Their contact info (including email) is in the Word doc.
Their email info is also included in the User Manual: 1749808860@qq.com
Which phone are you using? What firmware version is on your TC66? I believe v1.13 is the latest.
Thanks, finally got a way to contant him. Go to product page (desktop view of the website better):
Then click on Contact
You need to be registered with an account at Aliexpress to be able to use private messaging.
why you use photos of UM34C when you are talking about UM24C
There is now also several UM25 clones which are several dollars cheaper than the RuiDeng UM25/25C
Most UT25 has been removed from Aliexpress, we should support originals instead of copies , otherwise it will cause loss to the original creator and they may never create new products
Only the UM34C supports Dash Charge due to the additional pins of the USB 3 connector on that meter.
hello,when did you buy UM25C, the latest version supports OnePlus Dash Charge
Does anyone know of a prepackaged 60W DC to USB C thing? https://www.nicelineshop.com/index.php?main_page=product_info&cPath=&products_id=8369 this is just the bare board, I’d like a case with it, if possible
Googling for “DC to USB PD Converter” might help.
Here’s one https://www.omnicharge.co/products/dc-to-usb-c-adapter/
Another in stock: Amazon.com
Cheaper one (90W): Amazon.com
This one might be your best bet:
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F113684437490
That bare board has great specs, but I find it hard to believe it would be able to handle 60W of output at lower range of input voltage for long times, say 12V which is 5A+ constant input, chargers usually get quite hot at that rate.
so sorry, we don’t have
Looks quite great, thanks! However, the size and price is a bit overkill. For such multiport usage, the MagicFox PD180 京东(JD.COM)-正品低价、品质保障、配送及时、轻松购物! is cheaper and has higher wattage.
I plan to feed it with 20V. The Lenovo 135W charger looks like great target. https://www.reddit.com/r/thinkpad/comments/bpnc9o/the_p1x1e_small_135w_charger_available_retail/
hope you get the better one
YZXstudio has a newer model ZC918P that does 160W. I bought one off ebay, but it’s also available aliexpress. Like other YZXstudio products, it’s good quality but quite expensive.
The Magic Fox PD180 looks very interesting. I think it is unique in offering PD input. Is it available anywhere more accessible than jd.com?
If I want to test the maximum output of a charger, which adjustable load can I buy? Some recommendations?
Depends on the output of the charger you want to test :)
Here are some of the ones I use for my videos :
https://www.banggood.com/35W-Constant-Current-Double-Adjustable-Electronic-Load-QC2_03_0-Trigger-Quick-Voltage-USB-Tester-p-1194871.html
https://www.banggood.com/8-In-1-150W180W-Digital-Battery-Capacity-Tester-Voltmeter-p-1248703.html
These are just loads, so you'll need something to trigger the protocol you need.
These are just my two cents, btw :)
I’ve found a new meter similar to YZXstudio ZY1280, is it a copy or is original?
MagicFox魔狐U2 UX电流电压USB测试表QC4 PD3.0 2.0 PPS快充协议容量检测 U2表(无蓝牙)送短CC线
I’d suggest a load with more power than your charger can use. With USB, 35W are usual:
Electronic load 35W 3A with OLed display J7-f [image] Official specifications: Industrial discharge load USB tester 2016 new upgrade electronic load King Intelligent temperature control Double adjustment design USB Dual Adjustment accuracy Electronic Load discharger Industrial grade long life 35W power continuous discharge Voltage:3-21V Current:0-3A Real-time monitoring Voltage display Current display capacity display Electrical voltage display Power display Timing dis…
Electronic load ZKE EBD-USB Electronic load ZKE EBD-USB+ [image] Official specifications: Supply power: online USB power supply (5V) Voltage range: 0.05-21.0V Current range: 0.05-4.000A Test mode: constant current discharging, QC2.0/3.0 trigger, MTK-PE trigger, USB current voltage detection Max power: 35W Computer control software: support EB online software test Weight: 66.5g I bought it from ebay dealer electronics_lee (It was called EBD-USB, but the EB softw…
Electronic load DTU-CC01 [image] Official specifications: Material: PCB Display: 128 * 64 Input Voltage: 3.6V~30V Input Current: 0.2~3A Voltage Resolution: 0.001V Current Resolution: 0.001A Rated Power: 25W Max. Power: 35W Wire Resistance Measurement: Pressure-drop method Input Interface: USB-A, TYPE-C, Micro USB Capacity: 0~9999.9AH, 0~9999.9Wh Protocol Trigger: for QC2.0, QC3.0, FCP, SCP, AFC Working Temperature: 0~70°C Item Size: Approx. 11.5 * 4cm / 4.5…
The Magic Fox one looks like an unbadged version of WEB-U2 (more recently branded as WITRN U2)
China wholesale Sitemap, dropshIP wholesale from China, Professional Chinese wholesaler for general merchandise on wholesale price.
There are very similar USB testers sold under several different brands and the relationship between them is not clear to me (e.g. YZXstudio, WITRN, WEB-, POWER-Z, AVHzY)
not , it is web-z meter , they are different
they are all USB load , but the first one is a trash
I have the RD LD35
https://www.aliexpress.com/item/32882318330.html
This is just a load: if I want to do triggering, I prefer to do it separately.
