It would be generous and helpful of you if you could hyperlink your more esoteric claims to supportive data on occasion, if it isn’t too much trouble.
In relation to what, metallic powders?
No problem then. It’s just that in my laboratory work at college, our professors asked us to be careful when handling metallic powder, as not only would it be a mess to clean it, but they are flammable since they have extremely high surface area to air, but can also be inhaled, so we should always work under a fume hood.
I’m a toxicologist. This is a reliable reference for the toxicology of copper.
It’s complicated, as Cu is both essential and toxic. As with all things, the dose determines the poison (Paracelsus).
In my view, and as Blue mentioned, just be careful in handling to reduce unnecessary exposure.
I’d like to pitch in for 10 of each type of spring if that’s possible and not too late. If it is too late, no biggie. Thanks.
I’ll avoid snorting rails of copper powder going forward.
Yeah, snorting L-ascorbic acid powder feels a lot better. Seriously. O:)
Are you still doing the group buy?
TA’s post confuses me, it sounds like the led’s are not available.
Sorry if it was confusing. Basically the LED’s are available but they are not “reserved”. So they can be sold to someone else at any time. Once sold it is unlikely I will find more for some time.
So we should strike quick before they are sold.
Assuming prices similar to before, I’m in for 20 FD2’s.
I would be in for at least 20 FD2’s
I would also get at least 10 FD2’s as well.
I’m in for 20 SST20 FD2 if TA does the group buy instead of BSM.
So, guys and gals, now that I’ve shipped all orders, and reshipped some orders that were taking too long to ship, I’m ready for the 3rd gen spring groupbuy.
Here are the springs specs.
Large BeCu spring(Rev 3.0):
Material: Beryllium Copper C17530 38% IACS
Spring upper diameter: 6,25mm
Spring base diameter: 9mm
Spring thickness: 1,0mm
Spring height: 12mm
Total number of coils: 5
Plating: Copper(25 um)+ silver
Small BeCu spring(Rev 3.0):
Spring upper diameter: 4,25mm
Spring base diameter: 5,75mm
Spring thickness: 0,8mm
Spring height: 10,5mm
Plating: Copper(20um) + silver
Because of the thick copper plating to give a large boost in conductivity, the spring is again quite a bit more expensive than even the 2nd gen silver plated version.
Now, we are at 0,46$US/spring.
Express your interest below.
Will make a 3rd thread for it soon enough, along with some sweet sweet FD2 SST-20s.
Will also be making budget phosphor bronze springs, probably at 0,15-0,20$US/spring along with some new additions.
Yeah, the Rev 3.0 springs are going to be the biggest upgrade yet, along with some good 4000k SST-20 FD2 LEDs.
In for 20 FD2 SST-20.
Added to the new list.
As mentioned before, will probably make a new thread tomorrow.
New interest sheet: Rev 3 BeCu Copper-Silver plated spring+SST-20 4000k FD2 Below BBL - Google Sheets
These are for the Rev 3 springs, and SST-20 4000k FD2 LEDs below BBL.
Also, does anyone want some remaining springs?
I still have some of the Rev 2 silver plated springs available.
Yes ….Rev 2 springs 20 Large 10 small if you got them?
20L/10S Rev 3 also….
I’ll take 15x large and 15x small rev.2 springs
25x large and 25x small rev.3 springs
15x SST-20 4000k FD2 LED
Thank you
All added to the list.
