Yes, and mine is still the factory calibration which could be off a little. I’ll try to see if it’s accurate.
With a high capacity 3400+ cell you might see a bit less lumens, but you’ll probably gain extra Turbo time. I’ll try out some other cells I have laying around.
I also have all 4 of the Carclo lenses and the stock one seems to be the best, in my opinion. The clear 07 is a tiny bit tighter focused, but I see yellow streaks in the hot spot when shined on a whitewall or equivalent. Eh, it’s not worth using in my opinion. The 08 and 09 are nice if you need a wider spot, and don’t need the distance.
The 10511 is called a narrow spot. 22° (lightly frosted)
The 10508 is called a medium spot. 27° (heavier frosted)
The 10509 is called a wide spot. 40° (heaviest frosted)
The 10507 is the non-frosted, clear version with a narrow spot. 18°
Actually, it would not surprise me if the physical dimensions of all four lenses we’re identical and the beam angle difference is strictly due to the amount of frosting on the surface. Here is a picture in the same order as above.
My FW3A is saying it’s 38°C, when room temp is about 24°C. I’ll make sure it’s fully cooled down internally (when I wake up later) and then check it again. At the moment, my light is probably stepping down a little bit prematurely. Once I reset it, I’ll measure the stepdown time again.
Maukka got 20 seconds out of his light with a 30Q, but he calibrated the ambient temperature as well as bumped the default step down temp of 45°C to a slightly higher 55°C.
If there is a FW3C or FW3T or FW3B, the inner tube will probably still be anodized aluminum. It’s not there to look pretty; it’s there to carry a signal without electrical interference.
The other metals mostly just change the appearance and weight and thermal properties. They don’t really change anything about the light electrically. It was designed to work with bare aluminum, so the anodizing of the host doesn’t really serve an electrical purpose (except on the inner tube). Even the anodized aluminum version can’t be hard locked out. If I turn the light on and then start unscrewing the head, it gets well past the O-ring before the LEDs shut off.
I’m guessing that’s what JasonWW’s friend did — just loosened the tube a little so the switch wasn’t connected any more.
On mine, I’ve measured 125 lm on one light and 126 lm on another. So, fairly close. At first I got higher numbers, but when I checked my calibration light again I found the calibration of the tube had changed… so after fixing that, it was a few lumens lower.
Now I calibrate the tube before each batch of measurements. It’s fairly simple to do… just measure the reference light and plug that number into my conversion script. The multiplier is the expected lumens divided by measured lux. Then measure a couple other reference lights to make sure they’re all still in agreement, and it’s ready to use.
It could be lower, actually… but when I had the parasitic drain even lower, it was nearly impossible to exit from momentary mode. The head of the light had to be removed for over a minute before it finally drained enough to reboot, so it was necessary to hold the button to keep the light on, then unscrew the head.
Not really. The closest I’ve found is a Fenix AOD-S, but it’s not very good. It’s an odd shape, the material is much thicker than necessary, and it has poor optical properties. Most of the light still goes forward instead of sideways, and it splits light like a prism so the yellow parts go forward while the blue parts go sideways. It can even make high-CRI 219B lights look ugly.
The message I got from Neal’s Gadgets about my FW3A shipping gave an order number, which then revealed a tracking number on FlyTExpress. Status showed “EN ROUTE TO DHL ECOMMERCE” on 4/30, then it updated with FlyTExpress on 5/04. When I went to DHL’s site to test that tracking number, it doesn’t recognize it. Is this still a proprietary number that will convert to a DHL tracking number later once it leaves China, or will same number start to show a valid tracking status? The number I was given is F32706190430003A.
How would the LH351D compare to this? Apart from the whole flood/throw thing that is (which I find ridiculous anyway, wanting to get max throw out of a triple EDC light just seems contra-productive to me). I believe I have read it’s more efficient than the SST-20, is that true? I only have SST-20s in 3000K in a D4 atm, and I actually prefer the higher green content in the lower modes. If the LH351Ds are brighter while producing less heat than the SST-20s I’d probably want to give them a try. Anyone know where I can get a pre-soldered high quality triple board (I’m assuming it should be a DTP copper board)? I’m in Europe so I’d prefer shipping from China instead of US. I could solder them myself, but would rather not, also buying 3 LEDs and paying like 5-6€ shipping isn’t really worth it for me lol.
Well, the LH351D 90CRI are more efficient than the SST-20, but they are much floodier than the SST-20, so the relative efficiency of the SST-20 is actually higher than the LH351D since you don’t have to use as much power to see slightly farther.
He didn’t loosen the tube, he just clicked the switch.
I duplicated it once. I’m thinking the inner tube was just barely making contact and heavy switch pressure pushes on the tube (since there is no retaining ring on the switch) possibly creating a gap on one of the ends. I may need to clean the contacts and make sure I tighten both ends a bit more.
May 4 04:44
In transit - Departed waypoint
Flyt Express’s sorting centre, Guangzhou
May 4 02:39
Package in transit
May 4 02:34
Package accepted
April 30 11:31
Transfered to the local postal service
Flyt Express
April 30 11:30
Electronic shipment information received
Flyt Express
………. ’Most likely’ that number will not be a DHL number once DHL gets the package. But this tracking may update all the way to delivery.
