Vapcell Q2S battery charger smart charger can use for 21700 18650 new arrival
589 posts / 0 new
vapcell Dennis
vapcell Dennis's picture
Last seen: 1 day 20 hours ago
will34 wrote:
Where can I order the 10440? Can’t find them in your aliexpress shop.
will sell battery in Ali soon Smile
Agro
Agro's picture
Last seen: 2 weeks 4 days ago
vapcell Dennis wrote:
Agro wrote:
I see a high current 14500. Oh yeah, finally something worthwhile in this format. Party
Thanks
Could you help me?
Why did all my pictures disappear?
I quoted links to pictures that could be displayed before.
Now it’s gone.
When I look at the source of the first post – there are image links there.
Copying a link and opening in another tab shows me image – so this is working.
However when I reload the BLF site and look at network requests – my browser tries to load the images but your server refuses to give them with error “403 Forbidden”.
I don’t know maybe your web admin added some embedding “protection”?
Anyway the issue seems to be with your image host.
vapcell Dennis
Thanks
Could you help me?
Now it’s gone.
Thank you very much. I uploaded photos on a different website.
Now it’s all right.
Pete7874
Pete7874's picture
Last seen: 24 min 19 sec ago
Looking at the below discharge graph, this 16340 has more capacity at 5A than at 2A? Something doesn’t sound right.
Anyway, I ordered a few from illumn to try.
Barkuti
Barkuti's picture
Last seen: 32 min 12 sec ago
Pete7874 wrote:
Looking at the below discharge graph, this 16340 has more capacity at 5A than at 2A? Something doesn't sound right.
The fact we cannot understand something does not make it impossible. Such phenomena can happen. For example:
Source: HKJ's comparator and review of Samsung ICR18650-30B 3000mAh (Green) @ lygte-info.dk.
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
maukka
maukka's picture
Last seen: 4 months 3 days ago
In general, I’d just ignore mAh readings. Wh is a much better indicator of capacity.
My 16340 800mAh Vapcells still haven’t arrived even though I ordered them on April 4th. Once they were returned by customs and sent again.
Johm
Last seen: 3 days 5 hours ago
Capacity is the whole are below the line in this graph not just the finishing point.
moderator007
moderator007's picture
Last seen: 4 months 1 week ago
The Vapcell 16340’s I tested at 3 amps seem to follow the supplied graphs pretty well. It’s the best 16340 I have tested.
Pete7874
Pete7874's picture
I was referring to the actual capacity values listed in the table directly below the graph.
will34
will34's picture
Last seen: 1 hour 48 min ago
Sometimes you get higher capacity at higher discharge rate because the battery “doesn’t get discharged completely”. This is why energy is a much precise way to measure the real capacity because it can be translated directly into lumens/hours.
Barkuti
Barkuti's picture
I concur energy is a more precise way of measuring absolute performance or delivered energy.
The area below the line curve is delivered energy, which is the integral of the voltage curve over the delivered capacity for the given voltage range and discharge rate. Or something like that, haven't touched formal maths for ages.
vapcell Dennis
!https://i.imgur.com/XkTpbjx.jpg!
When the battery is discharged to 2.5V, the discharge capacity of large current may exceed that of small current. But there won’t be much difference. Smile
vapcell Dennis
Source: HKJ’s comparator and review of Samsung ICR18650-30B 3000mAh (Green) @ lygte-info.dk.
Nice test, Thumbs Up
vapcell Dennis
sincerely apologize for the delay in shipment.
Hope to be in your hands as soon as possible. Smile
vapcell Dennis
Thumbs Up
Thanks you very much Beer
Pete7874
Pete7874's picture
Why is that?
vapcell Dennis
energy is More important。 AH*V=WH
Barkuti
Barkuti's picture
… the discharge capacity of large current may exceed that of small current.
Why is that?
Because of temperature induced chemistry reactions inside the cell. As a general rule heat improves the performance to some extent, chemistry dependent of course. While lots of modern cells do not show increased capacity at larger discharge ratios, increased heat reduction in internal resistance is common.
Smile
moderator007
Why is that?
Smile
That was my thought as well. I have seen li-ions that were cold and run under a 3 amp discharge actual slightly increase in voltage as they were being discharged because the internal heat from being discharged warmed the cell which gives it the ability to provide more current. Since the discharge current is constant the cell doesn’t have to work as hard warm so the voltage goes up slightly. A warm cell will give more capacity in a discharge test than a cold one in my experience.
vapcell Dennis
moderator007 wrote:
Why is that?
Smile
Thumbs Up
So do I.
djozz
djozz's picture
Last seen: 1 hour 28 min ago
Ordered 2 pieces of 10440 batteries from the aliexpress store. Will check them out Smile
Thanks again for getting us a new type nice battery Dennis.
Pete7874
Pete7874's picture
Got my 16340 cells from Illumn.
Capacity test using 500 mA discharge current on Lii-500:
IR, measured using a DMM and resistors:
Cell 1: 0.21 Ohm
Cell 2: 0.20 Ohm
RelakS
10440 shouldn’t have a button top option? I will see if it will reach the positive contact in my DQG Tiny.
vapcell Dennis
we have button top , we will add it in web,sorry
vapcell Dennis
Cell 1: 0.21 Ohm
Cell 2: 0.20 Ohm
Thanks for the test, a bit low cap
we test it more than 750mah
RelakS
Is it possible to add this button top to my current order? It is awaiting shipment at this moment.
vapcell Dennis
yeah, contact Ali Customer service staff to change it
Pete7874
Pete7874's picture
No problem. It may just be the nature of this charger/analyzer (Lii-500). It consistently indicates lower capacity figures on all cells I test with it by about 5-6%.
RelakS
If I am correct, Vapcell measures capacity with 0.2C, which gives 150mA instead of 500. Maybe, this is the reason of the difference?
Pete7874
Pete7874's picture
The chart they posted (see below) shows them measuring capacity using various current levels, starting with as low as 0.5A and going up to 8A. At 0.5A, their tested capacity is 812mAh. The main difference is their cutoff voltage is 2.5V. Mine is 2.8V, but there can’t be much capacity left there at that point.
