On paper though the MF01S has 4 cells vs 3 cells and runs at 6v vs 3v (I think, I have not verified that one).
So on paper the MF01S should be able to deliver more power to the LED’s to drive them harder. How much harder, I have no idea. Also longer battery life of course.
At lower output levels they should be basically the same, the optics used will be the only real change here. While I have not seen the D18 optics in person, I am going to guess that they have the advantage based on past astrolux vs emisar comparisons. Although if that advantage is better throw or output (aka, efficiency), I do not know.
The LED’s themselves should be basically the same, the 4000k version that is being used in the MF01S is an FD2 tint bin which is a first and as far as I know the only way to get this tint at the moment. The 70CRI versions should basically come down to binning variance.
Overall my guess is that the MF01S will have higher peak output, longer battery life, slightly better thermals, more color options and auxled’s and the D18 will be more compact and marginally better optics.
This is all paper comparison though, I would be happy to use either light. They both look great.
I’m pretty sure the 4 cell MF01S will have higher output than the 3 cell D18. I own a D18 with the XP-L HI and I know the output can be pushed much harder if we have one more cell. Also I’m guessing throw should be more on the MF01S if the past MF01 is any indication.
Build quality wise, the D18 is phenomenal for such a small company. It is the same quality as the M43, which was often praised. The Mateminco lights made in the last year were not bad too.
Yes, this was the plan at first and could still happen if enough intrest was shown. I have a prototype here with a mixed tint XP-L HI 5A + 1A setup that is one of if not the best 70cri tint I have ever seen.
Although the price for the light would have to be increased with XP-L HI and they were worried that banggood would not want that, so they decided to start out with SST-20 only.
Plus the lumen output with the XP-L HI was only around ~10-15% higher in my testing IIRC and about the same throw as well.
I want one, but how LONG will this one take?
I am still waiting on 3 projects on BLF that has a lot of interest on list but still no production.
I already own the MF01, love it, just got the MF02, love it. I also have the MF04S, love it. Will the MF01S read the same as my other MF lights shortly?
It’s hard to say for sure. It’s possible that Mateminco might redesign it to be 4P instead of 2S2P, but I don’t really think that will happen. It’s too late in the project to make such a big change, and the light seems to generally work fine as-is. It’s just not as efficient as it could be.
There’s some odd behavior on the driver, like unstable power levels when the battery gets low, but that doesn’t seem to really cause problems. The most noticeable weirdness is a pretty sudden tint shift when the FET channel kicks in… but I’ve managed to smooth that out a bit to make it less noticeable.
As long as the battery carrier is tight and the contacts are clean, it seems to work reasonably well.
The beam is a lot like a Meteor — a big wide hotspot without much else. If you like that kind of beam, you’ll probably like the MF01S. It’s bigger than a Meteor though, and makes more light. I measured 13,900 lm with SST-20 4000K. The most I’ve ever been able to get out of a Meteor was a bit under 6000 lm.
People will probably enjoy the aux LEDs too. Lexel did a good job with those. It has a rainbow of colors, and the colors fade away as the battery gets low.
