Hello my dear friend!
i just received the specsheets !
Ms18 ordered
:+1: Congratulations! :sunglasses:
I literally shouted out loud in the office when the notification popped up that I could place my order.
Now I canât wait for it to ship. Iâve been scouting places I can go to take pictures.
Your addiction is more severe than many here.
Oh itâs bad. Iâve bought a couple cameras, learned how to use adobe premiere pro, and am even saving-ish for a drone, mainly for flashlight photography because my cell phone camera just wasnât cutting it anymore.
Samsung 40T confirmed, great cells!
DENGOH: AgentWhiteBread:I literally shouted out loud in the office when the notification popped up that I could place my order.
Donât worry, it will get better and then get worse again. It is never ending cycles. Just focus on all the fun we get from all these gadgets.
That is very good idea to use drone for flashlight beamshots. A lot of learning and work to do, of course money is one main factor too.
removed massive images
Do you know if the boxes will have all that design work or will it be less inconspicuous?
Really? I thought with the massive amperage they would use the 30T.
Yeah. Samsung 40Ts at 35A+ is really not sustainable.
30Ts wouldâve been much better.
Yeah. Samsung 40Ts are 35A+ is really not sustainable.
Battery packs are 4s2p, 35a cells will be plenty.
BlueSwordM:Yeah. Samsung 40Ts are 35A+ is really not sustainable.
If the leds need 200 amps at 6v, that is 50A per cell.
It looks like the 40T data sheet says it can do 45A continous, but only up to 80°C. So short duration 45A is okay.
Maybe the 40T is fine since max turbo on this light is pretty short and the cells should not overheat in that short period.
grahambo0101: BlueSwordM:Yeah. Samsung 40Ts are 35A+ is really not sustainable.
Are they not running these LEDs at 12v? If they are running at 6v that is some pretty heavy buck at play considering the battery packs are 16.8v
I actually said that the 35A+ required by the light at full power are not good for the cell at all.
30Ts wouldâve been quite a bit better.
Also, I doubt itâs using a buck. Starting with the MS12, 10k+ lumens go out the window in terms of regulation.
They are basically running in direct drive.
JasonWW: grahambo0101: BlueSwordM:Yeah. Samsung 40Ts are 35A+ is really not sustainable.
I donât know how they are running them. I used 6v as an example.
200A@6v
400A@3v
100A@12
The batteries see the same 50A each.
grahambo0101: JasonWW: grahambo0101: BlueSwordM:Yeah. Samsung 40Ts are 35A+ is really not sustainable.
200A@6v
400A@3v
100A@12The batteries see the same 50A each.
If the LEDs are run at 12v, then they only need half the amperage vs. if they are run at 6v. So at 12v, it would only draw 25a per cell
https://m4dm4x.com/wp-content/uploads/2019/05/4-1.jpg
That image says 40T for the R90TS. I assume the MS18 uses the same?
the battery pack is the same afaik
If you go to Banggood,you see that Imalent sells a two head,(MS18+R90TS,plus one battery pack),combo.
