There are options for professionally installed, DOT-compliant LED retrofits. It's a bit different than buying the replacement bulbs online from China.
I looked around, and it's probably pretty tough to get any sort of official DOT-compliant certification for a drop-in LED replacement for halogen. In most areas in the United States, if you're going to try to use one on-road, I'd pay attention to the light cut-offs. If you pay attention, you'll notice factory LED/HID headlamps on low-beams will have a sharp cutoff that should stay level with the rest of the car. This is to prevent blinding others (though sadly ineffective when a lifted truck tailgates me). This is also generally enhanced with some sort of leveling system on the vehicle, so if you load 500 lbs over the rear axle, the headlights aren't suddenly aiming up by fifteen degrees.
Another thing that I hate seeing is light bars everywhere on cars these days. Most states require that off-road lighting (classically the large halogens over top or on the grille of a pickup) be covered during on-road use. The same regulations would apply to light bars, but I never see them covered and it doesn't get enforced.
Makes me want to get Anduril on my L6, configure tactical strobe to use the FET, and point it backwards for the next light bar I see...
(Sorry for the rant, can anyone tell I got tailgated by another light-bar Jeep yesterday?)
A colleague from way back had… some boxy old car, a Honda, I think… with a squared back/trunklid. He slapped on some of that garish 8” wide chrome tape that idjits slather all over their cars (bottom of the doors, panels, etc.), right across the trunklid.
If you were following with lowbeams on, no big deal, as they’d (if correctly aimed) be hitting just low enough to not catch the tape. But if you tried hitting him with the brights, you’d get blinded in return.
Was quite clever, I thought. Looked ugly as sin, but was functional.
The thing I hate about those light bars is that they have almost no throw, so they’re not helping the idjit using them on the road anyway. They’re just one big glare. I’ve wished so many times for a Candela-seeking heat laser mounted to my car. It would automatically point at the offending source and take it out quickly and permanently. :smiling_imp:
These “194/921/t10/t15” bulbs are sooo much brighter.
Ive installed a ton of leds over the years. I have an auto detail/customization shop. Ive tried buying from most of the suppliers, even expensive ones like vleds. Heres a truck i did the other day. You can see the difference between one of those 13 led type that you posted and the one i linked on the 3rd brake/cab light.
Surely you’d want to know if a bulb fails, which would happen with the 6ohm resistor but not with the 33-50ohm resistor? Am i missing something?
Good info though, i have H9 bulbs in a projector lens which are dim, even with upgraded Philips X_treme Vision bulbs, Would be interested to know what you think of the H11 upgrade if you do it. (Am leaning towards to Philips Ultinon LEDS over the H11s at the mo).
I’ve got something similar for my backup lights. Flat like that, most of the LEDs are facing the long-axis of the reflector (see the pic above). Went up’n’down through my amazon orders, couldn’t find which bulbs they were, though.
Not for interiors, though. I’d get sunburn from something that bright. And I went out of my way for WW, because I just like that “relaxing” color, especially at night. 5-chip LEDs were okay, but the 13s were way nicer.
Thing is, my interior fixtures don’t have reflectors, just white-plastic to reflect light, and facetted lenses to spread the light. So when I found I could actually stuff the 13s in there and they’d fit, well, yay me!
Ever notice that so many backup lights are tinted? On VWs, they tend to be tinted gray, some GMs have they tinted orange-pink, even on my old Regal the openings are “slotted” to cut down on outbound light. Wtf??
David EF.
2 things.
Headlights also have Left hand offset on beam and Right hand. Depending on left/right hand drive.
Buying from China check that. All the ones I’ve got. H4
have been simple drop ins as long as you have small hands.
Look on You tube for reviews. (Veh, LED’s)
There are some good Chinese ones out there.
With those Bars and throw.
Get the single row 10w LED’s NOT the 3w dual/triples.
The 3’s are spreaders.
Hence the combo’s of outer and inner lights on bar.
Single row ARE real good throwers.
Mine, 20in. throws forever. Cold White too. not warm white.
It gives clear sharp trees. over 600mtrs down our road here.
You can pay handsomely from a place like deautoled.com, or store.ijdmtoy.com, where they assure error code free LED’s. Or you can try your luck with lesser priced LED’s from other sources. The cheaper ones seem destined for shorter lifespans. I’ve used about 3 different cheaper sources over the years, both auto and home… and most died after 1~2 years of use. I haven’t bought any newer ones lately, though I’ve been looking as the field has changed yet again (more aggressive offerings for good prices).
My dissatisfaction for interior LED’s had been with tint. Even the pricier ones seemed to go overboard on cooler tints, as if warm looked too much like incandescent and wouldn’t sell. Cool is too harsh. Ideally, I want something neutral white that leans warm. So cooler than incandescent, but not bluish like so many LED’s.
Czech out those 2 links I posted. Both are WW, both are quite nice!
Last week or so, I “argued” with someone as to whether/not my interior lights were LEDs or hotwire. He was insisting that LEDs are that nasty Angry Blue™ and mine have to be hotwire bulbs, because they look so natural.
For the tint, there is now the Luminus SST20 with high CRI (4000K and below).
I think it can be mounted on something like that as the SST20 is 3535 form factor. But no one got the idea…
It will die after 1-6 month!
The most tenacious what I find was this
But after some month some of the lines of leds will die. But it will work with leftover LEDs.
Why? Because of hot. I mean it is not with aluminum pcb, it is with glass textolite what can not let heat away from the leds. And it is with ordinary smd resistors. When you car is muffledб it is about 12v, when engine is work - it is about 14v. Current with 12 and 14v is different.
Also there is really cheap leds with tiny crystal and they work to the limit (works with maximum current)
I upgraded C5W by aluminium radiator 14x14x6mm, but it is also with glass textolite with poor thermal conductivity.
Now I finalized drawing the pcbs for C5W (C10W) and finally (15-20 hours) pcbs for W5W (T10) LED lamps with TRI-R 3030 smd LEDs SunLike and NSi CCR - Constant Current Regulator & LED Driver (I call it smart resistor)
How much time need to draw pcb board?
If someone interesting, C5W will cost about 5$
W5W (T10) will cost 5-10$ (depends from led quantity)
1pcs 3030 SunLike led cost 0.5$ in my web-site
the one reason why I use led in my car - it is light in the interior of my car. It is 6pcs C10W - 10w each. It is 60W. It is shine, but too much power… In another cars salon (interior) light - it is W5W. One way to do it more shine - use good LED lamp, but there is no good W5W (T10) LED lamps =(
For dome lights, I use this kind of LED panels with adapters for the bulb holder: https://www.ebay.de/itm/Warm-White-Car-Interior-48-SMD-LED-Lamp-Light-Panel-T10-Dome-Bulb-BA9S-Adapter/232173771458
There are various sizes available, I always use the biggest which will fit behind the plexiglass panel. They work well for several years now. Sometimes the wires are not soldered, but just pressed in in the adapters. The resulting intermittant contact can be repaired by actually soldering. Not the LEDs fault though.
https://www.ebay.de/itm/2x-1156-144SMD-BAU15S-PY21W-LED-Turn-Signal-Lights-Bulb-Canbus-Amber-Yellow-12V/293417003833
I use them as turn indicator, reverse lights and in the center brake light.
When being on constantly, they get hot as hell, but reduce the current after some time. There seems to be a sensor inside doing that. The heat seems to be no problem though, I ran them on a power supply for 24h straight and everything still worked. They get dimmer below 10V though. In my ancient `97 Toyota, the voltage sag with heating, lights, and rear window heating on at the same time while idling caused a voltage sag to below 10V apparently. This reduced the current the LED lights used, leading to rapid blinking. Parallel 4ohm resistors fixed that. Modern cars should have no problems with that. I still like these blinkers, they are so intense that they can be seen in reflective roadsigns.
you can check out ledlightupgrade.com. their automotive lighting is very high quality and engineered to work with factory housings and still provide a correct beam pattern that doesn’t blind everyone.
