dodge_911
(dodge_911)
May 21, 2019, 3:05pm
285
xnode
(xnode)
May 21, 2019, 8:50pm
286
I’ve found a new meter similar to YZXstudio ZY1280, is it a copy or is original?
MagicFox魔狐U2 UX电流电压USB测试表QC4 PD3.0 2.0 PPS快充协议容量检测 U2表(无蓝牙)送短CC线
angerdan
(angerdan)
May 21, 2019, 9:01pm
287
I’d suggest a load with more power than your charger can use. With USB, 35W are usual:
Electronic load 35W 3A with OLed display J7-f
[image]
Official specifications:
Industrial discharge load USB tester
2016 new upgrade electronic load King
Intelligent temperature control Double adjustment design
USB Dual Adjustment accuracy Electronic Load discharger
Industrial grade long life 35W power continuous discharge
Voltage:3-21V Current:0-3A
Real-time monitoring
Voltage display Current display capacity display Electrical voltage display Power display Timing dis…
Electronic load ZKE EBD-USB
Electronic load ZKE EBD-USB+
[image]
Supply power: online USB power supply (5V)
Voltage range: 0.05-21.0V
Current range: 0.05-4.000A
Test mode: constant current discharging, QC2.0/3.0 trigger, MTK-PE trigger, USB current voltage detection
Max power: 35W
Computer control software: support EB online software test
Weight: 66.5g
I bought it from ebay dealer electronics_lee (It was called EBD-USB, but the EB softw…
Electronic load DTU-CC01
[image]
Material: PCB
Display: 128 * 64
Input Voltage: 3.6V~30V
Input Current: 0.2~3A
Voltage Resolution: 0.001V
Current Resolution: 0.001A
Rated Power: 25W
Max. Power: 35W
Wire Resistance Measurement: Pressure-drop method
Input Interface: USB-A, TYPE-C, Micro USB
Capacity: 0~9999.9AH, 0~9999.9Wh
Protocol Trigger: for QC2.0, QC3.0, FCP, SCP, AFC
Working Temperature: 0~70°C
Item Size: Approx. 11.5 * 4cm / 4.5…
JJSEA
(JJSEA)
May 22, 2019, 1:06am
288
The Magic Fox one looks like an unbadged version of WEB-U2 (more recently branded as WITRN U2)
There are very similar USB testers sold under several different brands and the relationship between them is not clear to me (e.g. YZXstudio, WITRN, WEB-, POWER-Z, AVHzY)
RD_tech
(RD tech)
May 22, 2019, 1:53am
289
not , it is web-z meter , they are different
RD_tech
(RD tech)
May 22, 2019, 1:55am
290
they are all USB load , but the first one is a trash
JJSEA
(JJSEA)
May 22, 2019, 2:48am
291
I have the RD LD35
https://www.aliexpress.com/item/32882318330.html
This is just a load: if I want to do triggering, I prefer to do it separately.
RD_tech
(RD tech)
May 23, 2019, 12:43am
292
this is our LD35, it don’t have trigger function, if you need trigger function, you can check our other version HD35
JJSEA
(JJSEA)
May 23, 2019, 12:55am
293
I believe it has only QC trigger function. It would be great to have a load that also had PD trigger function.
RD_tech
(RD tech)
May 23, 2019, 1:09am
294
for not , there is not PD trigger load
JJSEA
(JJSEA)
May 23, 2019, 1:33am
295
I found another YZXstudio DC-PD adapter on ebay ZC823x3 (it’s also on their Taobao store): 180W, 6 ports arranged as 3 x 60W USB C/USB A pairs, and DC or PD input.
https://www.ebay.com/itm/ZC823x3-PD-180W-Multi-Protocol-Fast-Charge-Apple-Xiaomi-Huawei-Samsung-QC4-PD3/133054595939
I ordered one.
RD_tech
(RD tech)
May 23, 2019, 1:43am
296
this is a charger, not a load, I just talked about the USB load
will34
(will34)
May 23, 2019, 8:07am
297
Do you plan to release a usb load with PD trigger and higher power capability?
Yes, I’d love one.
I’d also be willing to pay a pretty penny for one.
maukka
(maukka)
May 23, 2019, 4:32pm
299
Also maybe with solder pads or terminals for connecting other than USB devices directly without a USB adapter, since that’s a lousy connection.
will34
(will34)
May 23, 2019, 4:52pm
300
If you’re willing to pay pretty penny I’d recommend YZXstudio zl1100, it can trigger every charge protocol, 0-3A ramping, serial data logging and up to 60W PD (indefinitely with the correct cooling conditions).
Everything is managed via the integrated OLED screen but you can easily translate the serial data into graphs with jcharts or similar tool.
maukka
(maukka)
May 23, 2019, 4:53pm
301
Too bad my first batch ZL1100 can’t trigger PD even with a newer firmware. Just says NG. So make sure you get a recent one.
RD_tech
(RD tech)
May 24, 2019, 2:46am
302
for now , we don’t have plan on load, we are designing a big display, many button and function power supply
RD_tech
(RD tech)
May 24, 2019, 2:53am
303
higher voltage is useless, big current is very important , HD35 have 5A current . 35W is enough
Yes, but higher voltage is necessary to test high power USB-C PD sources.
I mean, with a 3A cable at 20V, it goes up to 60W.
At 20V with a 5A cable, that goes up to 100W.
A 100W USB PD 3.0/QC 4.0 load would be large, but very useful for many years to come.
