I’m sorry but can someone explain why this light is well-received despite the SST20’s hated green tint at lower outputs? Wouldn’t that mean that it is always present in this light? Other than the price point I mean.
I don’t see green on low. Possibly due to the optic.
Do you own a flashlight with a 4000K 95CRI SST-20? If you do you must know that the tint and colour contrast it produces is excellent. Just not under the Black Body Line. Not difficult at all to understand that people like it. Just if you are a nitpicker (I admit I am one) or if you insist on flashlights that emit pink light you may not like this led.
For some reason, I thought the new C01S was still using the Yuji LED. Can someone tell me more about the SST20?
It is a fairly recent led from Luminus that has the standard 3535 footprint and a close to XP-G size die. The colour temperatures 5000K and higher are only 70CRI and are among the best performers in this die-size, the colour temperatures from 4000K and lower are only 95CRI which is very high for a power-led (some of these leds at some currents I found to be at 98CRI).
The C01S has a 4000K 95CRI SST-20 and I like the choice very much.
It appears to me TIR’s tend to be less prone to tint shift across the beam than reflectors, which makes off-tint less obvious.
It also is usually much less obvious when shining the light across colored objects than mostly grey or white objects.
Also, some of us are simply less sensitive to green tint than others.
Overall, I think the green should be thought of as a compromise of limited severity. For some it will be a dealbreaker, but there should be plenty of people who are fine with it.
[quote=djozz]
I hope sofirn can find a good led as replacement.
Yes I own a Convoy S2+ with the said emitter and I love it more than my 4000k BLF A6. To clarify, it’s not that I’m hating on the emitter. I was just wondering that with the number of times I read a post connected to the SST-20 someone comments on the ugly green tint. Thought might be missing out on something like a different tint. Thanks for the response djozz!
I hate the green in lights. Blue I can handle but green makes me put the light in a drawer. In this light I see no green whatsoever, I have used it for a while now as a backup on my keys, even though it’s a backup I use it a lot as my keys are generally easier to grab than the light in my belt holster.
I love c01s, the color and tint is perfect, no greenish crap.
The current at high mode is 2.2A, and at low modde is 0.022A, so that is 100 times difference. I wish it has “middle” mode at around 30 lumen(0.2A), then it would be a perfect keychain light
Are you sure you are getting 2,2A?
At 2,2A on high mode, you’d kill the AAA in less than 25 min.
i double checked it, yup, it runs 2.2A and 0.022A
Nice meter
It can do RMS current even at the high frequency that boost driver might be running?
I did not read through the entire thread, but I saw the light is advertised 100 lumens for well over an hour on a AAA battery. I don’t personally believe that, curious if anyone has tested it? I see above someone measured 2.3A on high, definitely not getting over an hour, even with a lithium primary. Is the 100 lumens accurate?
No, never over an hour runtime. It puts out 90 lumen of high CRI which requires almost 400mA through the led, so that little boost driver is doing its best, 2.3A sounds a bit high (on the full battery I assume) but that must be a not so efficient driver then. Must be 20 minutes, anyone doing an actual runtime test? (maybe me but not this week).
The BLF C01S silver color is available now
I just bought 3 of them
Thank you!
Ordered
Order placed
Gone just when I logged into AE
