There is no doubt this LT1 lantern can be a big interest outside for the general public eventually, as it fills a gap for a good quality area light/lantern that has recharability along with battery replacing, high CRI tint, functional design. portability, long-term off-grid uses, great modes, built out of metal (wont blow off the camp table like some plastic ones do i seen) the list goes on.
Awesome, thanks everyone! Man this is cool. Put me down for 2 more, for a total of 4 please.
On the note of bringing in burning man people, I’m torn. I don’t want to bring more noise into this thread, but I do want people to appreciate this light. Maybe sofirn would be happier with us if we let the BM people pay full price? That sounds mean and selfish now that I say it. But I kind of feel that way, anyone else?
Also, just my opinion, I don’t think we should have a turbo+ mode. I don’t think there and be any mode that can overheat the head of this lamp. Because there is no efficient way to get heat to the MCU, correct? People could burn themselves. Unless we added a turbo timer? It’d have to be real short.
Maybe make it a config option in the source code? People adventurous enough to compile their own code, or find someone to do it, can be trusted with the extra power. In my opinion. I’m just worried about the people I plan on gifting these to.
Yeah, I agree with BM people having to pay the full price.
We have to respect Sofirn, and BLF itself.
No arguments, that’s why I tossed it out for discussion.
If you’re going to BM and are even remotely interested in leds, then you’ve most likely already found this place. If not, it’ll be a pleasant surprise.
Add me for a third as well as the accessory kit with it. 1055 1056 are my first two. (Are you even tracking the accessory kits?)
Correct.
The plan is to put a temperature sensor in the LT2, if there is one. Also, a constant current driver. This would require more pins though, so the driver would use attiny1634 instead of attiny85. Two pins per channel to control power, or four PWM pins total. Another for the e-switch. Another to control the button LED. Another for the temperature sensor. Another for a voltage sensor, since both the temp sensor and the constant current parts are incompatible with measuring voltage on the VCC pin. Plus ground, VCC, and reset. Etc. At least 11 pins needed.
I’m not looking forward to doing the math and the code involved in making tint ramping work with four power channels. It’ll be a bit tricky. I suppose the tiny1634 will have plenty of space though, so I can actually afford to do the math on the device itself instead of needing low-tech trickery to make it fit.
But first we need to finish the LT1.
Yeah. The code is getting pretty messy with all the compile-time options though, and a “turbo plus” feature doesn’t easily fit into the abstractions the code uses. It all assumes the maximum power is 100, with no means of going beyond that… but in this case, 200 is possible. So I probably need to figure out a clean way of enabling model-specific quirks like this which make no sense on other hardware. I also need to clean up the code in general.
Definitely not at this point.
It wouldn’t be a lot of work to track accessory kits since it’s just an additional column in the table I created for the lantern buy. But as slider said it’s not being tracked and I have no plans to do so.
Once we get the lantern ready for orders, we can start another topic GB I’m guessing for the accessory kit, as i still have to test some of the accessories I’m working on for the sample lantern.
Yeah… tracking options which got added late in the project is a lot of work with questionable value for basically no reward. Not really worth it.
Please add one more for me for a total of 2. I was #1205.
Yeah.
Other than the 4x18650s, accessories haven’t been really planned.
So is there going to be a second round of test units with fixes prior to production or is the plan to roll the fixes directly into production?
I’m interested to hear how the diffuser is affecting output since it looks pretty heavy.
Please add me to the list for a 2nd lantern. I’m currently on the list at #840
I will be doing a test of the diffuser/lens (in comparison to the V1 & V2 tonight or tomorrow.
Add another 1 for me. Originally 550 and 551. 3 total now. Thanks guys
For those interested here are the interest list counts from March on. I don’t have insert dates on anything prior to mid-Feb so I left those counts out.
55 in March
106 in April
81 in May to-date
Wow, you’ve been really busy. I worked on the interest list for about 9 months and added about 500 people. You’ve been at it for 3 months and have added nearly 250! I’ve been super busy with work and definitely would have had trouble keeping up.
Nice work!!
Fortunately it’s not much work . I threw up an Oracle instance on my computer and created a few tables and other objects in it. I wrote a script that I use to insert the user name and post number which only takes a few seconds. Creating the spreadsheets is quick since I just have to query a view on the tables to populate them.
The database isn’t written specifically for the lantern project and is useful for future projects if anyone wants to use it. I’d be more than happy to pass the code on to anyone who wants it.
Sounds like a great addition to my fledgling collection of lights and camping gear. I’m in!
I kinda got lost in the postings but was there a clarification about whether or not the lamp will be glass with diffusion or some sort of plastic alternative?
