JasonWW
(JasonWW)
May 3, 2019, 6:41am
9809
TK, is there any combination of button presses that can make the light turn on at a medium level and then not respond to the switch anymore?
I let a newb check out the light and he did some crazy button clicking and it did this. I had to cut battery power to get it back to normal. It was odd.
Johm
(Johm)
May 3, 2019, 7:10am
9810
JasonWW:
Could be you have made a good start at discovering the ester egg.
First to the key, first to the egg.
(for those that have seen the movie Ready Player One)
mortuus
(mortuus)
May 3, 2019, 7:52am
9811
i ordered 7a, is there a way to know if i got into it or not ? i thought there would be alot more then 330 since the list is so big ?
JasonWW:
That sounds like they managed to knock the button signal tube out of place or something. But usually if that happens, the light shuts itself off.
M4D_M4X
(M4D M4X)
May 3, 2019, 8:46am
9813
the FW3A is such a beauty! :)
teacher
(teacher)
May 3, 2019, 10:27am
9816
It sure is & those are great pictures too!! :+1:
yanya
(yanya)
May 3, 2019, 10:29am
9817
M4D M4X
great video and great photos
copper would require an additional insulator because it cannot be anodized to be an Isolator as Aluminium.
M4D_M4X
(M4D M4X)
May 3, 2019, 11:45am
9819
the inner tube can still be used on other materials I think?
that would be an option, jupp
By the way: Is there a “shipping proges page?” I am #30xx and would like to know, when I could “roughly” expect shipping…
Neal
(Neal)
May 3, 2019, 12:07pm
9821
pls PM me the order number
pennzy
(pennzy)
May 3, 2019, 12:08pm
9822
Why not run a wire inside the tube rather than a inner tube? Just wondering.
JasonWW
(JasonWW)
May 3, 2019, 12:37pm
9823
How would you connect the wire ends to the driver and switch when they all rotate independently? Seems pretty tricky.
pennzy
(pennzy)
May 3, 2019, 12:49pm
9824
There’s my answer looking me in the face. I guess I didn’t think it through .
hodor
(hodor)
May 3, 2019, 2:37pm
9825
Bead blasted titanium gets my vote. Other aluminium colours could also be tempting.
…Or silver / clear version?… runs and hides … Only kidding, I don’t like these as they can’t be hard locked out.
Tally-ho
(Tally-ho)
May 3, 2019, 3:05pm
9826
But not impossible.
HDS is using a wire with a rotating head and a fixed MCPCB for the button, Novatac is using a spring with a rotating head and rotating button.
The end of the tube on the driver side of the HDS is anodized, the trace on the MCPCB is for the end of the wire.
teacher
(teacher)
May 3, 2019, 3:12pm
9827
Tally-ho:
But not impossible.
Interesting design, thanks for sharing Tally-ho. :+1:
Tally-ho
(Tally-ho)
May 3, 2019, 3:21pm
9828
The spring of the novatac is working the same as the inner tube of the FW3A, but with time if the spring wears off, it won’t be a problem due to its adaptable length.
