder blob my Shockli 5500’s so I can test them out.
I have not tested the capacity of my Sofirn HD cells either. I haven’t had a chance to run them down yet.
So it looks like the BLF edition just needs some better springs and it will see a big jump in performance. Nice.
DB Custom
DB Custom's picture
A better MOSFET and larger leads from the driver to the emitter makes a big difference too. Wink
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 3 hours 40 min ago
Your numbers sound low Jason could the larger lights play with your sphere? Cause it to give weird numbers? I would think your modded L6 would do close to 9k lumens? If you do a ceiling bounce test between the two are the numbers still close?
The amount of current doesn’t add up to the output you get even if you add loses for the reflector and lens.
