@X3, since you live in france, I can throw a 219B 4500°K and a 219C SM4070e in an enveloppe if you give me your address in MP. Can’t do more, I don’t have much left.
SST20 3000K, triple MCPCB from KD (1mm thick) and their optic (really smooth beam), plus a small alu spacer that I made today at work.
I had to add some length to the stock wires, but the good news is that the stock pill already have a 4mm hole right in the center.
It’s not waterproof anymore, I like when the optic sits flush in the bezel but it’s doable with an o-ring too.
I love it already.
Oh, it does 600 lumens on the highest mode too… not too shabby for a 95CRI 3000K source !
(the precedent LH351D with stock reflector was about 470 lumens, talk about low current efficiency !)
beautiful work!
thanks for the photos and info about LED options, parts, and optics you used
you could almost build a kit, or people could copy your example, if they had a few specs for the spacer… etc
can you line up some of those LEDs so I can see what they look like?
iphone, daytime, white printer paper:
If anyone would like to buy the new model RRT01, Fasttech has a 20% off sale going on that brings the price down to about $49 bucks shipped to the US.
Use code CHERISH for 20% off. https://www.fasttech.com/products/9691168
Nice comparison pics jon_slider
Thanks to Jon_Slider, through him I got my first old RRT-01 and also thanks to M4D M4X for the money saved when buying the new 2019 RRT-01
Both are now converted to Nichia 219C 4000K and I am very happy about these two jewels!
So I replaced the clip on my 2019 RRT01 by a shorter one, which is far better.
It’s the same as the pic just above my post, it comes from an Enogear SS 11 flashlight…
Does anyone know where I could source a spare one ?
With the help of BanL (Thanks BanL) I finally got a variety of reflectors. After trying several different reflectors from Fasttech that didn’t fit, I even cut one down on the lathe to fit but was worse than the stock reflector my KD shipment finally came in. I now have two reflectors here that drop right in to original RRT01 with no modifications.
The both produce a very nice beam compared to the original reflector. I have only tested them using a LH351D shaved dome led but I don’t expect them to be any different with a 3535 led. Nice hotspot with even spill and no visible rings.
Reflector #1 being slightly larger in diameter (19.4 mm in diameter).
Reflector #2 slightly smaller in diameter (19.3 mm in diameter).
They look identically to my eye but when measured KD list the right dimensions, one is .1 mm bigger than the other.
They are OP reflectors but are very fine ripples, barely noticeable.
To me with the shaved LH351D the smaller #2 reflector has a slightly better beam but ever so lightly. It could be it just looks better with the shaved LH351D.
There not that expensive so it might help to order both and see which one works best for you.
The best thing is they drop right in with no rings…
Great info on an alternative reflector for the Original RRT-01 to help eliminate rings in the beam
I will go ahead and order some to try out.
Thank you moderator007 for your efforts and generous sharing of information
a friend reports his stock reflector in an Original RRT-01 does not have a problem with rings in the beam using a 5000k 219c, but I certainly do have a problem with a 219b in an original RRT-01 w original reflector
I lent the Original RRT-01 w 219b to a friend, and he noticed the rings too, so Im really looking forward to trying the alternate reflectors.
It opens up some better possibilities for a run of Single N219b LED modded Original RRT-01.
