but this type of light is meant to be floody, like the mf01, it would be really nice to see lh351d… real bummer fw3a didnt get it for now or so…
How is the tint on the LH351Ds compared to the nichias in the MF01?
A bit better tint.
Here is my experience in terms of tint:
219C<LH351D<SST-20<XP-L HI
Interested depending on price.
If my understanding is correct, the MF01S will be basically an updated Q8 on super steroids. I really hope for optics and LED combination that will allow for super high output and as much throw as possible, resulting in powerful mixed beam profile. There is already enough boring high output flooders out there that come with XHP70’s and tiny reflector triples, dumping light under your feet and into neighbor’s windows.
That is why I chose the SST-20 over other options. It gave the best all around beam, tint and output pattern that I could find.
I have been using my prototype extensively since it arrived.
It lit up our living room all day a few days ago when a stormed knocked out the power.
I too love my lumen monsters for area illumination!
The D18 uses SST-20’s, how does it compare?
They’re basically the same.
output appears to be identical (lumens)
one’s smaller uses 1 less cell so less runtime but more carry-able.
one appears to have aux leds
I’m guessing the D18 with it’s individual optics will have a longer throw?
biggest difference: the brand and quality of manufacturing are not the same… not even close
I do not have a D18 to compare.
On paper though the MF01S has 4 cells vs 3 cells and runs at 6v vs 3v (I think, I have not verified that one).
So on paper the MF01S should be able to deliver more power to the LED’s to drive them harder. How much harder, I have no idea. Also longer battery life of course.
At lower output levels they should be basically the same, the optics used will be the only real change here. While I have not seen the D18 optics in person, I am going to guess that they have the advantage based on past astrolux vs emisar comparisons. Although if that advantage is better throw or output (aka, efficiency), I do not know.
The LED’s themselves should be basically the same, the 4000k version that is being used in the MF01S is an FD2 tint bin which is a first and as far as I know the only way to get this tint at the moment. The 70CRI versions should basically come down to binning variance.
Overall my guess is that the MF01S will have higher peak output, longer battery life, slightly better thermals, more color options and auxled’s and the D18 will be more compact and marginally better optics.
This is all paper comparison though, I would be happy to use either light. They both look great.
I’m pretty sure the 4 cell MF01S will have higher output than the 3 cell D18. I own a D18 with the XP-L HI and I know the output can be pushed much harder if we have one more cell. Also I’m guessing throw should be more on the MF01S if the past MF01 is any indication.
Build quality wise, the D18 is phenomenal for such a small company. It is the same quality as the M43, which was often praised. The Mateminco lights made in the last year were not bad too.
Were also XPL HIs considered? My best NW tint is from Thrunite TN40S that uses these.
Edit: wrong thread
Yes, this was the plan at first and could still happen if enough intrest was shown. I have a prototype here with a mixed tint XP-L HI 5A + 1A setup that is one of if not the best 70cri tint I have ever seen.
Although the price for the light would have to be increased with XP-L HI and they were worried that banggood would not want that, so they decided to start out with SST-20 only.
Plus the lumen output with the XP-L HI was only around ~10-15% higher in my testing IIRC and about the same throw as well.
Didn’t know drivers can catch fire. I hope they figure out what caused it. With the MS18 with 8x21700 high drain cells, it would be even more dangerous. I’m planning to buy the MS18 and R90TS too.
Catch fire? What are you referring to? Wrong thread?
oops I had too many BLF pages opened. DBSAR’s DX80 almost exploded
So as pick up to grab my Imalent DX80 before i went to bed to go up lock the door,(the flashlight was not used in a month) I went to turn it on and it began to hiss and vent smoke around the threads of the head burning my fingers, and blew the charge cap off, I immediately unthreaded the head off the battery tube, and it billowed smoke from the head driver area… for now I placed the light parts outside incase for saftey. This light has very little use, and never run on its maximum mode for longe…
lol I read a post from TK saying she has a problem with tabs. She said at the time of the post she had something like 400 tabs open at once.
lol we here at BLF understand
Interested depending on price. Any guess when it will be available?
Still a few months out if I had to guess.
