That has to be it, a tightening issue (retaining ring, head, tail cap). Light isn’t so fragile as to stop working from a simple fall of 1 meter. I’d bet it would survive a 10 meter drop onto pavement. I don’t get how someone can presume immediate driver failure like this… :person_facepalming:
This light is so finicky, took the lens and optic off, wiggled the PCB board with a tiny screw driver. Reassembled, tight, very tight. Working normal again.
Is it possible to select which blinky mode comes up by default, when I go into blinky group?
(I’d prefer to have it go to the bicycle strobe immediately, rather than any of the other options)
Yep, I can confirm that behavior with my FW3A. I have been playing with lightning strobe lately. When off, a double-click w/press+hold goes right to the strobe group and that’s the first one coming up, so the strobe mode memory works.
My FW3A survived its first hard drop. I was walking across a parking lot carrying several items together with my light and somehow managed to sling it 4 or 5 feet onto concrete.
It hit hard. Pick it up turn on and test. Wow it’s still working great. Took apart to check contact pads because I thought contact pads may have been damaged but all looks good. Well everything except a small ding on the edge of front bezel.
Guess I am a klutz. Probably drop my lights more then most.
Actually have only hurt 1 light from drops. It was a Nitecore SRT3 and 1 drop from 3 or 4 feet and it only lights the red LED.
Must be more careful . . . Not going to happen though.
FW3A should easily survive 1m drop from any angle.
If it stops working, what probably happened is the head or tailcap loosened slightly. Loosen the head, then loosen and tighten the tailcap, then tighten the head. It should then work normally.
For the driver to fail from a drop it would have to have something improperly soldered. I had this happen to my Sunwayman V10A years ago. Head fell 1m onto wooden floor during a battery change. Something popped off the driver. Could hear it rattling around in the head. Light didn’t work again (until I opened it up, found the component and soldered it back on. Even then it never worked quite right after that).
After disassembling the 3D twice more and reassembling, somehow it must have broken the short and started to work. This allowed me to troubleshoot some more, and I found what I think might be the problem with the 7A.
Checking resistance in the head, both lights have zero resistance between the spring and + wire on the mcpcb. However, the working 3D shows a resistance of 0.33 Mohm between the square head threads and the - wire and the 7A has absolutely no contact. I’m guessing there’s a broken solder joint at the driver side of the wire.
I received my 2 FW3As this past Monday, the 20th. My Sanyo NCR18650GAs arrived yesterday, the 24th and I charged them over night. This morning is the first time I can test if they work.
One my FW3As is seeming to work fine. The other seems dead on arrival. It will not turn on. I swapped the head from the working FW3A and it works so the problem is with the head. I read through all these pages and I see that there are instructions to check the retaining ring. The retaining ring is pretty tight, I can’t even move it clockwise or counter clock wise. I can’t really tell if the notches on the board and the head line up. I’ve been trying to take off the retaining ring to see if I can adjust the board positioning, but the ring is on there so tight that my needle nose pliers are scratching/taking small pieces of the ring off.
When I tighten the faulty head, it doesn’t even blink indicating it’s receiving power. My functional FW3A head blinks regardless of which body I screw it on. I haven’t contacted Neal yet, but is there anything I can do? Any specific tool I can use on the retaining ring to stop scratching/taking small pieces of it off?
Edit: just realized I was damaging the nearby thread, not the retaining ring itself.
I can’t think of much except get some small cheap needle nose and maybe grind the ends to get a better grip.
Did you check under the optic? Are the led wires soldered? Is the positive wire getting voltage when screwed on to the body? You can try shorting the led negative wire to the head and it should be like Turbo. There might be a driver issue or maybe an led wire came loose on the driver. It’s hard to say.
I find pounding 2 nails through a piece of wood works better than needle nose pliers and cheap and easy to make. You just have to get the nails in the wood reasonably close to what’s needed and then bend them to fit in the notches.
Please take a look at THIS suggestion. The variant I use myself is a combination of a 2 inch SS nail and a small round pry bar (the handle of which can rest in the palm of my hand). The way you cross them depends on what you want to do (loosen or fasten retaining ring). The rubber band is not meant to apply force but to prevent things from flying around.
Got mine about a week ago. It worked pretty good for a few hours then became erratic, then wouldn’t turn on. Threads cleaned and metal particles blown out (just a few shards). Came here to BLF and performed recommended tweaks: caps and temp sensor calibrate. The flashlight is working fine now save for muggle mode, which is somewhat unpredictable. Most of the time mm works, but sometimes it ramps down from hi. Temp was reset a couple times with no change to mm function. I placed the flashlight into the refrigerator, curious to know if the thermometer in the FW3A was working. It works fine. All other functions besides mm work as designed. Since I don’t loan out nice flashlights, muggle isn’t that important to me.
I have to say, this I the nicest looking flashlight I have ever seen. The gray matte anodizing is sharp looking, and the design is what I would call understated class. Reminds me of the old e-type jag before rubber bumpers. The tail switch is quite satisfying, aircraft grade all the way. There is not one thing I would change about the programming. It is a logical and intelligent UI, though it took me awhile to figure out. Turbo, oh christ, it’s a firebreather. Amazing. Moon is nicely dim, just right. If lens is turned skew to strong light it exhibits tones of pink and purple, indicating a good anti-reflection coating.
The transition from spot to spill is almost seamless and the beam shows virtually no color shift or artifacts. Very nice. I have the 3a. I don’t know the cri but it must be pretty good. The pocket clip looks to me like dark gunmetal, not black, and is plenty strong. I left it attached so it won’t roll. I would like to see what a matte finish natural titanium clip would look like.
My compliments to the FW3A team for putting together a solid contender in a really crowded field. My compliments to Lumintop for bringing it to life with a quality build. The FW3A is a real thoroughbred, and a pleasure to use.
They’re actually not very good for the FW3A if the driver retaining ring is super tight like on my one, tried them, failed.
Might work to get some tightening done but better to use a set of old small flat tipped tweezers with the tips bent outwards.
