Yes it looks interesting but I have concerns that lenses are acrylic/plastic and I can’t see weather it has anodized threads…
It looks fairly well…
I would like that kind of zoomie(or slightly larger) but with anodized threads, glass lens, 25.4mm body, without any gimmick charging ports if possible…
It is very hard to find such one. I’ve been through whole ali and other sites and I can’t find suitable hosts…
It has plastic lens, and while I have nothing against plastic lenses since they will throw further and have clearer die projection than most commercial available glass lenses with LED emitter it does not fit in mine project…
I need glass lens in zoomie(small lightweight and practical zoomie) so that it can hide laser emitter (VCSEL) imperfections or better to say to make them blurry…
This is how VCSEL looks under plastic(acrylic zoomie):
Glass lenses should kinda merge(blur) that imperfections which plastic/acrylic lens perfectly projects…
Do you mean that you want a low prcision lens?
Maybe a precise lens with dc-fix or a frosted/patterned one is what you need?
Hmmm… Yes… I just need classic glass lenses in small zoomie light(they usually are low precision ones?)…
But that idea of frozen patter from underside of lens or even better on top of the lens looks like a nice experiment. Small round “blur” or “smudge” on top of lens could do…
Guys. Please try the challenge…It is almost unbelievable how hard is to find this below:
“Zoomie(budget smaller one) but with anodized threads, glass lens, 25.4mm body, 1×18650 bat, without any gimmick charging ports if possible…”
There is a neat way of removing the anodizing, forget the name bit I have the stuff at home, its a common oven cleaner. Works surprising well at removing any anodizing it comes in contact with,,,,right down to bare aluminium
Sometimes being a newb is the best part of a hobbie
In the context of a laser talk I read your comment as “I want a great host with a bad (imprecise) lens”. I think that’s not what you meant…or is it?
I just wanted small zoomie with real glass lenses and glass lens are usually inferior to plastic lenses and they make blurry die projection in direct comparison to acrylic/plastic lenses wich have ultra clear die projection. I need glass one because I need blurry effect with VCSEL laser die…
So once again challenge for you guys:
“Zoomie(budget smaller one) with anodized threads, glass lens, 25.4mm body, 1×18650 bat, without any gimmick charging ports if possible…”
Been through hundreds of models only Sofirn SF30 is close to that but it has freaking 3xaaa body , and I need 25,4mm one
That is real beauty! I ordered one… Everything here but glass lenses
So why not swapp plastic to glass lens?
I think it is turbo hard to find glass one that will work on place of plastic one… Yes it may fit but focal difference… I would not like any overfocus or defocus(black hole ) issues. So finding that is also Sizifus job
I was able to find all kind of stuff and flashlights but I can’t believe that I can’t find the one I need with mentioned criteria: Zoomie(budget smaller one) but with anodized threads, glass lens, 25.4mm body, 1×18650 bat, without any gimmick charging ports if possible…
Sorry wrong info, looking at too many items at once, link to a driver that is listed that way. Interesting low 3 volts out, Luminus SST-40.2. https://www.aliexpress.com/item/22mm-2-8V-4-2V-Input-7A-Constant-Current...LED-Driver-Flashlight-Circuit/33003164774.html?spm=a2g0s.8937460.0.0.b7e52e0eMlzhNa
I have purchased a couple of lights from this seller JKK70 Manta Ray C8.2 all pretty good in my opinion. But yes it is also listed a 15 watts, 7 amps x 3 volts = 21 watts. Who knows, really only one way to find out.
I am kinda new here and I have been wondering why someone has not attacked the voltage on these low voltage emitters this way. Limiting the output voltage and increasing the amperage.
To increase the amperage going to the LED, you need to up the voltage to the LED by a bit.
Be careful though. Up the current too much(even if the LED can handle it), but gets too hot, and you might end up in a situation of a runaway with an LED, in which it kills itself.
Isn’t an issue with regulated drivers, but can be an issue with FET drivers.
Those look sharp. Too bad that switch retaining ring appears to be pressed in. I’m curious is the charging circuit is on the same board as the main driver components or a separate one.
Haven’t seen this one by Jin Heng mentioned here: SST20 or SST40, 21700, Type C USB charging, ~30USD: https://www.aliexpress.com/store/product/SST20-SST40-LED-Rechargeable-Aluminum-Flashlight-Torch-Type-C-USB-Charging-21700-Battery-Light-Outdoor-Camping/1242423_33004236817.html
I might have to try one. If it’s halfway decent, it would tick all the boxes for a friend I’ve been meaning to get a flashlight for…
Have anyone found a 18650 big reflector thrower as Supwildfire was? I was searching around Ali and nothing interesting there. I would make a mod with Osram white flat or SST40 dedomed version from Kaidomain.
So today I got the ““upgraded” Revtronic F30B”:https://www.banggood.com/Revtronic-Upgraded-F30B-2-T6-800-Lumens-4Modes-...USB-Rechargeable-Portable-LED-Flashlight-p-1337893.html?rmmds=search&cur_warehouse=CN in the mail, the one with USB charging in the tail.
What do you know, it’s another tailcap driver light…. but with a reverse clicky. It seems I’m a magnet for weird drivers, huh.
All that’s in the head is two resistors and a diode, antiparallel to the LED. (The diode is necessary for the TC charger.)
This is the tail driver:
Just a reverse clicky on the other side.
I don’t know what to make of this. It’s a nicely constructed light (paid 13€ for it), beefy body, 5.5mm thick LED shelf, the TC charger is nice & clean & watertight, – but the driver is an overengineered solution to a non-existent problem. And it’s not good at what it does.
The TC charger could be done with a standard driver, all it needs is that extra diode.
(Oh and there’s plenty of space in the head, it can fit a 22mm driver.)
Another one for the ‘project’ bin….
Any good suggestions ? Biscotti?
Sounds a lot like the 4×AAA LuxPro I got. Just a contact board in the head, 2 sm chip-resistors acting as a ballast, and the driver in the tailcap. Hell if I can get it apart, though. Got real ring-pullers, not just pointy tweezers, and I’m cranking it cw and ccw and it ain’t budging. No visible threads to see if it’s got rh/lh threads.
Really nice feather-touch switch, though, so while I suspect it wouldn’t function long as a power-switch, even with puny AAAs.
Should fit a Li cell nicely if I ever do get the tailcap apart, though.
Too bad it has that UI Seems quite pleasant to the eyes, though ;)
At that price, it's probably worth the risk to try and mod. Certainly would immediately swap the LED if nothing else, I'd expect a LatticeBright. The only thing giving me pause is the built-in charging, but I'd honestly be fine with losing that if it came down to it. Or maybe I'd just finally take the opportunity to do a charger myself.
Hi Kikkoman,
Guys. Please try the challenge… It is almost unbelievable how hard is to find this below:
I’ve found a handful that tick all the boxes but “anodized threads”.
It’s sodium hydroxide, lye, NaOH.
Agro,
Why not use a glass lens from Yajiamei in a host that otherwise fits? (Richfire SF-168, 20$, but plastic lens.)
Or on the cheap – 6$ , plastic lens :
https://www.dx.com/p/zhishunjia-yf1017-400lm-convex-lens-led-zooming-fla...
Or, why not re-anodize those threads (it’s not that complicated)?
That TF-Z9, I’m pretty confident it has a glass lens and counting pixels tells me the tube is 25-26mm. But no anodized threads.
Hi Kikkoman,
So why not swapp plastic to glass lens? I think it is turbo hard to find glass one that will work on place of plastic one… Yes it may fit but focal difference… I would not like any overfocus or defocus(black hole
/\ That looks like it might make a nice 21700 host.
Click this to go to signature links. I'm still around, just not reading many new threads.
This one looks super dope too:
https://www.aliexpress.com/store/product/30W-Powerful-Xlamp-XHP70-2-0-XH...LED-Type-C-USB-Rechargeable-18650-Flashlight-6/1242423_32968903816.html
Take a look at the specifications 7 amp CC, 3 volts out, luminus SST- 40.2 ????
Where did you see 7A?
I don’t see anything.
Oh it’s using dual FETs.
Probably CC at 3A, and direct drive at 7A.
I mean, at 7A in linear regulation, the regulator wouldn’t really survive.
Because it doesn’t work like that with LEDs.
Also, 15W for the SST-40 draws 4,6A at 3,27V.
Thanks for the info.
Old Lumens Contest 2020 - Hand-made light category
ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20 | Baton S1
Boruit D10 w/ Quadrupel Fet+1/Anduril | EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S15 Ti | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special | Thrunite T10Tv2
Supfire M6 3xXHP50.2, Sofirn C8F, Unfinished: Sofirn SP70, IYP07/Tool AAA hot-rods, Jetbeam E3S
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
Man that Jin Heng flashlight looks great and has everything I was looking for in a host. However, the press 2sec to turn-off is what turns me away
Nitenumen TK27
@1theDeals
Not that budget but I just stumbled upon this Titanium 18650:
http://www.aliexpress.com/item/4000004827705.html
MY REVIEWS THREAD /// My Flashlight Collection ///
Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Review's Blog (PT) /// OL Contest 2019 /// OL Contest 2020 /// GIVEAWAYs: 1 / 2
