I’m afraid you’re mistaken. Or maybe your light is different from mine. There is a small black pellet that is held in place by the rubber disc. I’ll post a picture of it later today.
The rubber piece has a hard plastic piece glued in place right in the middle. It should behave as one piece, normally… but if the glue gets unstuck, it can come out. If this happens, it’d probably be a good idea to glue it in place again.
Your right Jason, I was indeed mistaken!!
Mine had just stayed together on previous disassemblies. I just now checked & it is indeed 2 seperate pieces… just like you said. :+1:
I guess my glue was not very strong as it popped out easily. I think I’ve got some super glue I can use on it. Luckily my switch assembly stays in place unless I push it out. After playing with the light and trying it without the clip, I don’t plan on taking the tail cap off any more.
I assume we didn’t do it on Kickstarter because of their fee agreements? 5% of funding amount + an additional 3-5% payments fee, afaik and $0.20 per buyer.
So if 3000 people had funded 35.00 $US, Kickstarter would’ve gotten 5250.00 $US from the team plus 1.25 $US per buyer. That is an expensive deal for a simple escrow facilitator that doesn’t take on any risks (or in other words - each buyer would’ve gotten the light for 3$ more to fund the kickstarter fees).
Doing a community design (polls, messaging, consensus system) and fund pooling/shipping system would have to work on any forum, not just BLF, to make it a profitable venture. And the work involved would probably aim at the 5% per “mini fund” as a pay out to make it worthwhile… if you look through this thread a lot of posts are either status request for “where are we” or “design requests” or shipping status and/or similar.
The amount of work for such a system would also require cloning ToyKeeper :laughing: not sure if that is even possible!
Where can I get a little black nubbin, whatever that thing is, to replace the one I lost.
I never even saw it. Didn’t know to look for it. Still got the rubber, but no plastic nubbin, only a little ring in the rubber where a nubbin is supposed to be.
It’s the nothin’ nubbin. Definitely effects switch operation.
/\… Good pictures Jason. Turns out mine was glued & holding, that’s why I thought it was one piece. But a tiny bit of side pressure, applied on purpose; knocked it loose easily.
Solution… clean it all up real good & reglue with some good Super Glue or any good glue.
It might be a good idea to have the whole diaphragm switch ( metal cup acts as a spring actuator that is retained by the kapton tape) plus the boot with plastic plunger available for purchase. I would buy a few, just in case.
I definitely can make that nubbin, assuming it’s ABS plastic or similar. I have a micrometer to measure the hole size, what’s the length?
That little ridge in the center might be difficult, and it seems slightly tapered on the switch side. Hmm.
For the record, this will be my first “mod”.
I don’t think finding the old nubbin is an option.
Probably won’t make much difference what you make it of. And that little ridge & taper… personally, I would not worry about that at all. That may well just be dried glue.
I wonder why they did not just mold the nubbin as part of the whole to begin with??
