Just wanted to update. Yesterday I was finally provided with a tracking number for the replacement head. This is a little disappointing since it’s been over a month since I reported the issue. That said, assuming the replacement comes and is in good order I will be satisfied, I do understand that these smaller manufacturers can’t respond as quickly as some of the larger ones.
Once the replacement arrives I’ll do my best to open up the old head and see if I can figure out why it leaked so quickly. I might try to test the new one as well but I’ll have to figure out how to do so without risking damage.
In general, flashlight companies should update the firmware whenever possible. The code has continued to change over time, and old build targets remain supported… so it should be pretty easy to do the update any time a new batch of drivers is produced.
No more 219B option for the remaining ROT66s. The E07 is now the only Fireflies light available in 219B. I asked if the updated ROT would have 219B but haven’t heard back.
I got my rot66 in the mail today. It was flickering and couldn’t ramp up but after cleaning the contacts, adding a paper spacer to the tail cap, tightening the battery carrier screws and tightening the head and tail cap enough to be a PITA, it finally operates normally. The Nichia 219 color rendition is splendid and Anduril is such a intuitive and fun interface.
Asking this before pulling apart the light. Is there a mode in Anduril for the ROT66 that has ramping functionality, but no specials modes (e.g. no voltage check sunset, ect, no strobe modes, no turbo.)? Only 2 of the switch leds are on. When I do the 7 click thing to turn back on the other 2 leds, they sometimes turn on, but go out when I try to go into any of the special mods (which still don't work). I can't find any electrical connection issues. I haven't yet tried to gain access to the glued driver, but it feels secure when I try to wiggle the driver spring. I think it has the version of Anduril that had a small ramping bug from moonlight. I think this because it would sometimes not ramp directly from moonlight. The ramping behavior seems spot on. So it seems the switch itself is working properly.
So, is there a special mode of operation like this and is there a way out of it? I don't really want to break out the driver if I don't have to.
If I understand correctly, it sounds like it should be able to get back to normal operation by clicking 6 times. It may just be in muggle mode, which has ramping and not much else.
Me either. I got a response promptly when I first contacted Jacky and he asked me to send a video, which I did. That was several months ago and he hasn’t answered any of my emails since then. Very disappointing.
Did the 6 clicks as suggested. That brought back the special modes, but now I have no ramping. Just a super low moonlight mode and a very bright (maybe even Turbo) mode. Reread TK's Anduril Manual , but I'm still stumped. Anyone have a suggestion to get ramping back?
Turn the light on, then click 3 times. If I understand correctly, this should get smooth ramping back.
(I’m guessing you’re in stepped ramping mode with the number of steps set to only 2)
If you’d like to configure stepped ramping mode for better results, this may work:
Turn the light on.
Click 4 times to start ramp config mode. (The light should blink once, then flicker for a few seconds, then blink twice, then flicker, then blink three times, then flicker. Each flicker is a chance to enter a value.)
At the first option, click 1 time to set the floor to the lowest level.
At the second option, click 1 time to set the ceiling to the highest level.
At the third option, click 7 times to tell it you want 7 total steps.
Thanks again Jason and TK. I was just logging in to answer Jason. The behavior is like what TK suggested with 2 step ramp. I click to turn on. I get either Moonlight or Bright depending on what mode I last exited. I press and hold to change to the other mode. A single click turns the light off. Three clicks doesn't change anything. I tried several times varying my timing.
Maybe 3 clicks doesn't work when there are only 2 steps. I will add steps as TK suggests. Maybe that will allow 3 clicks to work. I'll report back. Thanks again you too for taking the time to help me out.
If you click 3 times to change the ramp style, it won’t immediately change the brightness. It should just give a very short “blip” at the end where it turns off for a split second. Then if you hold the button to try ramping, it should adjust the brightness in a smooth pattern.
