【 ACTIVE 】 Utorch H09 XPL Rechargable Headlight with magnetic charge and tail 【 $ 27.99 】
Utorch H09
Rechargeable Headlight
The Utorch LED headlight flashlight, using Cree XPL - V6 LED bead, with 1000 lumens maximum output, 8 modes for all lighting needs, and a maximum beam distance of 200 meters, is a necessity for outdoor activities, like hiking, camping, travel, home use, gifts and emergency lighting.
Main features:
• Super bright CREE XPL - V6 LED, max 1000 LED lumens output and max 200m beam distance
4 brightness levels, suitable for different environments
• Rugged indestructible aluminum body with anti-scratching type III hard anodization
• Built-in magnetic charging system, fast charge and convenient
Multi-level dissipating heat design and new copper starboard, excellent heat dissipation.
Side switch button to change modes and adjust output, one-handed control
• High-efficiency driver circuit, no visible flash in any mode
• Automatic memory function, remember last used setting
• New intelligent temperature control technology for headlamp stable and safe use
• Reverse polarity protection to protect from improper battery installation
Low-voltage prompts function, the light will flash when the battery is low
Lockout function to avoid light turn on by unexpected
Waterproof IPX8, suitable for rainy weathers
• Power supply: 1 x 18650 ( not included )
My threads:
BangGood.com Deals
GearBEST.com Coupon Codes&Flashsales
reserved
beam color?
only CW?
4200K ?
Interested!
Interested
Interested
Interested
I asked.
Answer - Natural White
interested.
interested
Interested
Interested
Interested
Interested!
yes interested
also, I really like that skill hunt idea with the lens that makes it a flood. Does anyone have experience with that? maybe even a small red light? is that possible? It makes talking to people much easier because they don’t have to look away from the red.
interested
Interested
Interested if nw.
